Driveshaft install question, and other banes of a clutch job - Page 3 - BMW M5 Forum and M6 Forums
 1Likes
post #21 of 23 Old 2nd August 2017, 04:43 PM
BeerTechB
BeerTechB's Avatar
Originally Posted by phtzer View Post
OK so this was the problem: pic
My pressure plate was in the original position and therefore there was no enough spring back for the throw out bearing. Those pins line up with holes in the flywheel, I must have missed that these pins were not depressed. Luckily the flywheel was not damaged.
Good to know! Was everything else in correctly?
Sent from my SM-N920V using Tapatalk
BeerTechB is offline
post #22 of 23 Old 2nd August 2017, 04:52 PM Thread Starter
phtzer
phtzer's Avatar
Yes I believe so, thanks so much for you help!
phtzer is offline
post #23 of 23 Old 2nd August 2017, 05:02 PM
BeerTechB
BeerTechB's Avatar
No problem! Let us know when it's up and running.
DIY: Rear Main Seal / Clutch / Driveshaft DIY with pics tripevans E39 M5 and E52 Z8 Discussion 13 30th June 2018 02:47 PM
New flywheel and clutch job Humblem5 E60 M5 and E61 M5 Touring Discussion 22 13th September 2016 04:19 PM
About to do a clutch/flywheel job.. does anybody around Socal have the Clutch tools i can borrow? CarbonHan E39 M5 and E52 Z8 Discussion 11 5th October 2012 06:29 PM
Clutch job question - Zhan E39 M5 and E52 Z8 Discussion 3 31st August 2011 06:28 AM
Dinan 3.91 Diff install Q - Driveshaft alignment? JeterM5 E60 M5 and E61 M5 Touring Discussion 3 14th February 2008 08:35 PM
