Rear view mirror just went Tango Union; Options? - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 14 Old 26th May 2017, 10:26 AM Thread Starter
dhl93449
dhl93449's Avatar
I have a 2002 E39 M5 with 55K mi on it. We have been having some toasty weather here in CA, and I now have a fluid bubble in the top half of my (internal) rear view mirror. Inside the bubble the mirror does not darken. In the region outside the bubble, it does. In daytime you can barely see the separation, but at night it is quite visible. I know this has been a historical failure issue, and this mirror was already replaced by Magna Donnelly in 2007.
I checked and an OEM replacement from BMW is between $500 and $650, depending on the source. Does anyone know if Magna Donnelly is still replacing mirrors? They appear to have a functioning website (Magna: Contact Us). Are the OEM versions still MD mirrors or are they now made by someone else? I am not sure I want to spend $500 on a mirror that will fail again in a few years.
I thought the replacement from MD was supposed to fix this problem, but it appears not. I had a link at one time to the procedure for replacing the mirror, but cannot find it all these years later...
Also, I considered just placing some sort of aftermarket mirror over the OEM, but that would look tacky, and I have heard these mirrors can leak that nasty electrochromic fluid which is toxic and corrosive soon after you get the bubble. All which mean replacement in the not too distant future.
dhl93449 is offline
post #2 of 14 Old 26th May 2017, 10:44 AM
gsfent
gsfent's Avatar
1. https://www.m5board.com/vbulletin/m5-...or-repair.html
2. Clemster
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is online now
The Following 2 Users Say Thank You to gsfent For This Useful Post:
dhl93449 (27th May 2017)
post #3 of 14 Old 26th May 2017, 11:41 AM
Duck
I tried this:
https://www.amazon.com/Mirror-Dimmin.../dp/B01IWJP9CY
The very very difficult part is opening the mirror case and not breaking the tabs. The actual replacement part is easy.
Duck is offline
The Following User Says Thank You to Duck For This Useful Post:
post #4 of 14 Old 26th May 2017, 03:35 PM
Ibmotoren
Ibmotoren's Avatar
...I have heard these mirrors can leak that nasty electrochromic fluid which is toxic and corrosive soon after you get the bubble. All which mean replacement in the not too distant future.
Yes, definitely pull it out if you haven't already. You don't want that goop all over your shifter.
https://www.m5board.com/vbulletin/e39...ml#post1653226
2001 ///M5 ...Anthracite / Black Complete-Heritage
Ibmotoren is online now
post #5 of 14 Old 26th May 2017, 04:36 PM
augustballer
augustballer's Avatar
I just use the square (rectangle) one from the non-M e39's. The one I have is auto-dimming, but I'm not sure if they all are.
augustballer is offline
post #6 of 14 Old 26th May 2017, 06:31 PM
jasoncjung
The first thing I did when I purchased my car was use RadarMirror that @gsfent posted (option 1). It was like $110 + shipping or so, with a 1 day turnaround (then add to/from shipping times based on your location from him - Texas). So far no issues, and of course eliminates some worry of leaking hopefully.
My buddy with an Mcoupe "thought" about doing this, but procrastinated (and was being cheap), then found leaky fluid on his dashboard which did some nasty stuff - so the $110 was well spent - and should have been done immediately instead of dealing with the frustration of cleanup.
Also just be careful in removing the mirror - follow the instructions instead of brute force. ask me how I know.
jasoncjung is offline
post #7 of 14 Old 27th May 2017, 04:29 AM Thread Starter
dhl93449
dhl93449's Avatar
Do you know if I can drive the car without the rear view mirror? I mean will there be any issues with the alarm or other electronics (besides the obvious rear view safety issue)?
dhl93449 is offline
post #8 of 14 Old 27th May 2017, 04:32 AM Thread Starter
dhl93449
dhl93449's Avatar
It appears all the "square" versions appear to be NLA according to RealOEM. Besides any "electrochromic" versions (self dimming) will have this problem.
dhl93449 is offline
post #9 of 14 Old 27th May 2017, 05:31 AM
Ibmotoren
Ibmotoren's Avatar
Fortunately I haven't had to find out yet! However, from what I've read there are no reports of such issues. With this being a very common failure I would think there'd be a lot of posts about such problems. It sounds like the common course is to send your mirror off to be repaired (e.g. radar-mirror), so if that caused alarm issues while you were without it, there would be many posts about that. Hopefully someone with first hand knowledge will chime in if there actually are any side effects.
The Following User Says Thank You to Ibmotoren For This Useful Post:
post #10 of 14 Old 27th May 2017, 06:31 AM
jasoncjung
I don't recall any issues driving or arming car without having a rear view mirror. Having never driven without an actual mirror, it threw me for a whirl every few seconds I'd look and there was literally nothing to look at. I was very confused, every single time I did it.
I know my car would beep/lock when I would press the button on the key fob, so the alarm seemed to work. That being said, the "red nose" on my mirror didn't work/flash when I bought it . . . and didn't work post radar-mirror - but that's not a function of the radar-mirror service. But I'm fine not having a red light flash - if that's what it's "supposed" to do when it's armed (frankly I'm unsure what the red nose does).
The Following User Says Thank You to jasoncjung For This Useful Post:
Ibmotoren (27th May 2017)
In the rear view mirror J_C Koenigsegg Forum | koenigseggboard.com 6 9th February 2016 07:56 PM
Valentine One & Escort Rear View Mirror Systems from Radar-Mirror.com RaceMX-M3 M6 E63 Group Buy and Sponsor Discussion and Offerings 1 3rd April 2011 05:16 AM
Valentine One & Escort Rear View Mirror Systems from Radar-Mirror.com RaceMX-M3 M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 26 2nd April 2011 11:30 PM
V1 in rear view mirror blueaudis4 E39 M5 and E52 Z8 Discussion 11 3rd September 2008 11:58 PM
Rear View Mirror Ocean's M5 E39 M5 and E52 Z8 Discussion 8 8th January 2008 05:30 PM
