Do you still regularly launch the E39 and what performance to expect? - Page 2 - BMW M5 Forum and M6 Forums
 5Likes
post #11 of 13 Old 18th April 2017, 01:42 PM
M3Fan
Originally Posted by Larry's M5 View Post
I went for full on hard launching last night, but I think something just went LOL Bad wheel hop and guess it's time to look at rear joints and guibo before anymore launch for me....
If I lose traction on a launch it's all wheel hop like crazy. The only thing that hasn't been replaced in my suspension/drivetrain is the RSF bushings so it must either be them or just inherent with the M5. Everything else including the DS has been replaced and it's still hop central if I break loose. Of course, a perfect launch isn't going to be breaking both tires totally loose so she leaps off the line quite nicely with minimal traction loss if I do it right.
Evolve Alpha-N tune, FMU Rear Exhaust, E60 Shifter
M3Fan is offline
post #12 of 13 Old 18th April 2017, 02:23 PM
CSBM5
CSBM5's Avatar
If you get wheel hop, get out of the throttle immediately. Do not power through wheel hop unless you want to deal with the consequences. Wheel hop depends on many, many variables from tire/road surface coefficient of friction, sidewall spring rate, torsional drivetrain stiffness and damping rates (one of the most important variables), suspension spring rate, suspension damping rate, bushing spring rates and damping rates, stiffness of suspension components, subframe, and body-in-white, etc.
The ones you most likely can easily affect (tires, road surface, rate clutch engagement vs rate power applied) will yield a widely varying outcome in whether you produce the wheel hop for a given launch. If you get the weight transfer right on the initial few 10ths of a second, you can hook up the tires hard and get a great launch (60' time) without undue stress (abuse) on the car.
Current stable:
CSBM5 is offline
The Following User Says Thank You to CSBM5 For This Useful Post:
Ibmotoren (18th April 2017)
post #13 of 13 Old 18th April 2017, 10:04 PM
pyite
pyite's Avatar
I don't think it is inherent with the M5. I drive it pretty hard and have never experienced this, thankfully.
pyite is offline
Stereo sound cutting out regularly, comes back when changing source or radio station Hammerzeit E39 M5 and E52 Z8 Discussion 0 3rd September 2014 12:12 PM
My E39 M5 in accident - what to expect? MFizzel E39 M5 and E52 Z8 Discussion 18 12th July 2007 08:06 PM
Who here tracks their M5 regularly? KWP E39 M5 and E52 Z8 Discussion 21 17th March 2007 07:15 AM
Wat can you expect from a E39 M5 msport E39 M5 and E52 Z8 Discussion 3 8th February 2005 05:58 PM
How many of you take your M5 to the track regularly? Terrence E39 M5 and E52 Z8 Discussion 2 19th February 2001 02:22 PM
