Any Performance Advantage in 19"or 20" Rims - BMW M5 Forum and M6 Forums
post #1 of 49 Old 16th June 2005, 06:51 PM Thread Starter
JRWM5
JRWM5's Avatar
Is there a performance advantage in switching to a light weight 19" or 20" Rim or a larger rim just looks better?
JRWM5 is offline
post #2 of 49 Old 16th June 2005, 07:00 PM
ELEVENS
Registered User
Re: Any Performance Advantage in 19"or 20" Rims
I think only if they're lighter and wider - which is a very tall order!
ELEVENS is offline
post #3 of 49 Old 16th June 2005, 07:57 PM
M Power
M Power's Avatar
Most, if not all, 19 or 20 inch wheels will be heavier than the stock wheels. But what you might do is swap your brakes for StopTechs or Brembo's and you might end up net neutral weight wise..
Stop Tech 4 wheel set up will not fit under your stock rear wheels but Brembo's do, with spacers for the front.
But in my opinion, any rim size increase should be for the eye candy appeal only.. Good luck in your choice
Andre
E 39: CB / Black - most tasteful options (fondly missed)
E 60: IB/Black - Everything except vented seats and split rears (gone)
997 C2S with X51 power kit: Black on black, most tasteful options I think
Life is not measured by the number of breaths we take.. but by the moments that take our breath away.
M Power is offline
post #4 of 49 Old 16th June 2005, 09:07 PM
SC'dKellenersM5
SC'dKellenersM5's Avatar
as tire diameter increases especially on cars that have been previously optimized by a performance tuning entity (M, AMG, PVO, etc...) you will gain nothing and have alot to loose.
As diameter increases so does the rim mass of the wheel and the sidewall of the tire also decreases. Sidewall flex is a bad thing in most cases but going past a certain point especially in the 18"+ range is asking for problems.
18-19...no bigger.
Im in the highspeed aluminum business
SC'dKellenersM5 is offline
post #5 of 49 Old 16th June 2005, 09:35 PM
M-Fünf
M-Fünf's Avatar
Rotating mass will degreade performance. A heavier wheel with lighter caliper would still degrade performance since the caliper is not rotating mass, only the wheel/tire/rotor, and all of those are getting bigger...
Right?
M-Fünf (a.k.a. Jeff)
His: Not an M5
Her's: '04 M3 Silver Gray/Black 6 speed
M-Fünf is offline
post #6 of 49 Old 16th June 2005, 09:51 PM
MPRESIV
MPRESIV is offline
post #7 of 49 Old 16th June 2005, 10:25 PM
Beamer_usa
Beamer_usa's Avatar
A wheel larger than 19' is strickly for show and cosmetics only. It will not add to performance or better handling.
Dinan Cans
Dinan Software
Beamer_usa is offline
post #8 of 49 Old 16th June 2005, 10:40 PM
alpineblue
rims on the rear of formula one cars are 13"--and feather light--so this tells you something about rim size for performance. race cars rarely go over 18"--even street exotics--mostly run 18" rims from the factory. however, the push for asthetics is high for consumers--the carerra gt has 20" on the rear i believe. with that much power you wouldn't notice the difference--but racers still use smaller diameters.
20" rims on an m5 would be hideous in my opinion.
Mark
2003 M5, Alpine White, Lemans Blue Interior, Dinan S2, Brembo Brakes.
alpineblue is offline
post #9 of 49 Old 16th June 2005, 10:53 PM
boplaw
I'm on the hunt for some 22" spinning dubs right now-)
Unskillful Raconteur
boplaw is offline
post #10 of 49 Old 16th June 2005, 11:02 PM
alpineblue
22" is a different story--can you set up a group buy?
Mark
Rims with Gun Smoke Finish STamulinas E39 M5 and E52 Z8 Discussion 13 20th November 2005 09:17 PM
AC Schnitzer 19 inch Type 3 Rims for sale SouthshoreM6 Parts / Other For Sale or Wanted 1 2nd November 2004 03:24 PM
M5 rims and X5 20 inch Rims alpineblue Parts / Other For Sale or Wanted 0 1st October 2004 01:51 AM
Need your opinion of 2 different wheel rims.... FAST 5 E39 M5 and E52 Z8 Discussion 3 3rd October 2002 07:44 AM
"Woe is me!" Back on stock rims... MarkM5Lauderdale E39 M5 and E52 Z8 Discussion 7 12th February 2002 08:52 PM
