DIY: Installing Einhorn billet shifter carrier bushings "Nuggets" - BMW M5 Forum and M6 Forums
 3Likes
  • 2 Post By TheShafro
  • 1 Post By TheShafro
post #1 of 9 Old 10th February 2017, 03:14 PM Thread Starter
TheShafro
TheShafro's Avatar
Installed these yesterday so I decided to make this write up for anyone interesting in buying a set. This is the method that worked for me. You may do it differently, but this will give you the general idea of how things go in/out.
Tools needed:
Flathead + Phillips Head screwdriver
Pry bar (I used an 18”)
13mm socket
13mm wrench
Punch/Chisel + Hammer or Socket + Vise
Dremel or angle grinder with cutoff wheel
Transmission jack or similar
Grease
1. Remove the shifter knob by pulling up and remove the shifter boot
2. Remove the foam and rubber insulation
Install: lubricate the inside of the rubber with silicone spray or anal lube to slide it onto the shifter easily
3. Turn the shifter cup clockwise to release the shifter lever
Replace this if it looks old and brittle
4. Once released, it should look like this
5. From underneath, remove the retaining clip. Pull it out and slide it back and remove the selector rod. Be careful not to drop any washers.
6. Now you gotta remove the pin that goes through the carrier
6a. Put a pry bar right under the clip and pry against the top of giubo. Use two hands, one to pry and the other to make sure the tip of the bar stays on the clip
7. Time to tilt the transmission. Use some kind of jack to hold the tranny while you remove the bolts holding it up. Six 13mm’s on the cross brace and two 13mm’s on the exhaust bracket
8. Now push the carrier up and forward then move it over towards the driver’s side and slide it out of the rear bushing. Make sure the carrier is clear of the shifter hole by rotating it.
9. Remove the old rubber bushings. You can use a socket and a vise or a punch and a hammer. Once you push out the bushing as far as it goes, cut it with a dremel or angle grinder. Then remove it.
10. Clean the inside
11. Install the nuggets. Female part in first on the inside, then the male part from the outside till both sides are flush
12. Grease the bushings on the outsides and use a cotton swab to grease the insides. This will make install easier
Now install everything in reverse order. Using a nut and bolt through the bushings was much, much easier than reusing the original pin you removed, literally took 5 seconds to put the bolt through. The size you want is M10x1.5 x 75mm and an M10 nut.
-Shady H.
@theshafro
'02 TiAg/Blk E39 lllM5
'08 JZB/FR E92
lllM3
TheShafro is offline
The Following 6 Users Say Thank You to TheShafro For This Useful Post:
FirstLineBMW (11th February 2017), gsfent (10th February 2017), mgdmb (11th February 2017), putty_thing (10th February 2017), Wane Ramsay (11th February 2017)
post #2 of 9 Old 11th February 2017, 03:22 AM
FirstLineBMW
Wow, great write-up, will definitely keep this in mind (& bookmark it) if I ever replace this bushing, thanks.
FirstLineBMW is offline
post #3 of 9 Old 11th February 2017, 07:06 AM Thread Starter
TheShafro
TheShafro's Avatar
Enjoy. And if anyone wants the billet bushings, I have them for $50 shipped.
-Shady H.
@theshafro
'08 JZB/FR E92
lllM3
post #4 of 9 Old 9th June 2019, 04:08 PM
Excoriar
Excoriar's Avatar
If ordering, does 1 set come with all the bushings for 1 car?
With great power, comes great credit card bills....
Excoriar is offline
post #5 of 9 Old 9th June 2019, 05:03 PM
DonutRanger
DonutRanger is online now
post #6 of 9 Old 10th June 2019, 10:50 AM
Excoriar
Excoriar's Avatar
I believe it reduces play in the shifter.
Excoriar is offline
post #7 of 9 Old 11th June 2019, 07:00 AM
bdiefAZ
bdiefAZ's Avatar
Great writeup, Thank you for posting the pictures. Is it possible to replace the rear mounting bushing with this approach as well?
bdiefAZ is online now
post #8 of 9 Old 11th June 2019, 04:29 PM
OjaiM5
OjaiM5 is online now
post #9 of 9 Old 11th June 2019, 09:28 PM Thread Starter
TheShafro
TheShafro's Avatar
I've never had luck getting that bushing out with the driveshaft still installed.
-Shady H.
@theshafro
'08 JZB/FR E92
lllM3
Tags
einhorn
"Softball" Control Arm bushings dhl93449 E31 850 CSi and E24 M635 CSi 13 18th June 2013 03:11 AM
"Softball" control arm bushings dhl93449 E39 M5 and E52 Z8 Discussion 22 3rd December 2012 03:33 PM
New BMW Campaign "Rear axle carrier"??? Tonygoalie E60 M5 and E61 M5 Touring Discussion 3 18th September 2009 05:34 AM
Ebay Front Steering and Suspension Kit with "HD" bushings crnjyM5 E39 M5 and E52 Z8 Discussion 8 12th April 2008 08:15 PM
Dash Message "Check Side Lights" after installing LED Markers KingM5 E39 M5 and E52 Z8 Discussion 32 12th March 2007 02:44 AM
