new clutch break in? - BMW M5 Forum and M6 Forums
post #1 of 13 Old 3rd June 2005, 02:26 AM Thread Starter
M5ROKIT
M5ROKIT's Avatar
Just had BMW Ridgefield, CT replace my clutch. It was slipping on hard acceleration at WGI. Wow! Is this how it was when new? It really engages early and I must get used to it! Anyway, should I "break it in" in any way?
Le Mans Blue with blue panels
Brake ducting
Stoptech big brake kit (black)
Slotted front/rear Aero Rotors
stainless steel front and rear brake lines
Dinan CAI w/stage 2 software
Dinan Stage III suspension w/JRZ
Dinan Front Strut Brace
275 fronts/rears
Nitto NT01 Track tire
Beast Power Rear Sway Bar Brackets
Powerflex Poly Bushings
Hawk HT-10 (for track, Axis Ultimates (street)
Eisenmann race exhaust 80mm
TEC cupholder
Euro arm rest
Autosolutions 25% short shift kit
Valentine One radar detector
AJ-USA Alluminum pedal set
Shroth harnesses (track)
<embed src="http://videos.streetfire.net/vidiac.swf" FlashVars="video=2bc84021-a84b-4ea5-9ac6-61c725f72e93" quality="high" bgcolor="#ffffff" width="428" height="352" name="ePlayer" align="middle" allowScriptAccess="sameDomain" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed>
Jaguar E-Type V12 1973
M5ROKIT is offline
post #2 of 13 Old 3rd June 2005, 02:50 AM
Lscman
Re: new clutch break in?
Just?? ...
A fresh clutch has substantially reduced torque capacity. In my opinion, max capacity is not realized for well over 1000 mi of break-in, unless it's all city stop and go driving. Highway cruising will never break-in a clutch...it requires clutch pedal cycling, stop and go and shifting.
Since the OEM clutch design has marginal capaity to begin with, racing at WOT with under 1000mi is very risky. Sustained slippage on a race track when still "fresh" can result in burning and glazing, so it may never recover.
I would NEVER install an OEM-quality clutch in an M5 expecting to run it on-track. You are asking a lot from a known weak clutch design that is notorious for prematurely failing under modest duty on the street....even behind a 282HP 540i motor.
Lscman is offline
post #3 of 13 Old 3rd June 2005, 02:57 AM
mr_bock
mr_bock's Avatar
You may have already broken it in... running hard on the new clutch. I burnt mine at under 5K because I did not know how weak the stock clutch was. You shudda gotten a heavy duty clutch......
Good luck guy
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
post #4 of 13 Old 3rd June 2005, 03:07 AM Thread Starter
M5ROKIT
M5ROKIT's Avatar
Well I guess 38K and 17+ track days isn't bad for the stock clutch then! It was under warranty if that clarifies anything up. I will definitely have 2K on it before next event at LRP.
What is my option if not going OEM?
Brake ducting
275 fronts/rears
TEC cupholder
Euro arm rest
M5ROKIT is offline
post #5 of 13 Old 3rd June 2005, 03:10 AM
mr_bock
mr_bock's Avatar
Do a search.... this has been discussed a lot and yes there are options...
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
post #6 of 13 Old 3rd June 2005, 04:25 AM
Lscman
You really have three reasonable options for uprated clutch for an M5...
Option 1) Single mass flywheel 11" clutch with uprated premium organic disk.
Option 2) Single mass flywheel 11" clutch with severe duty non-organic disk.
Option 3) Stock flywheel using 9-5/8" aftermarket clutch with severe duty non-organic disk.
Option 1 is more than adequate for most folks. It is good for road racing & very similar to OEM Corvette C5 and C6 setups in both size and design. It is not adequate for some severe drag racing situations where launches involve high RPM & high load, hoping to avoid wheelspin.
Option 2 is the strongest option out there...biggie clutch combined with racey high temp disc material. Hard high friction materials and lack of marcel cushion means engagement will be sudden, compared to organics. Smooth engagement will be difficult, if you're trying to operate in the limo mode. If you want to harness huge aftermarket horsepower or churn tire at will, this is it.
Option 3 is the poor-man's uprated clutch. It does not have much swept area, but the high temp & high friction disk substantially raises torque capacity compared to small organic setups. This small setup can absorb more abuse than stock, but the fragile dual mass flywheel can be fried. It provides marginal modulation & driveability like other racey disk setups.
Lscman is offline
post #7 of 13 Old 3rd June 2005, 06:43 AM
XrayMD
XrayMD's Avatar
Per BMW:
BMW AG - TIS
RA: Breaking in SAC clutch
Issue status (03/2002)
Break in the friction linings of the clutch by applying light to medium loads, in the same way as for brake linings. This preconditioning creates a carbon layer between lining and metal friction surface which in the end generates the necessary coefficient of friction. Breaking in can take the form of either normal driving with many gearshifts or a specific breaking-in program on gentle gradients.
"Normal" driving will not damage the clutch. "Normal" driving conditions involve drive-off speeds of up to approx. 2500 rpm on a medium gradient, e.g. when driving onto a transporter. Normal driving off on a level surface at speeds up to approx. 2000 rpm are likewise sufficient.
Sporting driving maneuvers will destroy a new clutch! These include driving maneuvers at high differential speeds, overlaps or very high drive-off speeds, e.g. when driving onto a transporter.
When a vehicle is moved "normally", an empirically established figure of approx. 800-1000 gearshifts is applicable to an optimally broken-in lining.
Please conduct the following breaking-in program in order to avoid later customer complaints:
* specifically for M5 and Z8 vehicles
Breaking-in program for approx. 30 km on road
Vehicle subject to "moderate" shifting processes
Drive off at max. 2000 rpm; upshift 1->2, 2->3, 3->4; upshift at 3500-4000 rpm, downshift 4->3, 3->2, 2->1, downshift at 2000 rpm
Drive off 3 to 5 times on a gentle gradient up to approx. 12%, drive-off speed max. 2000 rpm
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline
post #8 of 13 Old 3rd June 2005, 07:04 AM
bmwusa
bmwusa's Avatar
Originally Posted by XrayMD
Per BMW:
BMW AG - TIS
Good info, but where do you guys get this stuff? I have always been curious some of you guys seem to always have such technical information handy, About all I am good for is complaining, I personally wouldnt know where to get this stuff, do you find it on the internet or do you guys have freinds that work at dealerships and what not? regardless good info and thanks, Josh
1/2 of the Southern Renegades....
I just love the smell of JP-5 in the morning
bmwusa is offline
post #9 of 13 Old 3rd June 2005, 07:43 AM
FAST 5
FAST 5's Avatar
Question question for Lscman...........
Hi Lscman,
Where can one find/purchase a severe duty non-organic disk ??? Who has the best one? is there a name brand?
Please let me know, okay.
Thank you.
FAST 5 is offline
post #10 of 13 Old 3rd June 2005, 10:30 AM
DavidS
Moderator Emeritus
DavidS's Avatar
What I will never understand is: when BMW replaces a clutch under warranty, why can´t the SA spend 60 seconds to explain how to run the new clutch in? Surely, that would save time and money regarding the next clutch. And the next clutch....
The info is there in the TIS, they just have to learn to read it and follow it.
David
https://www.m5board.com/vbulletin/showthread.php?t=54788
https://www.m5board.com/vbulletin/showthread.php?t=88323
DavidS is offline
New Sachs Power Clutch tripleD E39 M5 and E52 Z8 Discussion 13 12th April 2005 09:04 PM
Stage 3 (6-puck ceramic) clutch 1st impressions 1badm5 E39 M5 and E52 Z8 Discussion 11 2nd November 2004 09:00 PM
Yet another clutch theory/technique thread greg E39 M5 and E52 Z8 Discussion 8 18th March 2004 05:55 PM
Proper way to break in the Sachs clutch? XrayMD E39 M5 and E52 Z8 Discussion 18 12th October 2002 04:55 AM
