Looking for a good DIY for Steering Shaft Lower Joint Assembly replacement - BMW M5 Forum and M6 Forums
post #1 of 9 Old 27th January 2017, 08:28 PM Thread Starter
Obioban
Obioban's Avatar
Obioban is offline
The Following User Says Thank You to Obioban For This Useful Post:
TheShafro (25th February 2019)
post #2 of 9 Old 27th January 2017, 09:20 PM
technician117
technician117's Avatar
Originally Posted by Obioban View Post
And can't find any.
Help?
Are you trying to replace the shaft? I would start by disconnecting it on the column side, observe how it goes through the firewall and unbolt anything there that might hamper pulling it out. Then get underneath and remove the pinch bolt on the steering box side. Use a prybar, etc to get the shaft off the 'box. It is collapsible, FYI. At that point I would speculate you can pull it out from the interior, but I've never removed one so everything I said is based on my general automotive knowledge tied in with work I've done around the steering shaft (replacing steering gear box, etc.).
Tim
2013 M5 Imperial Blue/Silverstone II, 6MT 50k miles
2000 Anthracite daily driver
UUC dssr and shifter
Supersprint headers with Tubi catback
Jailbreak tuning
Dinan 3.45 JED lightened flywheel
282,000 miles and counting
'00 Imola/Imola 104k,
'00 Silverstone/Silverstone 129k (SOLD)
technician117 is offline
post #3 of 9 Old 28th January 2017, 09:42 PM Thread Starter
Obioban
Obioban's Avatar
Obioban is offline
post #4 of 9 Old 30th January 2017, 01:34 PM
technician117
Well, I have it out, but the gasket that it passed through on the firewall is kicking my *** :P
Nice. Were my tips pretty much in line? Did anything not apply? I ask so that we can have the thread updated with proper info for future thread searchers.
Tim
Jailbreak tuning
post #5 of 9 Old 30th January 2017, 04:09 PM Thread Starter
Obioban
Obioban's Avatar
My situation was a bit unique, because I had the lower portion of the shaft already removed (refreshing the front end bits, lowered the front subframe). Looking at the lower shaft, it appeared to not be keyed, so when I was trying to reassemble it blindly, I assumed I had the wrong angle. In fact it was keyed, apparently, so doing it again I'd rotate it blindly until it properly lined up.
To insert the lower portion of the shaft, the gasket/bearing it passed through must be removed from the firewall. Note the orientation during removal, as it has to go back in the same way. The gasket has lips that must be sealed on both the sides of the firewall.
Other than that, attach the steering box side first (if disconnected)? Shaft can be removed from the steering wheel side with some gentle alternating prying. It just compresses in on itself, as you said. For reassembly, I gently tapped it back in place.
Every component of the steering system between the box and steering wheel is keyed in some way.
Obioban is offline
apetrov1x5 (2nd February 2017)
post #6 of 9 Old 2nd February 2017, 01:09 PM
apetrov1x5
what were your symptoms? Why did you replaced it?
apetrov1x5 is offline
post #7 of 9 Old 2nd February 2017, 02:19 PM Thread Starter
Obioban
Obioban's Avatar
Car has 150,000 miles on it and the front subframe was out for the project. While I was in there, I did everything I could think of to not need to drop the subframe again till 250,000 miles. I did every bushing, bearing, mount, and steering component on the car.
(did the same on the rear not long ago, and the engine before that-- I just prefer to do it all when I go into an area to minimize the amount of times I'm in an area/maximize the reliability of the car)
Obioban is offline
post #8 of 9 Old 25th February 2019, 08:36 PM
kashill
kashill's Avatar
I need to do the same, getting quite a bit of play in the steering wheel that does not transmit to the steering box. Do you have any pic's or the R&R? Also, is anyone aware of a Delrin or Powerflex replacement for the OEM rubber coupling bushing? Thanks1
kashill is offline
post #9 of 9 Old 25th February 2019, 09:17 PM Thread Starter
Obioban
Obioban's Avatar
I do not.
Obioban is offline
A good Alternator replacement DIY that's not dead thotlordsM5E60 E60 M5 and E61 M5 Touring Discussion 1 17th February 2016 07:21 PM
Steering box replacement DIY? Obioban E39 M5 and E52 Z8 Discussion 6 14th December 2015 02:34 PM
DIY: Lower coolant temp sensor replacement MPowrd E39 M5 and E52 Z8 Discussion 12 21st October 2015 05:03 AM
anyone know where i can find a good handbrake assembly DIY? markus037 E39 M5 and E52 Z8 Discussion 7 16th November 2013 02:33 AM
Drive shaft CV joint grease. lwebb12 E39 M5 and E52 Z8 Discussion 2 27th July 2012 07:20 PM
