BMW's Oil Viscosity changes. (quick question) - BMW M5 Forum and M6 Forums
 23Likes
post #1 of 100 Old 14th December 2016, 07:08 PM Thread Starter
3rd One
3rd One's Avatar
I haven't changed my oil since 8/2014 (only driven 800 miles since then) and just went to the dealership to purchase oil and a filter. The parts manager said they no longer sell 5/30 and that their 0/30 formula is "backwards compatible" and that it will be fine with my engine. For 13 years now I have always used 5/30 since thats what the sticker on my engine bay says to do (never used 10/60). I religiously send it out to Blackstone for analysis and have always had a clean bill of health.
Just making sure what he told me about 0/30 being ok to use is actually true.
thanks
2000 M5
2005 E55 Wagon
2018 S90 T6 Inscription
2008 Titan
3rd One is offline
post #2 of 100 Old 14th December 2016, 07:43 PM
gzig5
Lots of places sell 5W-30 oil, if that is what you want to run. The warranty is long expired so there is no reason to use oil sourced from the dealer, especially if they are changing the requirements. Do you think they actually tested the 0W-30 in an S62 engine to determine it was OK?
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is offline
post #3 of 100 Old 14th December 2016, 07:50 PM Thread Starter
3rd One
3rd One's Avatar
Right. I can find the BMW branded 5w/30 online in several places and have it tomorrow. I guess I was just wondering if anyone else had heard this or if any of it's actually true. Are the online vendors just selling old stock 5/30? The guy was listing his credentials being the parts manager for 15+ years, but it didn't make me feel any better.
I stick with BMW oil since I am a creature of habit and have had very few issues with this car, ever. Plus, with the BMWCCA discount its usually cheaper for me than any oil I can get elsewhere.
2000 M5
2005 E55 Wagon
2008 Titan
3rd One is offline
post #4 of 100 Old 14th December 2016, 07:59 PM
seabass23
seabass23's Avatar
You guys are discussing the viscosity designation of the oil and nothing else. Keep that in mind. The additive package that does the most work to protect your engine is the same.
The service manager is technically correct that 0W-30 is backwards compatible with 5W-30. For starters, the low temp (winter) viscosity is lower (0W vs 5W). This means the oil flows better at low temperature giving you better cold start lubrication. Because the viscosity ratings are given at two temperatures, the viscosity vs temperature curve of the 0W-30 is steeper than the 5W-30 curve. In simple terms, it means 0W will also have higher viscosity at extreme operating temperatures.
seabass23 is offline
post #5 of 100 Old 14th December 2016, 08:12 PM Thread Starter
3rd One
3rd One's Avatar
Obviously, my car sits a lot and still has relatively low mileage (75k). I do experience my lifters making a clicking sound if I don't start the car for a few months at a time. That noise is always gone by the time the car gets up to temp and I have had 10-15 minutes to really drive it. Would the 0-30 rating help that issue?
I am guessing from what you said that I should not be concerned with using 0/30 vs the 5/30 my mind tells me the car needs.
2000 M5
2005 E55 Wagon
2008 Titan
3rd One is offline
post #6 of 100 Old 14th December 2016, 08:40 PM
KevinM
KevinM's Avatar
BMW uses Shell oils now rather than Castrol. BMW still brands a 5-30 if you want to use it: Original BMW Accessories : Accessory finder
Ever since the TIS was released stating that BMW Castrol 10-60 OR 5-30 could be used in E39 M5s produced after the bearing change in 2/2000 (I think the TIS was released in 2006), I have been using Castrol 10-60 (prior to the TIS, the dealer would only use 5-30 because that is what the sticker says, and the car was covered under the BMW maintenance program). While Castrol is no longer the BMW supplier, I still use Castrol TWS 10-60 and I imagine you can also still buy the Castrol "German" formulation of 5-30.
Of course, any number of oils will be fine, such a Mobil 1 0-40, etc. BTW, the BMW/Shell 0-30 is what is being used in my F80 M3.
P.S. It's nice to have a good old-fashioned oil thread here...it's been far to long!
Kevin
2016 F80 M3, Mineral Grey/Golden Brown/6MT - ED delivery 6/3/2016 http://f80.bimmerpost.com/forums/sho....php?t=1291837
2007 Z4M Coupe Silver Gray/Black
Too many kids' cars...
KevinM is offline
post #7 of 100 Old 14th December 2016, 09:16 PM
seabass23
seabass23's Avatar
I personally would CHOOSE to run 0W-30 in any of my vehicles rated for 5W-30. To me it's the obvious upgrade since it provides better cold start performance AND better extreme temperature performance.
post #8 of 100 Old 14th December 2016, 09:26 PM
Obioban
Obioban's Avatar
I personally would CHOOSE to run 0W-30 in any of my vehicles rated for 5W-30. To me it's the obvious upgrade since it provides better cold start performance AND the same, all else equal extreme temperature performance.
Fixed that for you.
But, agreed. I run my car on 0w-40, for the cold start decreased wear. I run German Castrol, because it's BMW LL01 approved (unlike M1 0w-40, as of a couple months ago). I run the 0w-40 because it splits the hot thickness between the two weights BMW specs (30 and 60, but the 60 shears to a 50 almost immediately) and I am unlikely to ever track the M5 (where the TWS weight could become necessary).
All else equal (not necessarily the case, but for the purpose of discussing oils weights in isolation), a 0w-30 provides superior performance in lower temperature cold starts and equal performance at operating temperature. It is not, all else equal, any thinner at operating temperature (common misconception).
A thinner oil (e.g. 30 weight) actually provides superior wear protection than a thicker oil (e.g. 60 weight), right until it (suddenly, catastrophically) doesn't. A thinner oil also improves fuel economy and horsepower. The best oil to run is the thinnest you can get away with, but never exceed, for your usage set. Then, weight selected, get one that's approved for use in your car (for BMW's of our era, that mean LL01 approved, which it'll say on the back of the bottle).
Obioban is offline
post #9 of 100 Old 14th December 2016, 10:49 PM
seabass23
seabass23's Avatar
Originally Posted by Obioban View Post
Fixed that for you.
A thinner oil (e.g. 30 weight) actually provides superior wear protection than a thicker oil (e.g. 60 weight), right until it (suddenly, catastrophically) doesn't. A thinner oil also improves fuel economy and horsepower. The best oil to run is the thinnest you can get away with, but never exceed, for your usage set. Then, weight selected, get one that's approved for use in your car (for BMW's, that mean LL01 approved, which it'll say on the back of the bottle).
I stand by my original wording. At extreme temperatures (ABOVE normal operating), the 0W-30 provides BETTER protection. If you graphed viscosity vs. temperature on a log scale, you'd create two straight lines. Both lines would pass through the same viscosity at operating temperature but the cold start viscosity is lower for the 0W-30, therefore creating a flatter sloped line. As a result, your viscosity at extreme temperatures is HIGHER with 0W-30 than it is with 5W-30.
post #10 of 100 Old 15th December 2016, 05:57 AM
ard
ard's Avatar
Are people actually discussing and comparing oils based on the labeled viscosity range?!?!
the "0"...the '5'..the '30'????
Pretty funny.
I would never use oil thinner than the BMW HiPo 5w30 (which was close to a 5w40)... I run 10-60
I dont know the specs on BMWs new 0-30, but OP is wise to question BMW parts clerks.
ard is offline
Does anyone change their oil to different viscosity for summer? Fuddy E39 M5 and E52 Z8 Discussion 5 24th February 2007 08:01 PM
How important is the Oil Viscosity? Pip E39 M5 and E52 Z8 Discussion 30 13th March 2006 09:02 PM
oil viscosity vs temp mottati E39 M5 and E52 Z8 Discussion 12 10th August 2005 02:34 AM
This is one of those Oil Viscosity Discussions V-10 4 Me E39 M5 and E52 Z8 Discussion 1 23rd May 2004 08:05 PM
Oil Viscosity (again !!!) Steve Beswick E39 M5 and E52 Z8 Discussion 9 26th June 2003 08:48 PM
