BMW's Oil Viscosity changes. (quick question) - Page 2 - BMW M5 Forum and M6 Forums
 23Likes
post #11 of 100 Old 15th December 2016, 06:19 AM
Sailor24
Sailor24's Avatar
Any idiot working for BMW should have told him that they changed their minds and that they now only recommend 10w60 for the M5.
From a document I have posted many times
BMW Recommended/Approved synthetic oils doc. January 2008, Version 1.0
"The following is the only recommended and approved synthetic oil for BMW M
(Motorsport) vehicles in the US market with gasoline engines, at the present time.
BMW Long-life rating LL-01 Synthetic Oils for BMW M vehicles
equipped with S54, S62, S65 or S85 engines
Castrol TWS Motorsport SAE 10W-60 Synthetic Engine Oil, or
Castrol Formula RS SAE 10W-60 Synthetic Engine Oil
(BMW part number 07 51 0 009 420)
If Castrol High Performance Synthetic Oil is not available and you need to add oil
between oil changes, only use synthetic oils with the following specifications for M
vehicles:
Viscosity – preferred SAE 10W-60
Alternative – SAE 10W-40, SAE 5W-50 or SAE 10W-50
Use only oils with an API rating of SJ/CF, SK/CF or higher"
Sailor24 is online now
post #12 of 100 Old 15th December 2016, 08:31 AM
Thumper600
Thumper600's Avatar
and now, for something completely different:
http://test.resource.bmwusa.com/Pdf_...12c1eea2c.arox
I believe if one reads both pages any and all discussions will stop. Merry Christmas all
Thanks Sailor, I just posted the link to your copied and pasted posted numerous times document. Thanks again
Thumper600 is offline
The Following User Says Thank You to Thumper600 For This Useful Post:
Gouki (30th December 2016)
post #13 of 100 Old 15th December 2016, 01:50 PM
Obioban
Obioban's Avatar
Originally Posted by ard View Post
Are people actually discussing and comparing oils based on the labeled viscosity range?!?!
the "0"...the '5'..the '30'????
Pretty funny.
I would never use oil thinner than the BMW HiPo 5w30 (which was close to a 5w40)... I run 10-60
I dont know the specs on BMWs new 0-30, but OP is wise to question BMW parts clerks.
The average 0w-30 is no thinner than the average 5w-30 (or 10w-30 or straight 30) at operating temperature.
The labeled viscosity range is the correct way to compare oil viscosity-- it represents a range of thicknesses, when new, that the oil falls within. BMW's former 5w-30 is a thicker 30, but still in the 30 range. BMW's former 10w-60 was a thinner 60, but still in the 60 range (thought it becomes a 50 in the fist couple hundred miles, where it holds steady for a long time).
I don't think you're going to do any significant harm running a 10w-60. If I were to track the M5, it's what I'd put into it. But, when BMW specs oil, it has to be for all possible use cases of the car-- in the M5's case, that has to include tracking on a hot day. For those of us not tracking the M5, a 10w-60 just results in less power, less fuel economy, and more wear. And no, no matter how reckless/suicidal/stupid you are, you can't pull track level stresses on the car through aggressive street driving. People never believe that until they've actually tracked a car, but that's just a fact.
Obioban is offline
The Following User Says Thank You to Obioban For This Useful Post:
gsfent (15th December 2016)
post #14 of 100 Old 15th December 2016, 01:50 PM
Obioban is offline
Duck (15th December 2016)
post #15 of 100 Old 15th December 2016, 02:30 PM
Obioban
Obioban's Avatar
Originally Posted by seabass23 View Post
I stand by my original wording. At extreme temperatures (ABOVE normal operating), the 0W-30 provides BETTER protection. If you graphed viscosity vs. temperature on a log scale, you'd create two straight lines. Both lines would pass through the same viscosity at operating temperature but the cold start viscosity is lower for the 0W-30, therefore creating a flatter sloped line. As a result, your viscosity at extreme temperatures is HIGHER with 0W-30 than it is with 5W-30.
I think you're a bit off.
A better indicator of what you're looking for is viscosity index. The higher the VI, the less the viscosity changes with temp (which would be a shallower ramp, not a steeper one). That means it thickens less at low temps, thins out less at high temps. Typically a 0w-30 will have a higher VI than a 5w-30.
Caveats:
1. if the 5w-30 is made with much thicker base stocks than the 0w-30, it might still be thicker at all the hot temps it'll actually see
2. there's more than one way to get a high VI, and some methods leave the oil with less shear stability. so, in the hottest parts of the engine, the shear forces might make the 0w-30 thinner than its VI would suggest at that temp
so, if you're comparing Mobil 1 5w-30 to Castrol Edge 0w-30 SPT, the 0w-30 will likely be thicker when really hot because it'll hold its viscosity better
but if you're comparing BMW 5w-30 to Mobil 1 AFE 0w-30, the 5w-30 will probably be thicker when hot. One way to figure this out would be to look at VI and HTHS viscosity.
if both are high, that's one hell of an oil when hot
high VI + low HTHS = really not shear stable
low VI + high HTHS = likely suitable, though might be thicker than preferable when cold
low VI + low HTHS = terrible
(this is all assuming you're comparing oils within a given viscosity grade, e.g. xw-30)
Obioban is offline
post #16 of 100 Old 15th December 2016, 04:11 PM
seabass23
seabass23's Avatar
Caveats:
This oil thread has broken down just like they all seem to do. Let's all scroll back to the original post where a fellow user asked a pretty basic question about comparing two different bottles of oil.
Although it was implied by the photo, he didn't actually even tell us what car it was going in to!
seabass23 is online now
post #17 of 100 Old 15th December 2016, 04:17 PM
Obioban
Obioban's Avatar
lol, my post was an example of a thread breaking down? I think not. It was presenting factual information about the question that was asked by the OP in the first post thread of the thread.
Obioban is offline
post #18 of 100 Old 15th December 2016, 04:32 PM
Obioban
Obioban's Avatar
Obioban is offline
post #19 of 100 Old 15th December 2016, 05:44 PM
seabass23
seabass23's Avatar
All I meant was that the OP presented his question in very simple terms, implying that he was looking for an answer that was also presented in simple terms.
post #20 of 100 Old 15th December 2016, 05:45 PM Thread Starter
3rd One
3rd One's Avatar
Even with the photo, I just assumed you guys knew I was talking about my truck
thank you all for the lively discussion about this.
2000 M5
2005 E55 Wagon
2018 S90 T6 Inscription
2008 Titan
3rd One is offline
Does anyone change their oil to different viscosity for summer? Fuddy E39 M5 and E52 Z8 Discussion 5 24th February 2007 08:01 PM
How important is the Oil Viscosity? Pip E39 M5 and E52 Z8 Discussion 30 13th March 2006 09:02 PM
oil viscosity vs temp mottati E39 M5 and E52 Z8 Discussion 12 10th August 2005 02:34 AM
This is one of those Oil Viscosity Discussions V-10 4 Me E39 M5 and E52 Z8 Discussion 1 23rd May 2004 08:05 PM
Oil Viscosity (again !!!) Steve Beswick E39 M5 and E52 Z8 Discussion 9 26th June 2003 08:48 PM
