B9 , Exhaust camshaft Vanos position control - Page 4 - BMW M5 Forum and M6 Forums
 4Likes
post #31 of 107 Old 20th November 2016, 04:38 PM Thread Starter
vallibirgiss
Yes i know about the install having it all the the way clockwise and first available tooth etc
If i can take it out without loosening all the hub bolts what was the purpose of looseing them as seen in all the guides and diy , all say turn to overlap , slacken 3 bolts , turn to ign and slacken the rest, them spit out the gears
One thing i was thinking about , the hub bolts have to be tighten to 10NM , but there is no way to get a torque wrench on them ?
vallibirgiss is offline
post #32 of 107 Old 20th November 2016, 07:17 PM
BreakMyWindow
BreakMyWindow's Avatar
That procedure sounds like for cam timing adjustment.
Use a crows foot extension on your torque wrench or just practice torquing a bolt to 10nm so you memorise how much pressure to apply.
BreakMyWindow is offline
post #33 of 107 Old 21st November 2016, 12:58 AM
manualshifter
manualshifter's Avatar
Smile
Originally Posted by ard View Post
Scary huh....
yes, an Aussie. No name didnt start with M5.
Sailor was part correct, my sig does start with an "m"
Allan
manualshifter is offline
post #34 of 107 Old 30th November 2016, 08:18 PM Thread Starter
vallibirgiss
So just got my o rings and everything
One thing i have been thinking about is the torque on the hub bolts
Cant i put the splines in the hubs and torque them before i put the upper timing cover on?
That would allow me to get the right torque them i would use the 7mm and 10mm method when i put the vanos unit on?
post #35 of 107 Old 1st December 2016, 10:52 AM
BreakMyWindow
an easier way is to just torque them up, mark them then tighten them to the marked positions if u needed to re-adjust cam timing.
I never bothered torquing. I checked them after 6,000kms. None were loose.
post #36 of 107 Old 5th December 2016, 08:09 PM Thread Starter
vallibirgiss
In the middle of assemble it
One thing i was wondering about , is when you are putting the gears into the hub and engaging the first tooth
How much do you need to turn the hub counter clockwise to engage? I was trying last night and i always had to turn it a bit maybe 6-7 mm before it would engage, i thought you only had to turn it slighty then the gears would mash up
post #37 of 107 Old 5th December 2016, 09:10 PM
BreakMyWindow
Should be less than that. I practiced the engagement procedure with the vanos spline and hub unit out of the car on the bench. First available set of teeth and it will slide in. Maybe turn the splines and re-engage them in to the hub so you get the first available tooth.
post #38 of 107 Old 15th December 2016, 09:39 PM Thread Starter
vallibirgiss
Finally had the time to work on the M5 , put it all back to together accordin to jamiepeers Spring plate renewal thread
Everything went fine but after i tightend the hub bolts , i couldn't move the cams back and forth to advance and retard , they were just stuck i used alot of force to try to brake them free
I did change the upper timing chain tensioners aswell
post #39 of 107 Old 16th December 2016, 10:09 PM
herrubermensch
Originally Posted by mech9t8 View Post
Vanos unit are the same. The orientation of the solenoids in the vanos is different between left and right which is why they have different part numbers.
Absolutely correct.
--Peter
herrubermensch is offline
post #40 of 107 Old 16th December 2016, 10:17 PM
herrubermensch
Once you tighten down all six Vanos hub bolts on each cam, you will not be able to advance and retard the cams fully by hand. If you could, the vanos springs wouldn't be doing their job. In my experience, at that point, all one can do is "wiggle" the cams with a 27mm crescent.
--Peter
B8 (Intake camshaft VANOS position control" VANOS Passes All Tests thekurgan E39 M5 and E52 Z8 Discussion 12 15th November 2015 09:32 PM
Vanos exhaust position control and exhaust retard valve technician117 E39 M5 and E52 Z8 Discussion 10 31st October 2014 01:54 AM
Exhaust camshaft VANOS Position control, Cly #5-8 mubarak E39 M5 and E52 Z8 Discussion 8 18th September 2014 01:39 PM
Code b9 "Exhaust Camshaft 1Vanos Position Control murph550 E39 M5 and E52 Z8 Discussion 3 28th January 2009 03:02 PM
Is it safe to drive the M with an Intake Camshaft Vanos Position Control Error? Stickman E39 M5 and E52 Z8 Discussion 6 29th June 2006 12:51 AM
