B9 , Exhaust camshaft Vanos position control - Page 3 - BMW M5 Forum and M6 Forums
 4Likes
post #21 of 107 Old 17th November 2016, 03:24 PM Thread Starter
vallibirgiss
manualshifter: Thanks ! just read your thread and i will go out and check all grounds and such
If i cant find any faults in the wiring il guess i will swap the vanos units (not just the boards) side to side and see if the ticking noise and error code will move with it to bank 2
vallibirgiss is offline
post #22 of 107 Old 17th November 2016, 04:23 PM
xrviz
xrviz's Avatar
You can't swap the VANOS units side for side. They are mirror image. But you can refurb them once they are out.
xrviz is offline
post #23 of 107 Old 17th November 2016, 05:08 PM Thread Starter
vallibirgiss
According to Beisan procedure they are
"Note: Vanos units are same and interchangeable, but itís best practice to maintain vanos to engine head association. Vanos is originally oriented with vanos sticker to bottom."
post #24 of 107 Old 17th November 2016, 06:13 PM
xrviz
xrviz's Avatar
xrviz is offline
post #25 of 107 Old 17th November 2016, 07:00 PM
mech9t8
mech9t8's Avatar
Vanos unit are the same. The orientation of the solenoids in the vanos is different between left and right which is why they have different part numbers.
mech9t8 is online now
post #26 of 107 Old 18th November 2016, 03:05 AM
Sailor24
Sailor24's Avatar
They did the same with the pistons. Claiming they were different in each bank. We now know that is untrue, but if you have different pistons you would also need different vanos units.
Sailor24 is offline
post #27 of 107 Old 19th November 2016, 12:02 AM Thread Starter
vallibirgiss
Update : I'm 90 % sure that the wiring is ok after spending about 4 hours looking through everything , so i decided to pull the vanos bank 1 unit off.
Intake timing is spot on and the piston sit flush with the end of the bore, when i try to put the exhaust to inital timing it lands on a hard stop and the timing mark is off by a little and the piston is about 14mm inside the bore (see pictures)
So two thing could be happening i think ,, one way is that the timing on the exhaust is off (could that be the source of the code and the ticking?) [B]OR[B] the splines are getting jammed or stuck so i cant retard it all
the way
Is it right that i cant get the vanos unit off (with out disturbing timing) unless i get the piston all the way flush to allow movement for the 7mm and 10 mm keys?
The problem is almost identical as in this thread
https://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/479226-help-bought-another-m5-vanos-bank-1-issues-ticking-sound-idle.html
post #28 of 107 Old 19th November 2016, 07:09 PM Thread Starter
vallibirgiss
Thumbs up
Was finally able to remove the vanos unit (the whole unit with splines) , i was able to loosen the 3 hubolts and then i could but the exhaust camshaft to it's initial postion
Just order the S62 Vanos seal repair kit , and Rattle kit from Beisan along with all new solenoid O-rings , hoping that can solve my problem , either way it's gonna be a calm of mind knowing that everything in the vanos department is 100 % , doing valve cover gasket and changing the 2 intake cps aswell since i already renewed the exhaust earlier
I'm thinking the problem is somewhere in the spring plates (as described in the thread i noted before)
But one think , while i did the vanos removal with locking cams etc , i only focused on bank 1 and didn't even open the bank 2 , but now i'm obviously gonna be removing the vanos bank 2 unit to upgrade the plates.
How do i go about this when i have locked the bank 1 cams ?
Must i remove the cam locking pins and turn the engine to TDC overlap , loosen the 3 hubolts on bank 2, turn it to TDC ign , lock both cam on bank 1 & 2 , then go on and loosening the rest of the bolts and removing bank 2 unit?
post #29 of 107 Old 20th November 2016, 06:48 AM
mech9t8
mech9t8's Avatar
You shouldn't have to loosen the hub bolts to remove the vanos. You just need to jiggle the cam with the spanner.
You don't need to unlock the cams (on the side that you have already removed the vanos) to remove the vanos on the other side.
You also don't need to rotate the engine.
post #30 of 107 Old 20th November 2016, 10:54 AM
BreakMyWindow
BreakMyWindow's Avatar
Yep, just wiggle the cams with spanner and the vanos gears should spit out. Loosening the 3 accessible cam hub bolts per cam helps with this. Back them off quite a bit, not just a 1/4 turn.
Once you have done the spring plates on both banks it is absolutely critical you re-insert the vanos gears in to the hubs correctly. If you haven't already, search for 'Spring plate renewal' on here and follow the re-installation steps to the letter.
Check your static cam timing with the piston covers installed or your timing will be off.
BreakMyWindow is offline
B8 (Intake camshaft VANOS position control" VANOS Passes All Tests thekurgan E39 M5 and E52 Z8 Discussion 12 15th November 2015 09:32 PM
Vanos exhaust position control and exhaust retard valve technician117 E39 M5 and E52 Z8 Discussion 10 31st October 2014 01:54 AM
Exhaust camshaft VANOS Position control, Cly #5-8 mubarak E39 M5 and E52 Z8 Discussion 8 18th September 2014 01:39 PM
Code b9 "Exhaust Camshaft 1Vanos Position Control murph550 E39 M5 and E52 Z8 Discussion 3 28th January 2009 03:02 PM
Is it safe to drive the M with an Intake Camshaft Vanos Position Control Error? Stickman E39 M5 and E52 Z8 Discussion 6 29th June 2006 12:51 AM
