B9 , Exhaust camshaft Vanos position control - Page 2 - BMW M5 Forum and M6 Forums
 4Likes
post #11 of 107 Old 9th November 2016, 08:29 PM
mech9t8
mech9t8's Avatar
I don't want to create panic but maybe one of the vanos units failed. It's a rare occurrence but can happen...it happened to me. I had a B8 code and followed a similar path that you have without fixing the problem. Turned out the vanos unit shredded itself.
Try opening the oil cap and looking towards the vanos to see if anything looks out of the ordinary. Other side will be more difficult to check. Pull the oil filter to see if you have any metal in it. Lastly drop the oil pan to see if there are any remnants of a failed vanos.
Good luck.
mech9t8 is offline
post #12 of 107 Old 10th November 2016, 10:32 PM Thread Starter
vallibirgiss
Sailor24 : Alright i will check that tomorrow , any suggestions on what to check otherwise?
mech9t8 : I'll guess ill pull the valve covers off and check , i dropped the pan recentley and nothing out of the ordinary there.
Also there has always been a ticking sound coming from that bank 1 , i just assumed it to be the vanos sound but maybe this is the problem of the ticking sound , since i belive ive had this code for a quite a long time, the car seems to work fine so i've never really bother fixing it but now i want to fix it
I'm always open for some suggestion no matter how crazy / unlikley they are
vallibirgiss is offline
post #13 of 107 Old 11th November 2016, 06:03 PM Thread Starter
vallibirgiss
So i pulled the vanos boards out again , one thing that struck me is that when i pulled bank 1 is that the oil seemed to have alot of air bubbels compared to the bank 2
Update : i pulled the covers for the pistons , the exhaust cover was full of oil inside (bad seal)? While the inlet cover there was no oil
Could thos be the culprit?
post #14 of 107 Old 12th November 2016, 07:24 PM
Sailor24
Sailor24's Avatar
Yes. That could be the cause. Check the other bank not sure if the the oil question is valid but your conclusion is.
Sailor24 is online now
post #15 of 107 Old 12th November 2016, 08:39 PM Thread Starter
vallibirgiss
Checked the bank 2 covers , they were full of oil aswell so that must be normal
Recap
B9 - Exhaust camshaft vanos postion control bank 1 (Exhaust retard dosen't retard more then 6-7 degrees according to reader, (should retard all the way to 60ish degrees i belive ))
Engine ticking on bank 1 when hot ( not sure if that related to the code but likley)
Have swapped the Boards and put in new cps and swapped them aswell and the error always stays on bank 1 side
I have no idea where to look to next , was wondering if i could maybe meassure output voltage on the bank 1 vanos connector (from DME) ?
Maybe pull the vanos units off and do the beisan vanos procedure , dont know if that will help anything
post #16 of 107 Old 13th November 2016, 10:35 AM
Sailor24
Sailor24's Avatar
You know the boards are good? You have activated them with a 9v battery and click crisp and all the same? Assuming yes, you might want to check the oil flow out of bank 1 and compare it to bank 2. You do that by taking the drain hose and run it to a bottle instead of the pan.
Next or before see if the piston will move in all the way, you have to push hard and rotate the engine at the same time. Could be the splines are screwed and the piston is limited in its movement.
I had one like yours and thought it was the piston seal but when I switched boards I got different results on the valve timing. With one board I had a small advance/retard but with the other board it was maxed out. If an inlet is leaking the outlet will stay open to allow for that but if the outlet leaks badly then there is no hope to keep oil in there. When you switch boards what was intake becomes exhaust and inlets become outlets.
Piston seals do fail but not often and what you are seeing does look like the seal is letting oil past it. If that is true you will get no oil out of the drain tube because it is blowing by the seal and getting to the pan that way.
The Following 2 Users Say Thank You to Sailor24 For This Useful Post:
vallibirgiss (13th November 2016)
post #17 of 107 Old 13th November 2016, 07:13 PM Thread Starter
vallibirgiss
Sailor24: Hmm i will go and try that but when you say "drain hose" do you mean the overflow hose (see pic) ? Won't there be alot of pressure?
Also you say to see if the piston will move , do you mean that i open the piston covers and try to push the pistons with my hand while someone turns the engine?
post #18 of 107 Old 16th November 2016, 06:25 AM
Sailor24
Sailor24's Avatar
I will suggest you search for some of 68fb posts on this. I am just going on memory and parroting what he said since he is not here to say it again.
There is not much pressure on the out from the vanos. The pressure will only be there when the solenoids outlet is active. It should not be active at idle except for an initial adjustment. The solenoids don't operate constantly, they adjust then do nothing until the next adjustment.
post #19 of 107 Old 17th November 2016, 04:58 AM
manualshifter
manualshifter's Avatar
Originally Posted by Sailor24 View Post
My bad. I re read your first post and got it wrong the first time.You replaced a CPS and switched it side for. Then you swapped the boards side for? Through all this the code has remained the same? You have cleared the codes in between? I assume yes.
Could be hydraulic but finish checking the wiring first. There is this strange ground fault, it is located in the injector wire housing, but you need not go there just jump a wire to the grounds of the boards. A temp wire with a couple of alligator clips. Find a good/easy bolt and clip there then to the ground wire on the board. If no change then think hydraulic.
If it is hydraulic with that code it would be piston seals failed, unusual but there is a kit for it. Many posts on the system, I have no experience with it. In all the cars I have seen I have never seen anything but board failure.
If you want to read about the failure. It was first posted by one of the Aussies put vinegar in your search as this is how he cleaned it. Sorry don't remember who but the Aussies like to start their names with M5.
That was me, 12 Jan 2015, thread was "Vanos codes and rough running after new board"
Had to strip injector harness to chase a short in the earth to the DME, was a connector in the harness gone bad..
Allan
manualshifter is offline
post #20 of 107 Old 17th November 2016, 07:19 AM
ard
ard's Avatar
Scary huh....
yes, an Aussie. No name didnt start with M5.
ard is offline
B8 (Intake camshaft VANOS position control" VANOS Passes All Tests thekurgan E39 M5 and E52 Z8 Discussion 12 15th November 2015 09:32 PM
Vanos exhaust position control and exhaust retard valve technician117 E39 M5 and E52 Z8 Discussion 10 31st October 2014 01:54 AM
Exhaust camshaft VANOS Position control, Cly #5-8 mubarak E39 M5 and E52 Z8 Discussion 8 18th September 2014 01:39 PM
Code b9 "Exhaust Camshaft 1Vanos Position Control murph550 E39 M5 and E52 Z8 Discussion 3 28th January 2009 03:02 PM
Is it safe to drive the M with an Intake Camshaft Vanos Position Control Error? Stickman E39 M5 and E52 Z8 Discussion 6 29th June 2006 12:51 AM
