B9 , Exhaust camshaft Vanos position control - Page 11 - BMW M5 Forum and M6 Forums
 4Likes
post #101 of 107 Old 1st July 2019, 04:14 AM
dvldo
dvldo's Avatar
Hi Everyone, just wondering if this was ever resolved. I've read through probably all of the VANOS related thread and cannot seem to find a resolution for my car. I'm getting similar symptoms for code 72. Swaped boards, resoldered all joints, replaced diodes, replace solenoid rings, beisan rings, cleaned all ports on the VANOS unit itself, and installed new CPS (all 4). I'm still reading error 72. One thing I still have not done is swap the VANOS units. Just wondering if there is anything else I should check. Thanks. This is driving me crazy.
dvldo is offline
post #102 of 107 Old 1st July 2019, 07:05 PM
Sailor24
Sailor24's Avatar
They have all been resolved but most are different. You no results or any change from doing the things you have done? It is a bad ground then. In the electric conduit right over the fuel rails is where the grounds for the vanos solenoids join, check that.
Sailor24 is offline
post #103 of 107 Old 1st July 2019, 07:24 PM
dvldo
dvldo's Avatar
Thanks, Sailor. I just read that from another post last night. I will check that when I fine the time and report back. That sounds like it could be the issue. Yes, no results from everything I've done so far.
dvldo is offline
post #104 of 107 Old 7th July 2019, 09:10 PM
dvldo
dvldo's Avatar
I finally had time to check the ground leads on Bank 2. Looks like there's some corrosion which I'm currently soaking in vinegar. I check the resistance on all the pins and they seem kind of odd.
Bank 2(key off):
Pin 1 is 3.8koms
Pins 2 and 5 are both reading about .8kohms,
Pin 4 is 8.5kohms and 6 is 8.6
Pin 3 is 216.9kohms??
Bank 1(key off):
Pins 2 and 5 are .5kohms
Pins 1, 3, 4, and 6 are all around 8.5
Would a bad ground cause the high resistance reading for B2/Pin 3? I checked the voltage with key on and B2/Pin 3 shows 70mV and Pin 1 58.1mV. comparing with B1, readings show 1.1mV.
dvldo is offline
post #105 of 107 Old 7th July 2019, 09:11 PM
dvldo
dvldo's Avatar
dvldo is offline
post #106 of 107 Old 7th July 2019, 09:53 PM
dvldo
dvldo's Avatar
I traced the high resistance reading from pin 3 all the way to the DME. The high resistance reading isn't from the wiring, I think it is coming from something inside the DME box. Checked resistance from where the Pin 3 wire connects to DME (DME side) tground is the high resistance reading comes from there. Should I open up the DME and take a look or is this a sign I need to replace it? Now I'm worried.
dvldo is offline
post #107 of 107 Old 7th July 2019, 10:27 PM
dvldo
dvldo's Avatar
Jumped the gun... Took a look inside the DME box and found a fried chip(BTS621L1). I guess I'll order one and have someone at work solder it in. I guess we'll see what happens.
dvldo is offline
B8 (Intake camshaft VANOS position control" VANOS Passes All Tests thekurgan E39 M5 and E52 Z8 Discussion 12 15th November 2015 09:32 PM
Vanos exhaust position control and exhaust retard valve technician117 E39 M5 and E52 Z8 Discussion 10 31st October 2014 01:54 AM
Exhaust camshaft VANOS Position control, Cly #5-8 mubarak E39 M5 and E52 Z8 Discussion 8 18th September 2014 01:39 PM
Code b9 "Exhaust Camshaft 1Vanos Position Control murph550 E39 M5 and E52 Z8 Discussion 3 28th January 2009 03:02 PM
Is it safe to drive the M with an Intake Camshaft Vanos Position Control Error? Stickman E39 M5 and E52 Z8 Discussion 6 29th June 2006 12:51 AM
