02 M5 Ignition, key, steering lock issue - BMW M5 Forum and M6 Forums
post #1 of 7 Old 25th June 2016, 05:50 AM Thread Starter
ssclassa80
I searched plenty and found many threads with different symptoms to mine.
One day my key won't go in and I notice a metal flap blocking it's entry. I immediately notice that the steering wheel not only isn't locked, but it won't lock at all no matter how far I turn it in either direction.
I forced the key in it started right up. I then pulled the key out halfway and cleaned and lubed the lock assy. Now the flap is open and I can get the key in with a wiggle. It' is tighter sliding in than it used to.
The steering still will not lock with the key out. I'm not sure where to start. Steering lock assy? I really hope I don't need a new tumbler and new keys etc...
ssclassa80 is offline
post #2 of 7 Old 25th June 2016, 10:26 AM
Sailor24
Sailor24's Avatar
Sounds like the lock. Instead of going to BMW go to the local locksmith they can fix most things.
Sailor24 is online now
post #3 of 7 Old 25th June 2016, 11:02 PM Thread Starter
ssclassa80
Thanks for the advice, I will do that first.
Does anyone have any insight on what mechanism locks the steering wheel?
post #4 of 7 Old 26th June 2016, 02:24 AM
Sailor24
Sailor24's Avatar
It comes out of the lock assembly and for a lack of better word I will say pin, but it is larger. That inserts into a slot in the column.
post #5 of 7 Old 26th June 2016, 02:42 AM Thread Starter
ssclassa80
So if I replace the lock assy I can keep my stock keyset and tumbler?
post #6 of 7 Old 26th June 2016, 05:49 AM
Sailor24
Sailor24's Avatar
Hard to say the tumbler is a cylinder that activates and interacts with the other parts. Hard to know until it comes apart. It is probably something like a spring or something that can be fixed. The tumbler is separate to the mechanism. Make sure you use all of the original electric parts like antenna.
post #7 of 7 Old 14th May 2019, 04:14 PM
BenHalima
Thanks you solved half my problem, would surely go nearby locksmith md.
BenHalima is offline
Ignition lock issue gregcagle E39 M5 and E52 Z8 Discussion 4 7th May 2015 01:19 PM
requires locksmith -want to change my ignition lock of BMW m5 1994 ipMdycguir E34 M5 Discussion 1 29th January 2013 12:22 PM
Ignition Switch or Lock Blitzkrieg Bob E34 M5 Discussion 19 30th May 2011 07:06 PM
Battery drain if key in ignition, not an FSU issue kevin711 E39 M5 and E52 Z8 Discussion 2 8th February 2011 06:02 PM
E28 M5 how to reduce lock to lock steering Buttocks E28 M5 Discussion 0 12th June 2007 05:09 AM
