Rod bearing replacement cost and labor units - BMW M5 Forum and M6 Forums
 4Likes
post #1 of 27 Old 24th June 2016, 05:22 AM Thread Starter
lawrence1
lawrence1's Avatar
Hello,
I've been on this board for a while but never really posted much. I do enjoy reading your guys' posts and it appears that there's a lot of knowledge here, which is something i appreciate greatly. I've owned several M3s before, including a couple e46 M3s so i am familiar with similar vintage BMWs, as well as cars in general. To make a long story short, I just bought an 03 with 106k and am doing some work on it to catch up on maintenance. Since i plan on keeping this car for a while, i thought i'd do the rod bearing replacement preventatively.
I called a few NorCal indy shops and was a little shocked at the labor cost for this job ... the lowest quote i got was $2,000 with me providing all the parts. The highest was $3700 from Performance Technic, which i thought was out of line for this work, although it did include parts.
I remember reading posts where members were paying around $1500 for this job in the past so i wonder if the above quotes are reasonable or if i should keep looking.
Is there anyone in or around NorCal or SoCal that knows of a place or fellow member that offers better rates for this job amd is qualified to do it properly?
Your help is appreciated!
lawrence1 is offline
post #2 of 27 Old 24th June 2016, 05:29 AM
mgdmb
mgdmb's Avatar
It's roughly 11-13 hours, depending on the shop. Bearing prices have gone up a fair amount in the past few years, too. So, 2,000 isn't out of line, although 3700 is (PTech is a very well respected shop, but that's insane...)
mgdmb is offline
post #3 of 27 Old 24th June 2016, 05:37 AM Thread Starter
lawrence1
lawrence1's Avatar
Yeah, i am familiar with PTech as i took my e46 m3 there for some work a couple of years ago. I was just shocked at their quote ... a used S62 with decent mileage can be found for $4K nowadays :-)
I'd be interested in hearing from others on the west coast that have had this done.
post #4 of 27 Old 24th June 2016, 05:39 AM
mgdmb
mgdmb's Avatar
I've had it done, I paid ~1700, but that was 4-5 years ago (BRRacing in Los Gatos did the work)
@TheShafro - Have you taken this job on yet?
mgdmb is offline
post #5 of 27 Old 24th June 2016, 07:20 AM
thekurgan
thekurgan's Avatar
I've heard good reviews for European Sports Car Garage on 16th. I'd be curious as to their quote.
Ilse: 2002 E39M5 / TiAg / Tubi Rumore Stg 2 / E60 shifter / PowerFlex / Intravee II / KCA-420i / Jim Blanton 40% 3.45 diff / NCS coding / StrongStrut STB / Coby Alcantara wheel, shift and e-brake / Rogue Tranny Mounts / Mk IV / RK Plenum Plates
Bruna: 2000 E36/7 Z3 / Schwartz / RE RSM / NCS coding / M3 FCABs
BMWCCA #453648
"We're surrounded. That simplifies our problem of getting to these people and killing them." ó Lewis B. "Chesty" Puller
thekurgan is offline
The Following User Says Thank You to thekurgan For This Useful Post:
mgdmb (24th June 2016)
post #6 of 27 Old 24th June 2016, 07:35 AM
ard
ard's Avatar
I do virtually all mine own work, but have two recommendations:
Ive had work done once at Valley Motorwerks, (Walter) they are a member hear but haven seen them post in quite some time. Helped with a very very tricky diagnosis once. They are in Rancho Cordova, by whiterock and sunrise
I have work done on the Porsche at IBP-autosports- had to drop motor+trans, remove heads, reweld all 8 coolant fittings. Id never done it so had them do it. Ron is the guy there. Downtown Sacto
I trust there skills, cannot speak to their costs.
ard is offline
post #7 of 27 Old 24th June 2016, 11:51 AM
Sailor24
Sailor24's Avatar
You should do a search there was a very complete thread on this. Off the top of my pointed head $1200 for parts and 12 hours at $110 that is the best or worst part of $2500 but I think most of the quotes were $3000. I don't really remember maybe it was a Euro thread.
Sailor24 is online now
post #8 of 27 Old 24th June 2016, 06:56 PM Thread Starter
lawrence1
lawrence1's Avatar
Ron at IPB came in with the $2k quote. I have yet to call Valley motorworks but i wilk do so soon.
Thanks for your help. How many miles are on your car, ard? Are you contemplating getting this done? I'm just curious.
post #9 of 27 Old 24th June 2016, 06:57 PM Thread Starter
lawrence1
lawrence1's Avatar
Thanks Sailor, i did and thats why i was surprised ... the labor quotes i got were much higher.
post #10 of 27 Old 24th June 2016, 07:35 PM
gsfent
gsfent's Avatar
Isn't there a "shortcut" method by dropping the oil pan? That might explain the difference in labor quotes. If the shop knows enough about the shortcut, they are probably pretty familiar with the M5 and rod bearing replacements.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps and crossovers and sub and speakers).......
gsfent is offline
Currently Active Users Viewing This Thread: 7 (4 members and 3 guests)
Jose Rivera , DaveinGigHarbor , Bojangles , caslvre39
E60 M5 connecting rod bearing replacement - cost? dcer10 Australian Forum 1 5th September 2017 05:33 AM
labor hours rod bearing budylajoie E60 M5 and E61 M5 Touring Discussion 9 17th November 2014 03:42 AM
Rod bearing replacement euro46 E39 M5 and E52 Z8 Discussion 57 4th April 2014 04:33 AM
ROD bearing replacement rneedham1979 E39 M5 and E52 Z8 Discussion 17 22nd March 2008 05:26 AM
Flex Disk replacement labor cost JML M5 E39 M5 and E52 Z8 Discussion 11 23rd November 2007 11:44 PM
