Perceptions on your SC'd e39 performance... - Page 2 - BMW M5 Forum and M6 Forums
 15Likes
post #11 of 25 Old 13th May 2016, 06:11 PM
Thumper600
Thumper600's Avatar
Got to thinking about your question and remember now it was a 34/11 gear ratio, (3.09 vs 3.36 in the stock 600cc M.C.) in the motorcycle that made all the difference in the world. What I am trying to say is that gearing should make all the difference in the world. My 95 SC 540i pushes 414 ponies with a 3.15 LSD diff and feels just right. My 01 M5 pushes 400 ponies, has the 3.15 LSD diff and feels not quite as "brutal" in the power delivery area but then again its a noticeable "motoring down the road" experience all together. Perhaps you should consider a taller rear end ratio in that I'm "playing" with 400 ponies whereas you are probably at the 560 mark. So if you can find an inexpensive 3.15 LSD try it out, you may want to opt for something in the 2.90 range. Please keep us posted as to the "seat of the pants" experiment.
Thumper600 is offline
post #12 of 25 Old 13th May 2016, 06:13 PM
Thumper600
Thumper600's Avatar
Because I am of the opinion that those "words" are really "subjective" Chuffy
post #13 of 25 Old 13th May 2016, 11:46 PM
Zero_Cool
Originally Posted by chuffykow View Post
It's quick as ****. What have you been driving, aside from your E39 ?
Dude what part of elgin? I used to live off 20 and Randall before I moved down to Tn. I visit my parents place in that area often. Maybe we could meet up sometime this summer, I would love to get a feel for a SC M vs my stocker.
Sorry op, prooceeed
Zero_Cool is offline
post #14 of 25 Old 13th May 2016, 11:48 PM
chuffykow
Sorry op, prooceeed
I'm basically 20 and Randall as well. PM Me and we can figure out a time/place to meet up next time you're in town.
2002 ///M5 Chiaretto Red/Caramel
  • Handling: DINAN Stage 2 Suspension / Front Strut Tower Brace
  • Performance: Evolve stage 2 S/C with billet aluminum plenum / Aeromotive 11140 / Tuning by Frank Smith
  • Ear candy: DINAN Free Flow Exhaust / Intravee II / KCA-420i / 30GB iPod
  • Eye candy: 20% 3M Ceramic / Opti-Coat 2.0 by mzarif / Technical Graphite trim / Storm Motorwerks products / Nappa shifter / Slimmbones armrest
chuffykow is offline
post #15 of 25 Old 14th May 2016, 06:54 PM
gsfent
gsfent's Avatar
Before my recent tune I was putting down something north of 450 at the wheels. I have MUCH taller gearing. I could break the tires loose on a hard 1-2 shift. The backend would step out a little bit. I generally don't get on the car hard until 2nd and 3rd is the real money gear.
I have good Mich PSS. So it is very possible there is some issue.
When the ESS kits first came out, many of us had the intake tubes collapsing. Felt like a boost leak and car felt slow. You accelerated great and then about half way through, it just didn't accelerate hard anymore. Once that was discovered and fixed, car felt completely different.
With 3.62 gears, 1st should be close to useless. It should hit redline so fast that you have to be on top of it or you will hit the rev limiter. if not, I suspect there is some issue to be dealt with .
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is online now
post #16 of 25 Old 15th May 2016, 11:08 PM Thread Starter
Matt B
Matt B is offline
post #17 of 25 Old 16th May 2016, 05:58 AM
Blockdoc
Blockdoc's Avatar
Agreed! To the OP...Do you have a boost gauge?
It would be helpful to see if you have developed a leak.
Secondly...
I just last week replaced my IAT sensor (the one in the discharge tube). It had apparently gone bad and was reading a constant 140 degrees regardless of actual temp. I noticed a SIGNIFICANT increase in performance after replacement (I assume the ECU was "seeing" 140 degrees even when cool?)
2003 Sterling Grey M5 SOLD
ESS kit #1 with RK AUTOWERKS Upgrade! (RK/EVO software, Injectors, Fuel Pump)
Dinan Free Flow Exhaust, Dinan Rear Sway Bar
Super Sprint Headers
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around)
Aquamist HFS3/Howerton Engineering Tank (pre/post SC nozzles)
RK Autowerks CNC Plenum Plates
2015 M4 Coupe DCT (BootMod flash Custom Paul Johnson Tune, downpipes, Methanol 100 percent , E30 map, Pure Turbos 700WHP+, 295/275 tires with Vorsteiner wheels)
2018 Jeep Hellcat Trackhawk (707HP Supercharged)
Blockdoc is offline
post #18 of 25 Old 16th May 2016, 07:08 AM
herrubermensch
With 3.62:1 gears in the rearend AND a supercharger, you should be shredding first and second gear and thinking about starting in third gear. You definitely have an issue.
--Peter
herrubermensch is offline
post #19 of 25 Old 16th May 2016, 03:41 PM
Blue Thunder
I agree, always having traction issues.
Here is a scientific comparison between SC and stock, both cars blue to keep it accurate:
1999 M5 Avus Blau Metallic
Twin Rotrex superchargers, Front mount intercooler, Steel sleeved block, Forged CP pistons, 10.5:1 compression, SS Headers, SS race cats, TUBI Rumore, UUC 11" V12 cerametallic clutch + flywheel, UUC EVO3 SSK w/DSSR, Brembo GT4 brakes front/back, KWv3's, Angel Eyes + Angelibrights, Celis, 19" Hamann PG2´s, Strongstrut front Strut Brace, BMW fire extinguisher, Dynawin headunit, CF interior trim
1989 E30 M3 White - track toy
S85B50 with M-DCT - 560+ hp, 1300kg rocket for the Ring being built
https://www.m5board.com/vbulletin/e6...ct-e30-m3.html
Blue Thunder is offline
post #20 of 25 Old 17th May 2016, 12:48 AM Thread Starter
Matt B
Matt B is offline
E39 M5 Performance Modifications FitForFives E39 M5 and E52 Z8 Discussion 18 31st July 2008 11:41 PM
Performance Graph M5 E39 Gabriel343 E39 M5 and E52 Z8 Discussion 6 14th January 2007 06:31 PM
Performance 850CSi vs E39 M5 Frits E31 850 CSi and E24 M635 CSi 2 14th January 2006 05:01 PM
FS: E39 M5 performance goodies MAD KAO Parts / Other For Sale or Wanted 15 24th October 2005 06:30 PM
OT: car perceptions now and before. Your opinion, please Magna E39 M5 and E52 Z8 Discussion 3 5th March 2002 07:03 AM
