Bilstein B8 Ride Height/Spring Info - Page 9 - BMW M5 Forum and M6 Forums
 23Likes
post #81 of 83 Old 15th February 2019, 10:05 PM
CSBM5
CSBM5's Avatar
It would appear that the rear lower perch location is not M5 compatible. Does it have a ring that you can relocate like the Konis do? Measure the stock location from lower eye to ring and set it there if possible.
Current stable:
CSBM5 is offline
post #82 of 83 Old 16th February 2019, 03:11 AM
austrianvespaguy
austrianvespaguy's Avatar
I think this is basically the crux of it. The spring perch ring is unfortunately not adjustable. I measured it against the stock damper when I first got it out and thought I took pictures but now I can't seem to find them. In any case, if I remember correctly I only measured a 15mm difference between the two. I think once I drive the car around for a bit it will settle down some and end up closer to this 15mm increase rather than the 25mm increase that I measured right after installation. Let the spring seat itself into the new pads, the pads into the top mounts, and so on. Will measure again in a few weeks!
austrianvespaguy is offline
post #83 of 83 Old 20th February 2019, 01:36 AM
a_ok2me
a_ok2me's Avatar
a_ok2me is offline
Ride height after H & R spring install stevezx900 E60 M5 and E61 M5 Touring Discussion 25 28th August 2013 09:04 AM
ride height ! leosbimmer E60 M5 and E61 M5 Touring Discussion 9 28th July 2011 07:53 AM
Ride height imbalance M5Doctor E60 M5 and E61 M5 Touring Discussion 6 24th June 2010 01:57 AM
ride height help! SyncmasterM5 E60 M5 and E61 M5 Touring Discussion 21 15th May 2009 06:42 AM
Ride height Boz M5 E39 M5 and E52 Z8 Discussion 1 20th April 2005 11:30 PM
