Rear Wheel Bearing Noise - BMW M5 Forum and M6 Forums
post #1 of 7 Old 4th March 2005, 08:05 PM Thread Starter
Bob Uenaka
Bob Uenaka's Avatar
I am hearing a low howling noise at about 20 mph that seems to be getting progressively worse. The sound does change slightly in pitch as the car is turned left to right at 20 mph. My mechanic checked it out and found a very slight amount of play in the LR wheel so he suspects it's a bad wheel bearing.
Has anyone experienced this type of problem? Any suggestions as to what I should look for other than the wheel bearing? The car has about 35k miles.
Thank you!
Bob
'00 Silverstone/Black with Bruyere Club wood trim.
Dinan exhaust & stage II suspension, Nav TV in motion & VR, BBS RKII rims w/polished lips, 255/35-18 & 285/35-18, HID fogs, clear corner angel eyes with Umnitza LED's, Rogue transmission mounts, ceramic brake pads, brake ducts, BeastPower swaybar brackets, Euro arm rest.
Bob Uenaka is offline
post #2 of 7 Old 5th March 2005, 01:19 AM
blk540
blk540's Avatar
Re: Rear Wheel Bearing Noise
I have the same play in my rear of my 540i 6-spd, but there isn't any noise present. I do not know if the play in the rear is normal. My best guess is to check with BMW.
blk540 is offline
post #3 of 7 Old 5th March 2005, 01:47 AM
mottati
mottati's Avatar
How are your rear tires looking Bob? I had some worn rear tires that sounded like bad bearings at about the same speed.
94 M5 Touring Madeira Schwarz, Black 10/93 production
84 728i - M88 powered
mottati is offline
post #4 of 7 Old 5th March 2005, 04:09 AM
Mvious
Mvious's Avatar
Check the for sale section and member ALEV8 is selling wheel bearings.
Marion
Marion
ACS Roof Spoiler
Tubi Style Cat Back Exhuast
Custom Painted HRE 549 19x9 front 19x10.5 Rear
UUC Evo III SSK & DSR
UUC Transmission Mounts
UUC Direct Fit Clutch
Supersprint Headers and Connecting pipes
Active Autoworks CAI
Discovery Automotive Powerchip 93 software
Lidetak LE-30
Valentine One
Dension Ice>Link:Plus
Beastpower Brackets
Evosport Power Pullies
Stealth-One
Mvious is offline
post #5 of 7 Old 5th March 2005, 05:23 AM
hudson
hudson's Avatar
Thank you!
Bob
Sometimes you might have a small amount of play in the bearings and that doesn't necessarily mean the bearing is bad. A little trick to separate tire noise (like mottati mentioned) from bearing noise is to pump up the tires to about 50 psi and see if the noise changes. If it does then the tires are probably making the noise.
Is the noise in the front or the rear?
Joe
hudson is offline
post #6 of 7 Old 5th March 2005, 07:42 AM
Beamer_usa
Beamer_usa's Avatar
Beamer_usa is offline
post #7 of 7 Old 6th March 2005, 06:34 AM Thread Starter
Bob Uenaka
Bob Uenaka's Avatar
Thanks for all the input. I just replaced my rear tires with Toyo T1-S in size 285/35-18. These are the same tires that I've been on the last 10k miles. Since the last pair only lasted 10k miles and I won't be tracking this car any more, I had the rear camber adjusted from -2.8 to -1.8 degrees. The last pair of Toyos were notably quiet. I did try adjusting the air pressure, but only by 5 lbs and it didn't make any difference. I "think" the sound is coming from the rear.
Strange Noise When Turning Wheel . . . Rcl4668 E39 M5 and E52 Z8 Discussion 3 3rd December 2004 02:50 AM
Noise from rear suspension? shanks E39 M5 and E52 Z8 Discussion 5 17th August 2004 04:46 PM
UPDATE: DINAN 3.45 rear diff. GROUP BUY info/details............... FAST 5 E39 M5 and E52 Z8 Discussion 15 23rd October 2003 04:51 AM
rear tire hitting wheel well GGarai E39 M5 and E52 Z8 Discussion 9 30th November 2002 03:29 AM
