DIY: Supplementary Air Pump (SAP)replacement DIY with pics - BMW M5 Forum and M6 Forums
 6Likes
post #1 of 11 Old 18th April 2016, 12:25 AM Thread Starter
alfanator
alfanator's Avatar
Does your car sound like a jet engine on a cold start for the first 90 seconds? If so it is likely the SAP. Lots of discussion on this topic but no DIY. So here it is. Pretty simple.
Remove the right front wheel and the plastic valance. I have a Dinan CAI, stock is not much different.
This is what it looks like. The black thing next to the air filter.
It is on the front right corner of the car.
In my set up, it is mounted upside down and secured with three small bolts.
Remove the three bolts with a u-joint ratchet. Unplug the wire on top and hose on side.
Look in your garage for another pump. I had one left over from a 2000 that I parted out just sitting there. It was extremely clean and I did not recall a whine before some idiot rear ended me .
Here is a pic of the one I removed. It was funky and the sponge filter clogged with dirt.
Put the working one in. Inverse of how you got the noisy one out.
Turn on the car. Confirm to make sure the SAP is indeed running, because it is so quiet. It sounds like a DustBuster.
Mosey on to the other side, since I have the car up to check out the curb damage I did to the other valance.
Repair damaged balance with duct tape.
alfanator is offline
post #2 of 11 Old 18th April 2016, 03:44 AM
gsfent
gsfent's Avatar
[/IMG]
Do you need the SAP for emissions testing?
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is online now
post #3 of 11 Old 13th February 2019, 12:54 AM
espritv8
espritv8 is offline
post #4 of 11 Old 13th February 2019, 01:01 AM
Ferris
They sell a block off plate, though you have to keep the bank to bank pipe. They also sell a vacuum cap. The rest is removing, the valve, the pump and hosing and flashing a tune.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #5 of 11 Old 13th February 2019, 04:24 PM
espritv8
Still haven't decided to do the delete or not. Just worried It might cause other issues. I already have the shark tune installed from the previous owner (I think for that very reason)
So I've ordered a block of plate with ecs since I had other things to get from them. But some people are stating that I may be an issue to the cats if deleted...
espritv8 is offline
post #6 of 11 Old 13th February 2019, 04:28 PM
Ferris
I'd leave the hardware in place it really don't matter.. If you want to save 20lbs then remove it otherwise once it's tuned out it doesn't matter either way.
The cat's don't care all it does is help heat the cats by pushing more air into them. It runs for 30 seconds or so on cold start and is dormant the rest of the time. The only thing that would be mad if they're gone is the EPA, or the EU people, because you know muh global warming and ****.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #7 of 11 Old 13th February 2019, 04:32 PM
espritv8
Won't it still contribute to fill the heads with carbon deposits if the system is left there? I'm trying to weight the pro's and con's...
espritv8 is offline
post #8 of 11 Old 13th February 2019, 04:38 PM
Ferris
It's gonna happen either way. Here is a pic of the ports in the heads, exhaust valves removed. Basically what happens is the exhaust gases are going to push through the passages in the head and deposit carbon. Blocking off the ports at the end of the head or in cross pipes isn't going to make a difference.
It doesn't matter if they fill up either, minus the emission aspects of it. Tune it out and don't think about it again is my advice.
https://www.m5board.com/vbulletin/e3...-pictures.html
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #9 of 11 Old 13th February 2019, 05:38 PM
espritv8
Well I've just found out that my shark injector does not remove the SAP warning light after all. Some do, but not mine.
So'ill leave it like that and if it lits up someday, I'll tune it out.
Any better options than the shark injector do this?
espritv8 is offline
post #10 of 11 Old 14th February 2019, 03:21 AM
terraphantm
Read the tune with BMWFlash (or your app of choice) and delete codes 13, 3F, AA, and AB. The status will then be set to ready regardless of whether the pump is functional or present.
terraphantm is offline
Water pump replacement DIY vantaam5 E39 M5 and E52 Z8 Discussion 72 18th April 2019 12:00 AM
Deleting the Secondary Air Pump (SAP). Effects on the Beast..... timmay77 E39 M5 and E52 Z8 Discussion 58 24th February 2016 06:52 PM
SAP/Air Pump Relay Location matt0 E34 M5 Discussion 4 6th February 2015 01:14 PM
Secondary Air Pump (SAP) Dissected (Why you'll always buy a new one) Terabass E39 M5 and E52 Z8 Discussion 23 6th April 2011 09:55 PM
DIY Water Pump Replacement - Seriously Disappointed jbeuchert E39 M5 and E52 Z8 Discussion 4 6th September 2009 03:30 PM
