Key Replacement Options - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 26 Old 5th April 2016, 10:12 PM Thread Starter
3mta3
3mta3's Avatar
Spent a long time M5 lurking, finally found one that made sense. Have seen lots of info here about key options as well as some conflicting info on the interwebs. Seller only had 1 key left...and that one appears to be dead or not charging. I did find the reprogram feature and tried it...key on engine off...position 2...pull key out within 5 secs, hold the button etc to program....didn't work! Since I need a spare key anyway should just get a new one from the dealer, or is there another option. They do sell blanks thru locksmiths and interwebs at places but it seems unclear as to how much programming is required and how much or little time would be needed with dealer. Also saw conflicting info on the batteries whether rechargeable or not. Can someone please confirm before I cut this fob open....I also saw a post on this board that the program new key feature works if the fuel filler door actuator is working as it should too. Needless to say I need some advice.
2002 E39 M5 Sterlinggrau Metallic; Full Carmel; MKIV
3mta3 is offline
post #2 of 26 Old 6th April 2016, 12:51 AM
gregcagle
gregcagle's Avatar
My understanding is that you have to go to the dealer. When I got another key I had to do the following:
1) show up with car title
2) Pay anywhere from $160-220 depending on the dealer
3) Wait a day (I read somewhere they have to overnight the key from SC or somewhere)
4) Go back to the dealer so they can do some programming (takes five minutes or so).
Hope this helps.
gregcagle is offline
post #3 of 26 Old 6th April 2016, 01:19 AM
sor118
sor118's Avatar
sor118 is offline
post #4 of 26 Old 6th April 2016, 03:32 AM
SVTforme
SVTforme's Avatar
Hope this helps.
Confirmed - I did this last year. $175 needed title at the dealer and took only a day. I used reprogramming instructions from this site - don't have the link handy though. Just don't lose your new key a month later like I did .
SVTforme is offline
post #5 of 26 Old 6th April 2016, 04:21 AM
gsfent
gsfent's Avatar
Dealer can provide the master key with remote access, a valet key which only works the ignition and a plastic emergency key which is a master. A full set of keys are 4; 2 masters, 1 valet and one wallet emergency key.
When you order your new key(s), have the dealer deactivate any keys no longer in your possession.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is online now
The Following User Says Thank You to gsfent For This Useful Post:
Mike S. (13th April 2016)
post #6 of 26 Old 6th April 2016, 05:00 AM
Rontgen
Rontgen's Avatar
As an alternative, you can buy uncut keys from eBay or elsewhere ($30/pair), have them cut at a local locksmith ($30), and use a device called an AK90+ ($60) to add the new key transponders to the existing EWS. It is absolutely more work and a bigger PITA than buying a new key from the dealer and it really doesn't make sense if you just need one key for one car, but it is an alternative to buying from a dealer.
If you need multiple keys for multiple cars, or you own several EWS I/II/III/IV cars, then an investment in an AK90+ can be worth it. I needed 2 keys for my E46 and may eventually need replacement keys for my E39 and my dad's E85 Z4, so the AK90+ investment seemed worth it.
I will say the keyless entry range on the ebay keys is WAAY better than any OE BMW key I've ever had. Aside from that, they look, feel, and function just like OE keys.
Good Luck!
- Darrell
2001 M5 - Jet Black / Black Sport Interior
Xtrons PB7639BP Android Head Unit - AutoSolutions SSK
Dinan Exhaust - Rogue Engineering Resonated X-Pipe
Bilstein B8 - Intrax Springs - Eibach Rear Sway Bar
1990 325is - Jet Black / Black
Rontgen is online now
The Following User Says Thank You to Rontgen For This Useful Post:
gsfent (6th April 2016)
post #7 of 26 Old 7th April 2016, 07:02 PM
seabass23
seabass23's Avatar
Is it realistic to expect a locksmith to be able to cut the square blade keys? I know of a local autoparts store that claims to be able to reproduce immobilizer keys. All this time, I just assumed that they wouldn't be able to properly cut the blade keys...
seabass23 is online now
post #8 of 26 Old 7th April 2016, 07:41 PM
masri87
Similar position here.
Current key is dying and spare given my PO isn't reinitializing via the steps given.
I took it apart and saw that it wasn't soldered properly. , cleaned it up, resoldered it , gonna wait a few minutes and retry to initialization process. if it fails ill get a new battery and go that route
Questions
"Procedure:
1. Close all doors and have all keys available.
2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
3. Within 30 seconds of turning the ignition switch to “off” Press and hold the arrow button.
4. While holding the arrow button, press and release (“tap”) the roundel button three times within 10 seconds.
5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
7. Switching the ignition to KL R completes the initialisation."
KL R is position 2 correct? right before turning the engine on
masri87 is offline
post #9 of 26 Old 7th April 2016, 09:18 PM
REKIII
REKIII's Avatar
Good Luck!
Is this a typo? The eBay keys have BETTER range? If so, that would make this process a no brainer. However, do you need to find a specialized locksmith to cut the square keys like mentioned above?
2001 Jet Black M5
2012 Black Ford Raptor
2014 Black Jeep Grand Cherokee Summit
2008 Raven R1 - Being disassembled and sold
REKIII is offline
post #10 of 26 Old 9th April 2016, 07:49 AM
Rontgen
Rontgen's Avatar
Nope, no typo. The eBay keys on my E46 work from a considerably greater distance than they do with my E39 (and my previous E46). I wouldn't have guessed that would be the case, but it seems to be the case with both of my eBay keys.
Getting the key cut is the hardest part, not because the cut is particularly difficult but rather because some locksmiths would rather sell you a key of their own (which typically means they order it for you from the BMW dealer). I haven't had an E39 key cut, but in theory at least it should be easier than the E46/E53 since the E39 is cut from the outside rather than the "laser" cut down the middle.
- Darrell
The Following 2 Users Say Thank You to Rontgen For This Useful Post:
REKIII (11th April 2016)
key fob/ key battery replacement cah155 E39 M5 and E52 Z8 Discussion 2 7th March 2013 09:28 PM
key fob/ key battery replacement JohnnyP420 E39 M5 and E52 Z8 Discussion 3 20th March 2010 06:01 PM
Key Programming Options Johnny D E39 M5 and E52 Z8 Discussion 6 15th March 2002 01:27 AM
key memory options Bluewater M5 E39 M5 and E52 Z8 Discussion 4 23rd October 2001 04:39 PM
Key Program Options Brian R E39 M5 and E52 Z8 Discussion 5 15th July 2000 10:52 PM
