Secondary air pump temporary delete - Page 4 - BMW M5 Forum and M6 Forums
 11Likes
post #31 of 65 Old 23rd March 2016, 11:36 AM
omgroffles
omgroffles's Avatar
Originally Posted by mgdmb View Post
It works via software for sure, but the only monitor that can be not ready now is the EVAP system. No more 1 or 2 depending on model year. Changed for 2015.
Hey M
Are you basing this off of new info since we last chatted? I'm still getting Not Ready for my SA monitor.
Originally Posted by Rontgen View Post
I believe that mine still shows SAP ready, but I don't have the pump itself disabled - just the AA code itself. My pump still runs, and the O2 sensors report readings would typically trigger the AA low flow fault code. Deleting the AA fault code means that the DME never triggers the AA fault condition that would in turn deactivate the emissions ready status.
Do you mind sharing more details?
On a stock tune do you pull a SA error code and a SES light? If you pull an error code on stock, and if those codes are now gone with your edit, do you have a scanner to confirm if the monitor shows as Ready or Not Ready? I followed this thread which disables the SA pump altogether.
I have no SES or error code but I still get a Not Ready, the pump doesn't turn on at all on cold starts. How do you delete the fault code without fully disabling the pump and deactivating the emission ready status?
OP as far as I know, the DIY method commonly referred to deletes the error code and SES, but shows as Not Ready. Sounds like this will work just fine for you in your state. And for those of us with emissions, any guidance for coding a Ready status would be extremely helpful.
omgroffles is offline
post #32 of 65 Old 23rd March 2016, 04:06 PM
Rontgen
Rontgen's Avatar
Sure, let me look today and take some screen shots of my Emissions Readiness. I could be wrong about the readiness status - admittedly it's not something I keep an eye on at all since it doesn't really matter here but, I'll post back later this morning with some more concrete info.
- Darrell
2001 M5 - Jet Black / Black Sport Interior
Rontgen is offline
post #33 of 65 Old 23rd March 2016, 08:40 PM
Rontgen
Rontgen's Avatar
Screen shot of my emissions readiness. My car would trigger the AA code (low secondary air flow) occasionally, so I suspect my blockage is on the threshold of the system's tolerance. I selected CA Emissions standard for 2000+ gas powered vehicles, which I assume is correct. The red Xs represent monitors which aren't applicable to our cars.
All I did was delete the AA code from the program space, which is what p0lar has described in this thread: DTC (OBD Error Code) Deletion/Removal Strategy - BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
- Darrell
Rontgen is offline
post #34 of 65 Old 23rd March 2016, 11:11 PM
mgdmb
mgdmb's Avatar
Hey M
Sorry, I haven't had a chance to jack around with this. Been interviewing, but should have time on the weekend to reflash and see how long it takes to set ready...
mgdmb is offline
post #35 of 65 Old 24th March 2016, 06:57 AM
omgroffles
omgroffles's Avatar
Thanks for the screenshot Rontgen. I wonder if your pump / ports being on the verge of failure is the reason why it shows as ready. Mine gets the SA trouble code reliably, and so far when I've coded it out I've come up with Not Ready.
So I'm guessing you used a hex editor and not the MSS52 Bin Mod Tool ($30)? Thanks for the link, there are 4 methods there, which one did you use?
No worries at all. I was just wondering if you learned something new because from my own experience, getting the SA to show Ready hasn't been straightforward yet.
post #36 of 65 Old 24th March 2016, 04:08 PM
Rontgen
Rontgen's Avatar
You're welcome! That's a good point - my car may not be the ideal test mule since it didn't reliably trigger the AA code. However, further down in that DTC deletion thread, it does talk about emissions readiness and it sounds like others have had luck with getting a ready status.
I did use a Hex tool, but the Bin Mod Tool wasn't available at the time. Nowadays, I think the few dollars for the Bin Mod Tool is well worth it.
I don't have my garage laptop with me right now, so I can't verify for sure but I believe I used the first method. It sounds like others have had luck with the method hat zeros everything out.
Best of luck!
- Darrell
Rontgen is offline
post #37 of 65 Old 31st March 2016, 04:00 PM Thread Starter
xrviz
xrviz's Avatar
In the FWIW department, Wiki indicates two benefits of secondary air injection. One is for helping burn the rich exhaust during open loop at cold startup. This is typically done with air injection upstream, at the exhaust ports, as is the case with the S62.
The other use is for aiding in the catalytic conversion process during normal running and is usually done with air injection downstream just in front of the cats (as with Sailor's reroute).
Thing is, the way the ECU is programmed, the pump only runs at cold startup. So injecting air downstream will likely only minimally aid in burning the rich exhaust at startup. The main benefit I see would be getting rid of the AA code.
Obviously it would be much easier to just code it out.
xrviz is offline
post #38 of 65 Old 2nd September 2016, 08:09 AM
///Munchen
Bringing back an old thread rather than starting a new one. ... I figure anyone knowledgeable on the system will be here anyway.
I have built myself a SAP Simulator and have been driving a couple days... No pending codes, no CEL.... but the monitor has not cleared yet. The SAP triggers on cold start but (lovely Los Angeles) that has never been below 75* ambient temp.
I have read that the system can throw a fault on a cold start but needs a COLD start (60* or less ambient and coolant?) to pass the monitor... does anyone know this to be the case?
The reason I am trying this route is that I have spoken to 2 different smog techs saying if they see an "unavailable" SAP monitor with a SAP on the emissions diagram its an automatic fail.
Thanks in advance.
///Munchen is offline
post #39 of 65 Old 2nd September 2016, 06:10 PM
mgdmb
mgdmb's Avatar
Just code the monitor out so it's always ready and be done with it. You'll need to leave the SAP hardware in place if you want to pass visual though...
mgdmb is offline
post #40 of 65 Old 3rd September 2016, 07:33 PM
TurboHugh
TurboHugh's Avatar
PM sent
Me too please ...
Sent from planet Earth
2003 M5 Sterling Gray Metallic
BMWmregistry.com Member # 13792
NccBmwCCA Member # 5339
TurboHugh is offline
RK s2, secondary air pump delete piotrekm5 E39 M5 and E52 Z8 Discussion 4 1st August 2014 12:42 AM
Secondary air pump delete broster E39 M5 and E52 Z8 Discussion 10 19th March 2013 01:00 AM
Secondary air pump code still comes up after replacing the pump.. greekspeed E39 M5 and E52 Z8 Discussion 23 28th February 2011 02:47 PM
New pre cat 02 sensors, secondary air pump, mafs, fuel pump and filter = 1 happy S2!! madyspop E39 M5 and E52 Z8 Discussion 0 12th February 2011 04:37 AM
Temporary fix for Secondary air flow codes! jt2ma71 E39 M5 and E52 Z8 Discussion 5 9th August 2010 12:18 AM
