Possible to read codes with engine removed? - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
post #11 of 25 Old 14th January 2016, 04:51 PM
68FB
Interesting. Your UK e-box layout is very different from the North American one I have. Looks like you have two separate processors with covers on each. The NA one looks likes below, with one processor.
RealOEM reflects this, with UK models showing a basic DME AND a programmed DME.
Doesn't make any difference to your situation as far as I can see, just curious about the two processors.
The module 1 connector on top of the DME with the heavy red and brown wires in it is the main power supply to the DME. If you disconnected that one, I don't think you will have any power to the DME.
Malcolm
68FB is offline
post #12 of 25 Old 15th January 2016, 12:30 PM
liquidsmoke
Hmm. I'm 90% sure my UK car only had 1 DME when i changed the ebox fan last year... in fact im 99% sure.
What year is your car?
liquidsmoke is offline
post #13 of 25 Old 15th January 2016, 12:38 PM Thread Starter
putty_thing
That's not my car in the picture, it's just something I found on the Interweb to illustrate my point. Car is a 2001.
I've found I do actually have a picture from my disassembly but it's not perfect:
putty_thing is offline
post #14 of 25 Old 18th January 2016, 09:42 PM Thread Starter
putty_thing
To update: it didn't work - INPA timed out trying to talk to the ECU.
I'm guessing the main power feed in this case comes from the engine bay, with just data lines going back into the car.
Pic:
post #15 of 25 Old 18th January 2016, 10:10 PM
68FB
Two of the pins in the OBDII connector come from module 4 of the DME. Is that the one you have connected? I suspect you also need module 1, with the heavy red, brown and white wires connected.
Malcolm
68FB is offline
post #16 of 25 Old 18th January 2016, 11:11 PM
GreenM5
Got to be sensor related. Good job getting the motor out!
Driveway history:
E39 - 1999 M5 - Oxford Green with carmel interior - current
E38 - 1997 750iL - Black with black interior
E46 - 2002 330i Convertible - Gold with gold interior
GreenM5 is offline
post #17 of 25 Old 18th January 2016, 11:39 PM Thread Starter
putty_thing
Malcolm
The only thing I've got connected is the one bit of loom coming from the car, looks like all the rest is part of the engine loom. I'll attempt to connect that lot back up over the weekend and see how I get on.
I'm not sure how the parts of the module are numbered, but I've got the 4th from the right (in my picture) connected?
post #18 of 25 Old 18th January 2016, 11:43 PM Thread Starter
putty_thing
Found this picture: http://wiki.obdtuning.com/images/thu...BMW_MSS_52.jpg
So looks like I do indeed have #4 connected, and that power comes in on #1 like you said @68FB .
post #19 of 25 Old 19th January 2016, 12:54 AM
Sailor24
Sailor24's Avatar
Sailor24 is offline
post #20 of 25 Old 19th January 2016, 01:05 AM Thread Starter
putty_thing
Trying to read codes with INPA Fuddy E60 M5 and E61 M5 Touring Discussion 8 10th July 2012 11:58 AM
Read fault codes right on your cluster russap5 E39 M5 and E52 Z8 Discussion 22 16th May 2012 03:21 AM
Can't read codes.......... ///Mangler E39 M5 and E52 Z8 Discussion 5 30th November 2009 03:13 PM
Just read my codes.. Hakon E39 M5 and E52 Z8 Discussion 0 13th June 2009 11:46 AM
CEL codes read! 6 Of Them*Please help * isellbeachhomes E39 M5 and E52 Z8 Discussion 8 3rd January 2006 04:35 PM
