US Spec to Euro Spec 2003 Headlight Redo (DJ Auto Lenses) - BMW M5 Forum and M6 Forums
 13Likes
post #1 of 18 Old 1st January 2016, 08:46 PM Thread Starter
Dking078
Dking078's Avatar
I felt it would be a bit worthwhile to cross post this since alot have inquire about using DJ auto lens on their cars.
I had received some US spec headlights for experimenting. Lenses were trash and adjusters were long gone, in addition to being 2003 permasealed, not much hope was out there for them aside from a nice looking trash can or $$$ in repairing and cross country shipping .
Lo and behold, they fell into my lap and i decided to see what crazy things I could do.
The plan for these lights was DJ auto euro spec lenses and new adjusters, along with a butyl based sealant so they can be baked open in the future if desired.
Overall the project was a success, right now I have them on the car for rain / moisture testing of the sealant. As for the DJ auto lens itself, I'd give it an A- in fit and finish. looks great, the side rubber gasket is a bit stretchy, but that may be because it's brand new vs the 13 year old ones on my normal set. I could also do without the top circle cap, but nothing wrong with it otherwise, just personal preference.
How I got them...Not too good
The lens itself was demelled off...It was about 30 disks between the two lights, and a couple facial near misses from exploding ones
Free'd from 2003 spec hell! Not shown, but cleaning the channels of the left over sealant was pretty fun! I had made a few mess ups by splitting the outer housing from using too much force, but it was nothing my trim refurbing experience couldn't fix/reinforce.
The ugly old adjusters.
New adjusters and butyl sealant... apparently not that easy to find in the US.
Almost there.
Cleaned up the outer housings and all rubber gaskets.
All Finished! I'm not gona lie, applying this butyl (in a 90 degree room) was hell! It is much more stringy and hard to work with. I ended up using a bit too much butyl, but it was in the name of being 100% leak proof. I also permanently sealed the top circular cover since it's dang near useless and only opens the door to potential issues.
A nice before / after
Now for installed pics.
2003 BMW 540i [Sterling Gray / O5SW M5 Black Interior]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one true authority of E39 Trim. --E39 Trim Information Thread [Click]
For Sale:
2004 BMW X5 4.8is [Black/Black] [Click]
E39 OEM Refreshed Xenons with new DJ Auto euro lenses! [Click]
E60 Windshield washer sprayer nozzles "Fan" style [Click]
E39 HVAC Buttons [Click]
Got Broken E39 Rear Quarter sun shades? [Click]
Random stuff I don't list on the board: https://www.ebay.com/usr/dking056
Dking078 is offline
post #2 of 18 Old 1st January 2016, 09:37 PM
She loved E
She loved E's Avatar
She loved E is offline
post #3 of 18 Old 1st January 2016, 10:22 PM
therealet23
therealet23's Avatar
Nice Work!!! You should have put some EVOX-Rs or FX-R 1.1's in there while you had it open!
therealet23 is offline
post #4 of 18 Old 1st January 2016, 10:24 PM Thread Starter
Dking078
Dking078's Avatar
Not gona lie, I was very tempted! But since it's a first attempt I played it safe. Maybe if I ever do a V2 set
For Sale:
Dking078 is offline
post #5 of 18 Old 2nd January 2016, 05:15 PM
Will.
Will.'s Avatar
They look great!
By any chance, did you check to see if the amber reflectors could be used in place of the clear corners on the DJ Auto lenses?
2001 M5 | 2005 M3
Will. is offline
post #6 of 18 Old 2nd January 2016, 07:10 PM Thread Starter
Dking078
Dking078's Avatar
Originally Posted by Will. View Post
They look great!
Unfortunately, I did not try this.
For Sale:
Dking078 is offline
post #7 of 18 Old 3rd January 2016, 12:00 AM
OC e39r
OC e39r's Avatar
Good job Daniel.
2nd on FX-r transplant.
Sent from AutoGuide.com Free App
Running strong
Hüper Optik 40%
E60 545 shifter - removed
E53 X5 front control arm bushings
E9x radio knobs
E46 m3 alcantara steering wheel
Eibach rear sway bar
Koni yellows
CNS 10.5 clutch disc with a lightened dual mass flywheel - removed
Carbotech 1521 pads
StopTech SS brakes lines
Centric high carbon rotors
Intravee II,Alpine KCA420i - removed
Cupholders delete
TEC cupholder
Pre facelift headlights retrofit
OC e39r is offline
post #8 of 18 Old 5th January 2016, 10:01 AM
ObjectEdit
Very nice! Where abouts are you located in LA?
I just attempted heating and opening my lamps (2002 M5) only to find 7 mins at 270 deg, and heat guns don't make the glue gooey. I'm guessing these may be the newer unbakable glue? It looks and feels like hard silicone, and doesn't get soft with heat. ( I've opened other lamps before in the past).
That being said, I have these lamps, and new adjusters... And a new set of DJauto clear lenses, just like yours.
Would you possible be able to help me out and install the DJ auto lenses for me ? If possible, how much would you charge?
Thanks!
-Joe
ObjectEdit is offline
post #9 of 18 Old 5th January 2016, 04:54 PM
SidekickChuck
SidekickChuck's Avatar
Very nice work! So if those headlamps are almost permanently sealed (because they are off a 2003), I assume it is due to the fact that the sealant they used is not very pliable, and hardens to almost a solid. If this is the case, how were you able to remove the sealant and plastic that remained in the channel after you dremmeled the lenses off?
I hope you retained and reused the vents with the rubber caps in the rear of the housing. They are vital to keeping condensation from occurring inside the assembly.
2001 BMW e39 M5
Eisenmann Race Exhaust
SS X-Pipe resonator delete
Powerchip Tune
South Bend Stage II Endurance Racing Clutch
CNS Lightened Flywheel
KW Variant 3 Coilover Suspension
RDSport 19" RD2
AC Schnitzer Type II Racing 19x9.5F 19x10.5R
Latest Photos
SidekickChuck is offline
post #10 of 18 Old 5th January 2016, 06:24 PM
mech9t8
mech9t8's Avatar
Very nice. A cheaper option to the EVO-X is to use an optically clear lens. Makes a significant difference.
mech9t8 is offline
Wing Mirror Glass Question (US spec/ Euro spec) Jgy6000 E39 M5 and E52 Z8 Discussion 3 18th March 2013 02:08 AM
Are the strut housing from USA spec and Euro spec B36 the same? mc hammered E34 M5 Discussion 1 13th August 2011 03:40 AM
US spec v Euro spec front rotor weight MrCrashRR E39 M5 and E52 Z8 Discussion 12 18th June 2010 11:28 PM
E60 For Sale: LCI Tail Lights - EURO SPEC, US SPEC AKAlius Parts / Other For Sale or Wanted 3 1st April 2010 07:05 AM
Difference btw. Euro. spec. & US spec. 996TT? Angel Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 3 7th August 2002 08:11 AM
