UUC DSSR Review and Install - BMW M5 Forum and M6 Forums
post #1 of 11 Old 29th December 2004, 04:51 PM Thread Starter
Wrightsville Beast
Wrightsville Beast's Avatar
Hey Crew.
As some may remember I wrote a review on the UUC Evo 3 shifter a few weeks ago. That thread is located here:
https://www.m5board.com/vbulletin/sho...hlight=uuc+evo
At the time I was not able to get the DSSR installed because I was having issues with the clip near the transmission. So - I drove the car with the stock shifter rod in place for a few weeks until I could get time to work on the DSSR install. This was actually informative as it allowed me to see the difference between the stock rod and the DSSR with the Evo 3 shifter.
The Install:
The clip near the tranny is a PIA to get off - especially using just ramps to get access under the car. I used Dave Z.'s trick of using the glove to push on the clip. I believed Dave! Yes - it finally came off - but I also used a screwdriver to pry open the clip somewhat. Some may come off easier than mine - but just be prepared and patient as it may take a little time. You can see the clip - and you can get access to it - so this is a DIY for those so inclined.
Once that clip is off - it is all of 20 minutes to get the rest of the rod installed - very easy.
The fit is PERFECT. Extremely close tolerances. One wonders why BMW didn't design the rod this way to begin with - it makes so much SENSE. When you compare the stock shift rod to the DSSR - well there really is no comparison. The design and build of each are at opposite ends of the spectrum.
The difference between the stock shifter and the Evo 3 was night and day. The difference with the DSSR installed is not quite as dramatic - but still a big difference. Shifting is even MORE precise and very solid. The shifts shoot from gate to gate with more precision and accuracy - it is an improvement you can definitely feel.
In conclusion - I would not hesitate to recommend this product. Anyone getting the Evo 3 without the DSSR is missing out on even more precision. I am glad I installed the DSSR as it makes a noticable difference in the shifting feel and accuracy.
Wrightsville Beast is offline
post #2 of 11 Old 29th December 2004, 05:52 PM
pmarin
pmarin's Avatar
Re: UUC DSSR Review and Install
I agree, the combo is a "must do" mod, night and day improvement. No rattles either!
2003 Jet Black m5 sport black interior
Supersprint ceramic headers, x-pipe, & mufflers
Updated Dinan Cold Air Intake
UUC EVO3 shifter with DSSR
Powerchip 91 software
PS2 tires, Clear Bra, Hardwired V1
Phatbox, Sirius, Bluetooth
pmarin is offline
post #3 of 11 Old 29th December 2004, 06:48 PM
howler
howler's Avatar
The EVO3 /DSSR unit is one of the best mod's for the money I've made.
The fit and finsih of this combo is far from none the best I've seen.
I highly recommend this setup for anyone tired of the notchy stock shifter.
Originally Posted by Wrightsville Beast
Hey Crew.
The Install:
Bob
FORMER CARE GIVER OF:
'03 M5 Sterling Grey/Black Sport/Aluminum Trim
Dinan:
Headers
Stage I lightened Duel Mass flywheel
High Performance Clutch
Cold Ir Intake System
High Flow Throttle bodies
Tuned Velocity stacks
High-flow air mass meters
3.45 differential
Stage V software,
Stage III suspension
Stage II Dinan/Brembo Brake Pkg.
Strut Tower Brace
Shock tower brace______________________________
OZ Superleggera III wheels w / Goodyear F1 GS-D3
Carbon Fiber rear diffuser
Tubi Cat-back exhaust
UUC EVO 3 SSK/DSSR
Euro Clear corner Xenons
V-1 w / Stealth One
Lidatek LE-30
AC Schnitzer pedals
OE Fire Extingusiher
OE First Aid Kit
howler is offline
post #4 of 11 Old 29th December 2004, 07:06 PM
dmz
dmz's Avatar
dmz is offline
post #5 of 11 Old 29th December 2004, 08:30 PM
Boz M5
Originally Posted by dmz
I agree, best mod for the money so far.
I totally agree its an excellent mod. I did the Evo 3 shifter about 8 months ago. I added the dssr about three weeks ago. It seems that shifting from first to second gear is quite a bit harder you have to shift it like you mean it. otherwise it doesn't want to go in gear. Also Ive had the handle come off a few times while shifting.
Boz
Boz M5 is offline
post #6 of 11 Old 29th December 2004, 09:56 PM
LBPDNNM5
LBPDNNM5's Avatar
Question on the EVO3--my car has a UUC SSK installed in Dec 2002 by previous owner. I am thinking that was probably a previous version (EVO2?). Anyone have any knowledge of the difference? The one I have is great in my view.
Larry
2000 Dinan S2 Carbon Black/Caramel
LBPDNNM5 is offline
post #7 of 11 Old 30th December 2004, 12:33 AM Thread Starter
Wrightsville Beast
Boz,
That funny - because I seem to experience the exact opposite now on my 1-2 shifts. It fires out of first and into second like its on autopilot - faster and smoother than before....
post #8 of 11 Old 30th December 2004, 12:57 AM
buymenow00
buymenow00's Avatar
I have the same thing...2nd gear needs to be firmly engaged, I've had it actually pop out of 2nd twice. Evo3/DSSR combo was installed a couple months ago, so I thought it would work itself out over time, but it is still the same. All other gears feel great, excellent even...but 2nd gear is a pain, and a real bummer when running up (or down) through the gears. My mechanic says that since this unit doesn't have any adjustments (the ball is fixed) there's really nothing for him to play with.
Rob, any ideas here?
2011.5 M3 Sedan ZCP
Retired:
2005 330i ZHP
2007 M Coupe
2003 M5
2001 530i/6
1992 325i
1981 320iS
buymenow00 is offline
post #9 of 11 Old 31st December 2004, 12:20 AM
Rob Levinson
m5board.com Site Sponsors
From 12/02, it's the EVO2. EVO3 started shipping around 10/03.
The differences between EVO2 and EVO3 for the M5 include:
1) The self-adjusting primary pivot ERK which provides a permanently smoother and more precise action as well as super-aligning the linkage geometry.
2) Full-length interior vibration isolation material.
3) Oversized lower pivot bearings and altered design which aids installation .
4) Change from an aluminum upper sectio to alloy steel with a greater compensatory mass that smooths shifting.
Is it worth changing? That's a question for you to ask yourself, viewed in terms of the costs involved - a new shifter and installation. We do offer a $100 "customer loyalty" rebate program for trade-ups if do choose to get the EVO3.
There is a DSSR available for the EVO2. It's different, but the difference only has to do with the change in the lower pivot bearings. The functionality is the same, but the part is slightly different and comes with different bearing parts that update the lower assembly to an EVO3 style. Price is the same.
UUC * www.uucmotorwerks.com * 678-679-5360
Rob Levinson is offline
post #10 of 11 Old 31st December 2004, 12:25 AM
Rob Levinson
The BMW gearboxes have some variability from car to car. It's not unusual to see one car with a specific type of issue and another with absolutely no (or even opposite) similarity of behavior.
What we have found through the years is that the choice of transmission fluid makes a very big difference. Despite the discussions of "special" fluid that BMW recommends, in all reality the M5 gearbox is in the same design family as the earlier V8 and V12 transmissions and will respond the same way. Our recommendation is to use Redline D4 ATF (the "magic potion" for smoothing out BMW gearboxes) or a 50/50 mix of D4 and Redline MTL. Where there are other good combinations (including some recent ones that I will be trying in my personal car), the Redline products have repeatedly been the best choice in our testing.
- Rob
UUC Evo 3 Shifter Review and Install Tips Wrightsville Beast E39 M5 and E52 Z8 Discussion 18 9th May 2005 11:12 PM
yet another UUC SSK/DSSR review... Brother Methias E39 M5 and E52 Z8 Discussion 9 1st November 2004 01:56 PM
UUC shifter install impressions rmasu E39 M5 and E52 Z8 Discussion 14 20th December 2002 10:03 AM
Review and Comments on M Audio enhanced bass subwoofer install mofo_knows E39 M5 and E52 Z8 Discussion 16 17th July 2002 02:09 AM
Rogue Engineering WSR (review) DZeckhausen E39 M5 and E52 Z8 Discussion 22 28th March 2002 05:08 AM
