Time for a new clutch, looking for a mild option - Page 3 - BMW M5 Forum and M6 Forums
 13Likes
post #21 of 29 Old 15th December 2014, 12:51 AM
gsfent
gsfent's Avatar
Originally Posted by mgdmb View Post
Indeed it does, no chatter at all, ever. CNS takes the stock dual mass flywheel and shaves it down to remove the weight, so you're left with all the benefits of a dual mass, but much lighter than stock kit.
I believe Dinan just lightens the flywheel, but CNS has it machined to flatten the surface so it can accept the larger disc. It is almost 1 inch larger in diameter, which is a lot. Not sure it couldn't be done by any good machine shop, but you would at least need the old one in hand to see where the machining took place.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is online now
post #22 of 29 Old 15th December 2014, 01:09 AM
mgdmb
mgdmb's Avatar
Good point, I hadn't considered that... I know there's a picture on here that compares the Dinan and CNS flywheels. iirc, CNS removes the dowels and drills new holes, too.
mgdmb is offline
post #23 of 29 Old 15th December 2014, 01:12 AM Thread Starter
PumpinIron
Banned
Interesting. I know everything Dinan comes with a huge, huge markup. I wonder how much you'd be into this if you started with a $400 brand new LUK DMF and then had a reputable machine shop do the work. That would be interesting to see how much money could be saved.
PumpinIron is offline
post #24 of 29 Old 15th December 2014, 07:15 PM
gsfent
gsfent's Avatar
A good part of the charge is R&D (or as we call it, trial and error! LOL). Just taking weight off is not hard, but doing it in a way to optimize performance is what you are after.
Now, if someone has a worn Dinan DMF to look at and we can compare to a stock DMF, then I think you can easily replicate for under $100 of machine shop time. I would probably select a shop that does a lot of race car work too, they would tend to be more familiar with the process IMHO.
post #25 of 29 Old 15th December 2014, 07:54 PM Thread Starter
PumpinIron
Banned
Yeah, that would be nice to have a worn Dinan DMF to compare to the stock one so it could be machined to spec!
post #26 of 29 Old 16th December 2014, 04:19 AM
m5power1
https://www.m5board.com/vbulletin/e39...arts-list.html
Stock car. Stock DMF flywheel + South Bend Stage 3 Endurance. Clutch felt really heavy at first, but within two days your foot gets used to it and it feels like stock. Other than that, I'm very happy with this setup. Nice streetable clutch, no on/off feel at all. I actually expected the clutch to be grippier, but I guess kevlar (Endurance) has a lower friction coefficient than organic (Daily).
m5power1 is offline
post #27 of 29 Old 16th December 2014, 04:28 AM Thread Starter
PumpinIron
Banned
Nice! I'm putting together a list of parts of things I want to replace while I'm in there.
So far I've got the clutch, flywheel, rear main seal, transmission mounts, transmission input and output shaft seal, guibo, and several other parts as well.
post #28 of 29 Old 13th January 2015, 06:56 PM
Viper3812
Viper3812's Avatar
I ordered the South Bend stage 2 daily clutch yesterday. Going to pair it up with my UUC ltw flywheel.
Viper3812 is offline
post #29 of 29 Old 4th July 2019, 01:09 PM
Jayson
Jayson's Avatar
Hate to bring back a 4 yr old thread but I'm curious what you opinion is on this clutch at this point? I need to replace my dinan which has lasted 70k miles but don't want to spend that much right now so I'm considering the southbend endurance
Sent from my SM-G975U1 using Tapatalk
Jayson is offline
Time for a new clutch euroukie E39 M5 and E52 Z8 Discussion 1 6th September 2012 11:45 AM
Rarely does U.S get the best option, but this time BMW got it right desmotesta E39 M5 and E52 Z8 Discussion 19 26th May 2012 03:58 AM
Best Option for Replacement Clutch/Flywheel for High Performance Street Use herrubermensch E39 M5 and E52 Z8 Discussion 8 10th October 2008 12:22 AM
Is it time for a new clutch? tjav8b E60 M5 and E61 M5 Touring Discussion 7 9th March 2008 06:02 PM
we have a NEW CLUTCH OPTION! dbox E39 M5 and E52 Z8 Discussion 34 23rd February 2005 05:54 PM
