DIY: Cruise control fix - BMW M5 Forum and M6 Forums
post #1 of 24 Old 30th October 2014, 09:12 PM Thread Starter
Burnout_187
Burnout_187's Avatar
Cruise control fix
Symptom: Cruise control does not activate, when green light is on. Or activates for few seconds and then disengages.
I had error code for brake pedal switch so i assumed that was the problem. Allso in TIS repair instructions it says that brake pedal switch is problem for those symptoms. After change, no difference.
After that searched for cruise control module, found one at realoem for M5, part number: 65718375497.
Ordered it from ebay and was ready to change it but i could find it. Seems that M5 does not have one, regarding realoem says that it has.
Okay, last change. gear position switch...Nbr #1
well, it wasn't switch itself, it was spring behind it.
Here is the location for the switch.
You need 22mm spanner, open switch, remove it. Then remove spring and pin. Replace spring and put it back in right order. Tighten it and your cruise control should work now.
Partnumber for spring: 23 31 7 511 337
Luckily i had my old gearbox lying around so i got spare parts immediately.
Burnout_187 is offline
The Following 4 Users Say Thank You to Burnout_187 For This Useful Post:
68FB (31st October 2014), chowdah (31st October 2014), gsfent (31st October 2014), tmaschm (31st October 2014)
post #2 of 24 Old 30th October 2014, 11:27 PM
tmaschm
Thanks! I need to do this!
2000 M5
Sport interior w/ full leather
Mk4 navigation computer, 16:9 navigation, 2015 maps
Sirius/Aux retrofit
E60 545i shifter, F10 M5 shift knob
Dinan adjustable RSB
Euro spec facelift headlights/tail lights
LCMIIIB and RLS for auto headlights
tmaschm is offline
post #3 of 24 Old 31st October 2014, 03:52 AM
68FB
Just curious, how do you know you need to do this? This is a pretty rare failure.
68FB is offline
post #4 of 24 Old 31st October 2014, 04:31 AM
tmaschm
Well my cruise control isn't working. Green indicator comes on but won't set at speed. I don't think it is the brake pedal switch as my lights work fine. Also I don't think its the neutral safety switch as the car won't start if the clutch isn't pressed in. That leads me to believe it's this spring. I've heard of it breaking on more than just this guys car so it must not be all that rare.
2000 M5
Sirius/Aux retrofit
tmaschm is offline
post #5 of 24 Old 31st October 2014, 03:14 PM
rvt1000
rvt1000's Avatar
Another possibility may be your gear indicator switch and reverse light switch on the transmission. It may have fell loose, or switched if you did any transmission work as both cables plug into the same style connectors. I had the same issue and mine were plugged into the wrong connector. Easy way to tell is if you are in any gear do your reverse lights turn on ?. When the gear indicator switch is plugged into the reverse light cable the car does not know what gear it is in hence no cruise. Easy fix if that is the case.
lll M5 Silverstone Ext/Int
Dinan Stage3 Suspension
01 BMW M5
03 BMW 330XI
06 Audi A6 4.2
11 BMW X5 3.5i
rvt1000 is offline
post #6 of 24 Old 31st October 2014, 03:44 PM Thread Starter
Burnout_187
In prefacelift cars they are same, facelift cars they have different connectors.
post #7 of 24 Old 31st October 2014, 04:08 PM
aazeez1975
aazeez1975's Avatar
If you have the transmission down for clutch change it is a good idea to change all the springs and little parts specially item 16.
aazeez1975 is offline
post #8 of 24 Old 31st October 2014, 04:35 PM
rvt1000
rvt1000's Avatar
good to know
01 BMW M5
03 BMW 330XI
06 Audi A6 4.2
11 BMW X5 3.5i
rvt1000 is offline
post #9 of 24 Old 31st October 2014, 05:23 PM
68FB
In NA, cars had two clutch switches up to 09/2001. One was a Hall effect switch used by the DME for ABS, DSC, and cruise control (S32 in WDS), and the other was a conventional switch (S235) used for the start lock.
But if your S32 switch was bad, I would have expected you to have code 50 (hex 80), the one with the weird "switch chain grip" description, and no green light on the dash, so it sounds like you are on the right track.
I have seen those switch pins damaged but it was the roller and axle on the end getting chewed up, not the spring breaking like that, although maybe the one leads to the other. I replaced this pin a couple of years ago due to worry about the catastrophic damage it can do to the tranny. The old one was like new.
68FB is offline
post #10 of 24 Old 31st October 2014, 05:38 PM
Rontgen
Rontgen's Avatar
Could the status of these switches be viewed with INPA?
- Darrell
2001 M5 - Jet Black / Black Sport Interior
Xtrons PB7639BP Android Head Unit - AutoSolutions SSK
Dinan Exhaust - Rogue Engineering Resonated X-Pipe
Bilstein B8 - Intrax Springs - Eibach Rear Sway Bar
1990 325is - Jet Black / Black
Rontgen is offline
No Cruise Control? Jetpilot718 E39 M5 and E52 Z8 Discussion 64 2nd May 2018 10:45 AM
ABS, brake light, DSC, Tyre control inactive but I still have cruise control?? Leezamonkey E39 M5 and E52 Z8 Discussion 9 15th October 2011 06:53 PM
Cruise control bay E34 M5 Discussion 0 11th May 2006 02:50 PM
No cruise control? WMWNWMN E34 M5 Discussion 11 6th March 2006 01:33 AM
Cruise control Joe_Jan E28 M5 Discussion 1 27th June 2002 01:29 AM
