Ideal Square Setup on Stock Suspension? - BMW M5 Forum and M6 Forums
 4Likes
post #1 of 20 Old 3rd October 2014, 12:12 AM Thread Starter
Westyside
Westyside's Avatar
Hey fellow Beast Tamers
I'm looking at ordering a new set of shoes for my beast and wanted to run this by the hivemind before I pull the trigger on custom rims.
I've got a stock suspension setup that I'm quite happy with, but it's time for tires and I felt that now would be as good a time as any to get into a square setup to both allow for tire rotation and reduce understeer.
I've already converted to Vorshlag 75mm Studs, and I want to make sure what I'm ordering is going to work the best.
A traditional square setup with 4x Style65 rear wheels gives you 18"x9.5 wheel at +22mm. Given that I'm not married to OEM sizes, is this still the best size to order if I'm planning on sticking with a stock suspension setup? What size front spacers should I use for this setup? I don't care about hellaflush and have no desire to roll or tuck fenders.
Any help from you geniuses would be much appreciated!
Westyside is offline
The Following User Says Thank You to Westyside For This Useful Post:
TheBullet (6th February 2017)
post #2 of 20 Old 3rd October 2014, 02:42 AM
gsfent
gsfent's Avatar
3mm spacers on front should give you just enough space to clear the struts. Can still seat the wheel on the hub. 275/35-18's all around. The favorite tire around here is the Mich PSS, although there are a few other alternatives.
If you have studs and nuts, get some plastic black covers, from 5 feet away, they will look like bolts.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
The Following User Says Thank You to gsfent For This Useful Post:
Duck (10th November 2016)
post #3 of 20 Old 3rd October 2014, 03:17 AM
LJG
LJG's Avatar
You need 3mm+ spacers up front to go square. My car ran 275's square for quite some time on stock suspension, now on Dinan 1.5, no issues.
-Lawrence
Imola Red | Caramel ///M5
LJG is offline
post #4 of 20 Old 3rd October 2014, 07:28 AM
masterofgoingfaster
masterofgoingfaster's Avatar
If they're going to be custom might as well make them have a perfect offset (~15-19) for the front so no spacers are needed and then put small (3mm) spacers on the rear if you like, no?
You could also consider going staggered X9 up front and X10 in the back (I think with correct offsets it fits) if you're not 100% sure about the square setup. If I were to go the custom route I'd probably put 255s on a X9 and 285s on a X10
Also, got any pics of the NSX and M5 together?
masterofgoingfaster is offline
post #5 of 20 Old 10th November 2016, 06:45 PM
Brent_M5
Brent_M5's Avatar
what's the best spacer to use up front for stock suspension M5 with stock rear 18x9.5 Style 65s with 275 Michelins? is it ok to use a 10mm or 12mm spacer since those come with a full hubcentric lip? Or will that rub with the fender?
Current:
-2001 Anthracite M5 (daily)
-2008 Black X5 3.0si (wife's mom mobile)
-1998 Cosmos Black M3/2/5 (track fun)
Gone but not forgotten:
-2000 Steel Grey 323Ci (first Bimmer / daily / track)
-2001 Slate Green 525iTa (wife's mom mobile)
-1989 Diamond Black 325iX (winter fun)
Brent_M5 is online now
post #6 of 20 Old 10th November 2016, 09:42 PM
gzig5
Your going to be getting close and it might depend on which tire you are running (PSS are a bit fatter than many) and what your front camber is set to. I haven't measured, but I run 3mm with PSS and I could probably just clear if I used a 10mm but might have some contact at extreme loading.
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is offline
post #7 of 20 Old 10th November 2016, 11:01 PM
doug
doug's Avatar
I ran PS2's and now PSS' for a long time with my stock suspension using 5mm spacers. The 3mm spacer was just not quite enough with either tire. I've since moved to a 3mm hubcentric spacers on new Ground Control coilovers. Works perfectly.
2003 M5 Sterling Grey/Black Full-leather, M-Audio, PDC
Day 1, Blue Ridge Mountains
Day 1, Biltmore Estate
doug is offline
post #8 of 20 Old 11th November 2016, 06:21 AM
centurycapital
3mm spacers upfront for sure, but consider keeping the track the same front to rear and run spacers front and Back
centurycapital is offline
post #9 of 20 Old 30th December 2016, 08:11 AM
ruprectgern
ruprectgern's Avatar
ruprectgern is offline
post #10 of 20 Old 6th February 2017, 12:52 PM
TheBullet
TheBullet's Avatar
I also have a 2002 M5 with a completely stock suspension and just picked up a staggered set of 65's in excellent condition. I am going to use the 8" fronts for a winter square setup and the 9.5" rears for a summer set.
I also plan on doing a couple autocross's each summer and maybe a track day or two here is Colorado.
That being said, I plan on running Continental Extreme Contacts 275/35 and have been given mixed information on what size spacers to use.
Here are the suggestions owners have stated:
15mm front, 10mm rear
3mm front, 10mm rear
5mm front, nothing on rear
3mm front, nothing on rear
My 2 goals are: staying as close to stock OEM specs OR trying to widen the stance as much as possible without the potential for any wheel rub.
Which spacer setup leaves the beast with true "square" stance?
Recommendations? Thoughts?
TheBullet is offline
My OEM square setup D-RodM5 E39 M5 and E52 Z8 Discussion 97 15th April 2016 12:23 AM
Square setup question masterofgoingfaster E39 M5 and E52 Z8 Discussion 15 19th June 2014 03:30 AM
Square setup vs Coilovers... TeamDeen E39 M5 and E52 Z8 Discussion 16 23rd February 2014 03:01 AM
Suspension Alignment, maximising tire life (lowered on coilovers and square setup) nakedpants E39 M5 and E52 Z8 Discussion 1 14th March 2013 06:23 PM
What rim for a square 18" setup rob p E60 M5 and E61 M5 Touring Discussion 1 16th November 2012 05:22 AM
