Joined the Big Leagues: ESS SC Impressions - Page 8 - BMW M5 Forum and M6 Forums
 41Likes
post #71 of 95 Old 21st September 2016, 03:14 PM
brads2002
brads2002's Avatar
That would be great. Thank you. Forgive me if this is an ignorant question but is there a way to use the 92MM pulley so it boosts sooner but open a waste gate so it still maxes out at 6PSI? I have turbo'd a couple BMW's in the past but have no experience with superchargers.
I think I would be happy with the 6PSI but not sure like revving to 5K to get partially there.
Looking forward to seeing your completed install.
brads2002 is offline
post #72 of 95 Old 21st September 2016, 04:33 PM
gsfent
gsfent's Avatar
Originally Posted by M55555 View Post
In prep for the AFR gauge, decided to relocate my boost gauge to this location (wiper arm lever), allowing the fog light switch location to house the AFR. Both perfectly in eye sight without taking eyes off the road and eliminating the need for any pods.
Interesting placement of the boost gauge. Can you put up some better pics of the two gauges (or the boost gauge on the wiper arm)?
Thx.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #73 of 95 Old 21st September 2016, 05:10 PM Thread Starter
M55555
M55555's Avatar
Thx.
For sure. Here's the backside of it.
I'll have more of both later today once the AFR arrives.
2001 Carbon Black ///M5
ESS VT1-560 Supercharger System 92mm Pulley
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete V1
Bilstein PSS9 Coilovers + Ground Control Camber Plates
BBS CH 19x8.5F, 19x10.0R
Michelin Pilot Super Sport 245/35F, 275/35R
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
OEM Mud Flaps
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser
SLIMM Front Lip Spoiler
SLIMM OEM Euro Armrest
Audiovox Mediabridge BT Integration
M55555 is offline
post #74 of 95 Old 22nd September 2016, 12:58 AM
brads2002
brads2002's Avatar
Yeah I'll try and take a look over the next few days after I get the AFR in. But I know for a fact with the stock pulley I saw zero boost at 3-4K RPM.
Been thinking about this today....I knew I saw the 3K somewhere. It was on their dyno graph. I also talked to Asbjorn at ESS. He said that boost comes on at 2500 and should be near max at 5K. I mentioned that it was an older kit and that wasn't a factor. M55555, think you might have a leak in the system? Sorry couldn't figure how to paste the graph but link below.
E39 M5 VT1-560 Supercharger System - ESS Tuning
post #75 of 95 Old 22nd September 2016, 02:45 AM Thread Starter
M55555
M55555's Avatar
After looking at my recent dyno chart, I get boost starting at 2.5K RPM and max boost at redline. I'll further verify this later.
Also, I completed the install of the AEM UEGO Wideband AFR gauge. Looking forward to the drive tomorrow.
Wideband Gauge was $166 shipped on Amazon
O2 Sensor Bung $25 local muffler shop (pre-cat)
Install: 1 hour total time, from start to finish
OEM Mud Flaps
M55555 is offline
post #76 of 95 Old 6th October 2016, 05:25 PM
PAbimmerfan0429
PAbimmerfan0429's Avatar
PAbimmerfan0429 is offline
post #77 of 95 Old 6th October 2016, 11:41 PM
mcgnms
mcgnms's Avatar
All of these kits will reach max boost at Redline. If its not then there is a problem with your setup.
SOLD: 2000-BMW-E39-540i/Biarritz-Blue/Gray-Interior/Black-Trim/Sports Package/6-Speed/DSP.
Powertrain: TTFS Stage-2 VF-Engineering Supercharger | Dinan Manifold | Magnaflow 16858 Exhaust & X-Pipe | High-Flow Cats.
Suspension: ECSTuning Cup Kit (Koni Yellow/H&R 50464) | BF-Goodrich Comp-2 A/S.
Cosmetic: Front & Rear M-Tech Bumpers | Slimmbones Finned Rear Diffuser | Piano Black Interior Trim/Style 37's.
Extra: S62 Clutch & PPlate | AEM 320 Fuel Pump | AEM Wideband/Boost Failsafe | E60 SSK | ZHP Knob | CDV Delete | Blitzsafe Aux | Wolverine Pan Heater
Current: 2001-BMW-E39-M5/Carbon-Black/Silverstone-Interior/Sport Seats/M-Audio
Powertrain: Dinan Exhaust
YouTube Channel
Instagram
Twitter
CarThrottle
mcgnms is offline
post #78 of 95 Old 30th November 2016, 11:19 AM
zer0cool82
zer0cool82 is offline
post #79 of 95 Old 13th April 2017, 07:42 PM
brads2002
brads2002's Avatar
The 5er is out of hibernation and I have put about 300 miles on the kit. I really like it. Only thing I noticed is that when cold it tends to hold RPM so you have to break a bit more. This goes away once the car is warm. All in all early indications are its a lot of fun and the car maintains its stock characteristics.
I swear the car feels faster after the first few trips. Do these have a performance break in period? I am not sure what would actually change inside the supercharger to give me this perception. Its not weather dependent. I have run on both cold and hot days as we have had some weird weather lately.
post #80 of 95 Old 13th April 2017, 09:47 PM
Silent
Silent's Avatar
It's probably faster because you haven't driven it in a while. Mine has been sitting since I finalized the tune, but I did get a chance to update to the F10 shifter. If time allows, I'll be updating my front suspension. Have most of the parts collecting dust.
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
ESS VT2 580 Upgrade-Impressions havasusteve03Beast E39 M5 and E52 Z8 Discussion 42 9th June 2013 04:35 PM
ESS Supercharger-Initial Impressions (Long) Blockdoc E39 M5 and E52 Z8 Discussion 51 24th December 2009 02:59 AM
Another ESS ECU Tune: Thoughts and Impressions andrewsherman E60 M5 and E61 M5 Touring Discussion 180 16th May 2008 08:51 PM
Finally, the BIG DAY. Initial driving impressions(long) schnelleM5 E39 M5 and E52 Z8 Discussion 25 3rd March 2003 03:53 AM
