Retrofit Automatic Headlights
58K views 59 replies 23 participants last post by  Tamer
#1 · (Edited)
As I was doing some pre-purchase research on the E39 M5, I realized that the 02-03 models offered a feature I really wanted: Automatic Headlight On/Off. While it seems trivial, all my other cars have this feature and I've grown to like it (read: I'm lazy and spoiled). First World Problems. :)
As luck would have it, I came across a very low mile 2001 (Build 12/00) model and simply couldn't pass it up, so I bought the car despite it missing this feature. My hopes were to retrofit Auto Headlights after I took care of some other maintenance and repair work.
Much of this info came from http://www.e39.org.uk/autolights.htm, so this DIY is an attempt to condense some of the info, shed some light on the required coding, and show some pics from a car with the steering wheel on the correct side. ;)
Thanks to Adam (Clemster) for hooking me up with a great deal on a matched set of components to perform this swap! As always, perform this at your own risk - I am not liable for anything!
Parts you'll need:
- LCM IIIB (Light Check Module)
- RLS (Rain & Light Sensor)
- 4-position Light Selector Switch & Bezel
- RLS adhesive pad
Tools you'll need:
- Torx driver
- Phillips Screwdriver
- Various trim removal tools
- 19mm socket
- Small flat screwdriver
- Heat Gun (hairdryer might work also?)
- 8mm socket and ratchet
- Laptop with PASoft's BMW Scanner software and OBD-II head.
General Info:
The Automatic Headlight function is controlled by the LCM and it looks for two inputs when deciding whether the lights should be on or off: the light selector switch should be in the "Automatic" position (Max counter-clockwise) and the RLS should be reporting that the ambient light level outside is lower than the specified threshold. Easy, right?
The 2000-2001 cars came with a LCM IIIA, which isn't capable of handling this function, so we'll need to upgrade to a LCM IIIB, preferably from a salvaged M5. I believe this LCM is available from other BMW models as well, although I'm unsure exactly how the coding would need to be handled. Ditto for the LCM IV which is also rumored to work for this application. M5 build date you are looking for is 9/2001 or later.
Assuming your M5 came with automatic wipers, there is a rain sensor (RS) located on the inside of the windshield, just below the rear-view mirror. This sensor will need to be replaced with a RLS in order to add the ambient light functionality.
The Light Selector Switch on the 00/01 cars is a 3-position switch: Off/Parking Lights/On. We'll need to replace it with a newer switch and labeled bezel that adds a 4th position to the left of "Off", which is the Automatic selection.
Again, easy stuff as this is all plug-and-play with no wiring changes needed.
Light Selector Switch Installation:
Pull on the selector knob and it will pop off, revealing the plastic 19mm nut which secures the light switch to the cluster bezel. Loosen the nut with the socket, but don't remove it yet. Remove the cluster bezel by popping off both pieces of wood/titanium trim and removing the three Phillips-head screws. Also remove the three Torx screws at the top of the cluster bezel and the bezel will pull toward you. At this point, you should be able to access the rear of the light switch. Unplug the single connector and remove the 19mm nut. Reassembly is the reverse of above - be careful not to over tighten the 19mm nut...it doesn't take much force to hold the switch in place.
LCM Installation:
The LCM is located in the passenger-side kick panel, below the glove box. There are lots of DIYs and videos out there that can explain this better than I can, so I'll refer you to YouTube for this part. I would recommend taking a close-up picture of the label on your new LCM in case you need to know part numbers or sw versions later on. Before removing your old LCM, use BMW Scanner or NCS Expert to note your specific LCM coding options so you can manually apply those to your replacement LCM.
Not my video, but here's a how-to I found on YouTube:
How to remove LCM on 1998 BMW 528i E39 - YouTube
For reference, my new (used) LCM-IIB
RLS Installation:
Remove the trim around the rear-view mirror mount by prying it apart with a small screwdriver. Once it's popped apart, remove both halves. Remove the rear-view mirror by grabbing the mount and rotating it counter clockwise about 45 degrees. Unplug the electrical connector and your mirror is now out of the way. Remove the RS by prying out the plastic retaining clips from both sides. The sensor should pull off the Prism, which is glued to the windshield. Unplug the RS and set it to the side. Now you need to remove the prism from the windshield. Note that the Prism on the RS is made of glass, so prying on it is not advisable. The adhesive is a gelatin-based "goo" that is similar to what holds a new credit card to it's paper. I found that heating the prism up with a heat gun allowed me to get a plastic trim removal tool wedged between the windshield and the prism and pop it loose. Clean the windshield by "rolling" the adhesive from one side with your fingers, just like you would a credit card. You should be able to get the bulk of the goo off with your fingers and carefully follow up with a razor blade and some glass cleaner for the last few bits.
Rain Sensor:
At this point, the RLS opening on the windshield should be crystal clear and ready for a new prism.
Take the RLS off it's plastic prism by sliding the locking tabs up and removing the prism. Keep in mind that the electrical connector for the RLS will end up in the upper right hand corner once installed so make sure you orient the prism correctly. I ordered two type 903 pads from:
RAIN SENSOR PAD REPLACEMENT 903 (Pad only)
903 RAIN & LIGHT SENSOR KIT (Pad & Prism)
Although you only need one, I'd recommend buying two so you have an extra just in case. Each pad comes with instructions and a tube of 3M primer. Apply a light coat of primer to the windshield and let dry for >5mins. Same for the back of the prism. Once the primer is dry, peel off one side of the protective plastic and attach the pad to the prism. You can eyeball it and put it on centered. Once that's attached, peel off the other side of the pad and have a friend help you center it on the windshield. Attach the RLS to the prism and engage the locking slides. Plug the RLS in, re-install the rear-view mirror/trim and you're done!!
RLS Part Numbers for reference:
#2 ·
Coding:
At this point, the Auto Headlights should work! You can test it by either covering the RLS or shining a flashlight on it and the lights should respond appropriately. Same for the rain sensors: you can use a spray bottle filled with water and the wipers should react, assuming that you've initiated the first wipe from the stalk. You will have all the customer coding options from the car you salvaged the LCM from - in my case, I inherited Daytime Running Lamps after the LCM swap. In a moment, you can use your software tool of choice to re-code the specific options you had before.
But wait, something looks different on the cluster? What's that dot next to my trip odometer? WTF!??
That's the "tamper dot", but don't worry - we'll fix that too. The tamper dot shows up when there is a VIN mismatch between the EWS, IKE (cluster), and the LCM. Your new LCM is coded with the VIN of the salvaged car, so no surprise the dot is present.
BMW's software tools only allow changing the VIN on a brand new module (via DIS). The BMW software does not allow for coding a used module, thus forcing you to buy a brand new module. Luckily, PASoft's BMW Scanner software allows us a work-around to that limitation. Our job is to re-code our used LCM so it looks like a new LCM.
Using this guide I found somewhere on the internetz I was able to recode my LCM to eliminate the tamper dot:
https://www.evernote.com/shard/s28/...rd/s28/sh/124c7ec6-ea3e-49ec-aa39-3b6b081e8964/c76e0437d7634ab205d6e5db86e2bfe0
Follow the directions there (you did take a picture of the label on your LCM-IIIB, didn't you?) to change the algorithm, set the odometer, and the VIN
The only thing I did differently is rather than attempt to manually match the odometer readings, I just zeroed out the odometer by typing in "000000" and wrote that reading to the LCM's EEPROM. Once you change the VIN to match your last 7 and cycle the ignition, the EWS will populate that odometer reading, just like it would with a brand new BMW LCM.
At this point, use NCS Expert (or BMW Scanner) to restore any coding options you had previously and verify everything still works!
#8 ·
Thanks everyone! This board has been a tremendous wealth of knowledge for me and I'd like to contribute in some small way. These cars are old enough that by now, almost everything has been done by someone, somewhere. Sometimes it's just a matter of condensing the info into one thread to make it easier for the next guy.
It's under the passenger-side (LHD) kick panel. Check out the video I posted in the OP and it'll walk you right through it. The only issue I had was when removing the lower trim piece along the carpet/door opening, the clips broke. Luckily, it's a cheap fix: 3 clips (51478234047) @ ~0.50ea.
Good Luck!
#9 ·
Cost
I, like you, am all too spoiled with automatic lights on most of my other cars, so I'm really interested in this. Particularly since I leave my lights on all the time :rolleyes:.
One thing missing from your excellent post is the expected cost. Can you fill us in, please?
Forgive me if you listed this somewhere and I missed it.
#11 ·
Rontgen,
I've run into a snag. I am looking to purchase BMW Scanner v1.4, but it appears that this software only works with Windows XP. I don't have an XP machine; I use a Mac and a Windows 7 laptop.
I was able to download NCS Expert/Dummy for free. Can I use this to write my VIN and Odometer readings to the new LCM? If so, can I use the BMW Scanner USB cable and OSBII adapter to connect my laptop running NCS to my car?
Or am I screwed?
Thanks,
Art
#13 ·
As a cheaper alternative, you can add auto lights with NCS Expert by using the latest daten files and coding in the feature.
It doesn't turn the lights off during day time so that's a drawback I guess, but the lights do come on automatically every time the car turns on and off when you kill the ignition. I like day time lights so this option was perfect for me.
Also, you do have to turn the lights to the "on" position if you want to use your brights.
#14 ·
hi
I would like to thank you for the great job you did....but I have an e39 2001 and I did all the steps you offered it worked properly but the manual leveling switch doesn't work, my question what about if I changed the Lcm 3b to Lcm3 b man lwr.
is it gonna change the situation and make the switch of manual leveling work?
Sent from my SM-N920C using Tapatalk
#21 ·
To each his own, and good DIY. But constantly turning HID bulbs on and off greatly reduces their lifespan, right?
IMHO, auto brights would be a more useful retrofit.
#23 ·
I'm talking shadows, going from light to dark, tunnels, that sort of thing. But depending on your local area might not be issue.
#24 ·
Constantly flashing any light source reduces its lifespan - HID or otherwise. With HID, the concern is really with the ignitor. Modern bulbs, ballasts and ignitors are designed for hot restrikes. Only the very old and most aftermarket equipment should actually show this concern.
Further, automatic headlight systems, even those on vehicles with tungsten-halogen bulb sets, have a delay built in and usually an adjustable sensitivity setting to minimize needless cycling.
In short, it's really not an concern.
Reactions: Tamer and Rontgen
#26 ·
Iâ€[emoji769]m interested in adding auto headlights to my car. I want the headlights (and tail lights) to turn on at the hint of darkness or during early mornings. How sensitive is the light sensor of this e39 auto headlights system?
it is sensitive enough and very good it will turn on at the early morning and when you get into a tunnel or garage and will be off when day lights come around
#27 ·
Hi and thanks for this step by step guide!
I'm wanting to retrofit this on my '03 E39, I will have a look to the LCM version that is fitted in my car, maybe it's already the correct one.
But I've two questions about the RLS sensor :
1) You gave instructions with removing the RS sensor, but what if the car doesn't have the RS sensor, is the connector for the RLS sensor still present somewhere ? Or is there a need to run new wires ?
2) On a car without RS, will your retrofit also add automatic wiper blades operation ?
#28 ·
I thought RS was standard on all E39s, def shouldn’t be an issue on an ‘03
#36 ·
I don't think my car is prewired either...
terraphantm can you provide more details for making connections?
It's hard to tell from those pictures which lin goes where.
I'm wondering what's the latest body control module that can be installed, LCM IV?
I don't have any better pictures unfortunately.
You probably don't have to follow the factory wiring 100%. If the car has a sunroof, you can grab power and ground from the sunroof module itself. Then you need to run a wire to the K-bus (doesn't seem like there's any convenient modules to tap in that area), and also a wire directly to the GM3 module.
Latest LCM you can install is LCMIV C24. Generally speaking, you can always install a newer module than what your car came with.
#46 ·
A question about the switch. I want to also do a retrofit for rear fog light. But all the switches with rear fog lights don't have the Auto position. Am I missing something?
#47 ·
I think you’re forgetting that there’s 2 different switches. The headlight switch is on the left side of the steering wheel and the fog light switch is on the right side. The auto option (if you have it) is for the headlights and therefore on the headlight switch. The e39 isn’t smart enough to know when there’s fog, so no auto position for that.
