DIY: Retrofit Automatic Headlights - Page 4 - BMW M5 Forum and M6 Forums
 21Likes
post #31 of 34 Old 26th February 2019, 12:37 AM
sierramike
sierramike's Avatar
Originally Posted by terraphantm View Post
An 03 should have an RLS if it came with a rain sensor at all. If he somehow doesn't have one, then he'll most likely have to add the wiring.
And yes, if you add it, you should have rain sensing wipers afterwards. Might require your GM to be recoded.
Actually mine doesn't have RS nor RLS fitted. German car, the only country where BMW can be delivered with as few options as a Dacia ... Well, this was to say, they order nude cars with custom list of options, that means original buyer could have chosen professionnal navi but not the rain and/or light sensor ...
Anyways, is the wiring complicated to retrofit? Somebody knows which way the wiring should take and where it plugs?
sierramike is offline
post #32 of 34 Old 26th February 2019, 06:13 AM
terraphantm
It's 4 wires.
Pin 1 = Terminal R (Live with ignition position 1) - from the factory it comes off of X1443
Pin 2 = Ground - from the factory it would go to X10012
Pin 3 = K-bus. Goes to X10016
Pin 4 = X332 Pin 20
You could probably come up with simpler wiring if you wanted.
terraphantm is offline
post #33 of 34 Old 26th February 2019, 11:37 AM
Tamer
Originally Posted by josiahg52 View Post
Constantly flashing any light source reduces its lifespan - HID or otherwise. With HID, the concern is really with the ignitor. Modern bulbs, ballasts and ignitors are designed for hot restrikes. Only the very old and most aftermarket equipment should actually show this concern.
Further, automatic headlight systems, even those on vehicles with tungsten-halogen bulb sets, have a delay built in and usually an adjustable sensitivity setting to minimize needless cycling.
In short, it's really not an concern.
Do you mean that we can make the light sensor can be more sensitive to light much better and avoid delay
Tamer is offline
post #34 of 34 Old 3rd March 2019, 05:03 PM
alexE39M5s62
alexE39M5s62 is offline
Headlights Automatic Adjustment Woes Tiauguinho E39 M5 and E52 Z8 Discussion 28 31st March 2017 05:52 PM
Anyone retrofitted automatic headlights to an 01? Obioban E39 M5 and E52 Z8 Discussion 4 1st November 2013 04:37 PM
Automatic headlights... jadkar E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 10 14th May 2013 03:34 PM
Thoughts on automatic headlights and headlight washers? Clem E39 M5 and E52 Z8 Discussion 20 2nd August 2006 09:55 AM
Automatic Headlights ???? Nolift911 E39 M5 and E52 Z8 Discussion 27 9th June 2004 05:34 PM
