headlight housing question - BMW M5 Forum and M6 Forums
post #1 of 6 Old 19th March 2014, 06:59 AM Thread Starter
pantablo
pantablo's Avatar
I'm helping a friend sort his newly aquired 2003 540i touring. He's disabled and needs a good pair of hands to help him, as well as some BMW knowledge.
His passenger headlight is loose. 3 of the 4 mounting points are broken. Looks like if I replaced the back housing, number 3 in the image below, that it would easily solve the problem. Issue is after doing some research it seems the top tabs holding the housing to lens are plastic welded together and not intended to be replaced. The lenses on the 540 are not adhered to the housing from my research either, like the M5 lenses are so that helps.
Can this back housing be purchased separately and installed or does the entire headlight assembly have to be replaced?
part #3:
Thanks for any advice.
pablo-
pantablo is offline
post #2 of 6 Old 19th March 2014, 11:38 AM
blackxs
blackxs's Avatar
Whether its adhered is year dependant (not M5/540 dependant, since they shared the same lights) and 2003 lights are a solid piece. The entire assembly will need to be replaced - some 2001/2002 lights you can just replace the lens but that wont help you with your mounting tabs being broken and you cant do it on 2003 lights anyways.
This is the correct diagram for 2003 lights - interestingly even has a warning on the realoem page saying "The cover glass cannot be replaced. The headlight has to be used."
blackxs is offline
post #3 of 6 Old 19th March 2014, 08:05 PM Thread Starter
pantablo
pantablo's Avatar
pantablo is offline
post #4 of 6 Old 20th March 2014, 10:36 PM
XxGhostxX
XxGhostxX's Avatar
XxGhostxX is offline
The Following User Says Thank You to XxGhostxX For This Useful Post:
AGM5 (22nd March 2014)
post #5 of 6 Old 20th March 2014, 11:06 PM
SidekickChuck
SidekickChuck's Avatar
I thought the e39 touring (non-M) headlights followed the same LCI as the M5. So if it is a 2003, it would not come with the headlights that come apart by the clips, but would have to be handled in the same fashion as the M5 would.
[edit] Disregard, I didnt see that blackxs corrected the breakout diagram.
2001 BMW e39 M5
Eisenmann Race Exhaust
SS X-Pipe resonator delete
Powerchip Tune
South Bend Stage II Endurance Racing Clutch
CNS Lightened Flywheel
KW Variant 3 Coilover Suspension
RDSport 19" RD2
AC Schnitzer Type II Racing 19x9.5F 19x10.5R
Latest Photos
SidekickChuck is online now
post #6 of 6 Old 21st March 2014, 06:13 AM Thread Starter
pantablo
pantablo's Avatar
Originally Posted by XxGhostxX View Post
Without seeing the tabs its hard to say, but you can get these for the broken tabs
BMW E39 M5 S62 5.0L - 63126908410 - Headlight Repair Kit - ES#172737
I have like 3 of them on mine.
Blake
Dont understand how they install. Can you post a photo of yours installed?
pantablo is offline
2007 M6 Repacement Headlight plastic housing Mark Ducati E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 9th July 2010 08:23 PM
E39 Want to buy: Wanted: E39 M5 passenger headlight housing to replace my dull/worn housing Tripleinboard Parts / Other For Sale or Wanted 2 3rd April 2010 08:59 AM
E60 For Sale: E60 Xenon Headlight Housing ///WeissM Parts / Other For Sale or Wanted 0 22nd January 2010 12:52 AM
headlight housing question HOVO E39 M5 and E52 Z8 Discussion 2 28th February 2006 07:07 AM
headlight housing question HOVO E39 M5 and E52 Z8 Discussion 1 25th February 2006 02:45 PM
