Garage Door Opener - BMW M5 Forum and M6 Forums
post #1 of 20 Old 4th March 2001, 11:00 PM Thread Starter
01M5
01M5's Avatar
Post Garage Door Opener
Would someone be kind enough to explain how to program the garage door opener? Where is it in the owner's manual? Thanks in advance
01M5 is offline
post #2 of 20 Old 4th March 2001, 11:55 PM
AndyMenard
AndyMenard's Avatar
1) turn ignition on to the second position
2) Hold down the two outside buttons on the universal transmitter until the indicator light begins to flash (20-30 seconds). Then release the buttons. This initializes the memory and erases any previous settings on all three channels.
3) hold the end of your hand-held transmitter against the front surface of the univ transmitter so you can still see the indicator light.
4) using both hands, push the hand-held transmitter button and the desired button (the one you want this transmitter programmed on?) Continue pressing both buttons through step 5.
5) hold down both buttons until you see the indicator light on the BMW univ transmitter flash, first slowly and then rapidly. It indicates that you have successfully programmed the universal transmitter to learn the new frequency signal. Release both buttons once the rapid flashing begins.
To program another button, REPEAT STEPS 3 through 5 ONLY!! .
Hope this helps?...
Andy
2000 Imola M5 / Black Nappa - Titanium Trim
AndyMenard is offline
post #3 of 20 Old 4th March 2001, 11:57 PM
blue max
blue max's Avatar
Post
Welcome to the best car board on the planet.
Here's a thread on the very subject.
http://www.bmwm5.com/ubb/Forum1/HTML/001911.html
For purposes of our survey, what color is your car & in what corner of the globe are you located?
Thanks.
blue max is offline
post #4 of 20 Old 5th March 2001, 01:45 AM
Jim Dolan
Jim Dolan's Avatar
Post
If you program one now and weeks later want to add one, what do you do. Clear all and reset or just follow procedures #3 through #5. I just tried adding a second remote to the universal remote and finally resulted in clearing and installing both remotes. Am I right? If so I think that should be improved so you can add remotes at will without erasing and reloading them all over again.
Twice now that was the only way it worked for me. Any thoughts on this?
Jim
07/00 M5 Titanium over Red
Jim Dolan is offline
post #5 of 20 Old 5th March 2001, 04:12 AM
Jester
Did you guys install a secondary universal remote? My car didn't come with a homelink system that I know my dads 740 did. Is this what you are referring too?
'00 NBM Vette Convertible Pic #2
'00 ///M5 Titanium Silver/Caramel
Jester is offline
post #6 of 20 Old 5th March 2001, 06:02 AM
Need4Spd
Need4Spd's Avatar
Don't forget. If you have a garage door opener with "rolling codes" (continuously variable codes that change according to a built-in algorithm), you need to perform an additional step before your M5 remote (yes, it's std. and built in to the roof near the sunroof switch) will work. You need to locate the "learn" button on your garage door opener (the part with the motor!). After programming your car remote first, press the learn button on the garage door opener and then w/in like 10 secs., press the opener on the car twice. The first one logs in your remote and synchs it to the opener, the second should actually operate the door. It could take a couple of tries. Some openers don't give you much time to climb down the ladder, jump in the car and push the button (the key has to be turned to position II), as they all seem to assume you have a hand held remote, which of course you can operate while still standing on the ladder. Better yet, get a helper to push the remote in the car. A nice thing about the remote buttons on the M5 is that they're lighted. On some other cars that have this feature, they're not, which makes it a bit of a fumble when opening the door at night.
Need4Spd is offline
post #7 of 20 Old 5th March 2001, 04:33 PM
RaMsEs
RaMsEs's Avatar
Post
If you make your garage opener learn what the universal trasmitter is transmitting, what happens to the regular remote? My other car does not have a built-in opener and if this process messes up the the functionality of the regular remote then I can't do it. It'll probably be fine but I just want to make sure before I reprogram my opener.
Thanks,
-Shawn
RaMsEs is offline
post #8 of 20 Old 5th March 2001, 05:05 PM
MarkM5Lauderdale
MarkM5Lauderdale's Avatar
Post
Ramses, The garage door just thinks of it as an additional remote. Your existing remote should still work. (At least it does with mine)
Mark
2000 Dinan M5
2001 X5 4.4 Sport
Mark's M5 Page
X5 Page
[email protected]
MarkM5Lauderdale is offline
post #9 of 20 Old 5th March 2001, 06:19 PM
RaMsEs
RaMsEs's Avatar
RaMsEs is offline
post #10 of 20 Old 5th March 2001, 07:36 PM
Parkerfe
Post
And it works great. I have it progammed for my garage door opened and both my front and back security gates at home. I never have to look for the remotes again; until I change the battery and have to re-program I guess.
Parkerfe is offline
Nice garage (McLaren F1) + interesting story about #69 Gustav GTBoard.com: General Sportscars 5 10th March 2005 03:11 AM
My wife backed into the garage door!!! Naka E39 M5 and E52 Z8 Discussion 22 30th August 2004 08:36 PM
How I went from 2.5 car garage to 3.5 M5NSX E39 M5 and E52 Z8 Discussion 11 9th October 2002 11:52 AM
Tiling a garage floor, quest for ultimate garage lear E39 M5 and E52 Z8 Discussion 58 11th September 2002 10:10 PM
"ORDER / PRODUCTION SUMMARY" ( Note : See First Post For Instructions ) Alan A E39 M5 and E52 Z8 Discussion 82 17th March 2002 06:50 AM
