Clutch advice needed..... - BMW M5 Forum and M6 Forums
post #1 of 10 Old 25th March 2003, 07:04 PM Thread Starter
Reflex55
Reflex55's Avatar
Ok, so after a year and a half of ownership and some good time at the track, it's time for me to replace the clutch. Anyway, I've done some research and talked to a couple of friends, and they all recommended the Sachs clutch kit. So what is your opinion on this? Any other possibilities? Specific things that I should know/expect from this model? BTW, the car is currently rated at ~452hp/410lb-ft.
.: '02 M5 Carbon/Silverstone :.
-Hamann HM450 Package
-Brembo 355mm Discs
-H&R Coils
-ACS SS
-OZ Superleggera 9x19/10x19.
and more to come.....
Reflex55 is offline
post #2 of 10 Old 25th March 2003, 07:53 PM
MAH
MAH's Avatar
Re: Clutch advice needed.....
[ BTW, the car is currently rated at ~452hp/410lb-ft. [/B][/QUOTE]
How do you come to the conclusion that your car has 452hp? Modified in some way? Dyno results? We would like those same results.
Thanks,
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
Red (angry eyes) Angel Eyes
MAH is offline
post #3 of 10 Old 25th March 2003, 08:08 PM Thread Starter
Reflex55
Reflex55's Avatar
Hamann Exhaust+ECU+Cold Air Intake. Dynoed three months ago.
-Brembo 355mm Discs
-H&R Coils
-ACS SS
Reflex55 is offline
post #4 of 10 Old 25th March 2003, 08:15 PM
MAH
MAH's Avatar
Do you have the Harmann headers?
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
361RWHP
425HP and growing!
MAH is offline
post #5 of 10 Old 25th March 2003, 08:48 PM
jmott
heh
50hp from the ole IHE eh?
what kind of exauhst is this?
just a muffler/catback?
or headders, catalytic converters and everything?
oh, and to actually give you some input, I was doing some research and found that these guys: http://www.dialaclutch.com/
who distribute the stock M5 clutch can add a kevlar lining for increased durability/clamping force. very inexpensive too.
havent tried it yet tho!
jmott is offline
post #6 of 10 Old 25th March 2003, 08:52 PM
MEnthusiast
Moderator Emeritus
MEnthusiast's Avatar
cant recommend a clutch, sorry, but I want to say- great pics over at layer2k- are you the photographer?
All the best,
MEnthusiast is offline
post #7 of 10 Old 25th March 2003, 09:21 PM Thread Starter
Reflex55
Reflex55's Avatar
Yes, the exhaust system is the complete package. Exhaust headers and everything. Thanks for the link, btw. It looks like an intersting thing. I'll check that out.
MEnthusiast : Photography is just a hobby. I wish that I could do it professinaly, though.
-Brembo 355mm Discs
-H&R Coils
-ACS SS
Reflex55 is offline
post #8 of 10 Old 25th March 2003, 10:04 PM
Teutonaddict
Teutonaddict's Avatar
...they all recommended the Sachs clutch kit. So what is your opinion on this? Any other possibilities? Specific things that I should know/expect from this model? BTW, the car is currently rated at ~452hp/410lb-ft.
Reflex-
The clutch is one area that's universally seen as a weak point, yet there's not been a definitive solution that's proven successful. I did a lot of research on this about a year ago, and then ended up getting a new clutch under warranty, so my investigation stopped.
My own M5 has never 'hooked up' as good as it did when new; I have a hard time breaking traction these days. Once hooked up, however, I have no complaints about power on tap. It's just that I don't go looking for stoplight drag races any more.
If you do a search using "sachs + performance + clutch," here's what you'll find:
http://www.bmwm5.com/vbulletin/searc...der=descending
I know of one member (540is) that installed the Sachs Peformance kit on his supercharged 540i. We've not heard much since the install on its performance.
I did have one California speed shop discourage me from trying the Sachs kit, as they said it likely would require some machining of the dual-mass flywheel to make fit. Sachs is NOT the OE manufacturer of the E39 M5 clutch--that job belongs to LuK.
If I had to make some changes on my own dime, I likely would go with an uprated Sachs clutch (can't beat the price on dial-a-clutch) and some aftermarket lightened flywheel like Dinan or UUC. I believe that would give me the missing 'hook-up' back, along with a more positive clutch engagement.
Good luck, and let us know what you find out. BTW, once you find your best price on anything Sachs, I would give the guys at Adirondack Auto Brokers a call to see if they can beat it. They are a great resource for Sachs clutches and Mintex pads (also Sachs). www.germanautoparts.com
BOTH SOLD!!
'00 Carbon Black/Black All-Leather/Sportive
#101421
Kinesis K-58s full polish ~ StopTech 355mm BBK ~ KW var.2 coilovers ~ Dinan 17mm adj. rear swaybar ~ SuperSprint exhaust and X-pipe ~ UUC s/s and Rogue tranny mounts ~ a/d/s/ 2x10 a-series subwoofer ~ MTX Class D monobloc sub amp ~ MBQuart component drivers ~ Hardwired V1 & BCT-12 ~ Schroth Rallye 4 harnessbelts ~ M-Technic brake ducts ~ Angel Eyes
Teutonaddict is offline
post #9 of 10 Old 26th March 2003, 02:12 AM Thread Starter
Reflex55
Reflex55's Avatar
Thanks for all the information. I'll also have to read the posts from the search. I'm sure I'll have more questions, so don't go away.
-Brembo 355mm Discs
-H&R Coils
-ACS SS
Reflex55 is offline
post #10 of 10 Old 26th March 2003, 07:57 AM
mweel
mweel's Avatar
Check this thread out..
Were still waiting for UCC's test results of their clutch.
//MWEELS
http://www.bmwm5.com/vbulletin/showt...ghlight=clutch
mweel is offline
M5 Purchase. Advice needed. vadim E39 M5 and E52 Z8 Discussion 11 29th September 2003 02:28 PM
Anyone know the exact pressure needed to depress a stock clutch pedal? B-Pac E39 M5 and E52 Z8 Discussion 0 9th September 2003 02:38 PM
Urgent advice needed! jack880 E34 M5 Discussion 6 19th August 2003 06:13 AM
TECH: attention, clutch afficianados.... Teutonaddict E39 M5 and E52 Z8 Discussion 16 13th May 2002 05:01 AM
Advice needed: Lexus SC300 for M6, Should I Trade? chunpng E39 M5 and E52 Z8 Discussion 18 1st February 2002 10:30 PM
