Vanos Oil Leak and Pictures - BMW M5 Forum and M6 Forums
 7Likes
post #1 of 54 Old 10th March 2013, 08:58 AM Thread Starter
clee911
I posted back in December 2012 about having an oil leak from my Vanos and have still been unable to resolve it. Previous post:
https://www.m5board.com/vbulletin/e39...-question.html
After doing some more analysis, this is what I have discovered in this video from my driver's side Vanos piston cover:
E39 M5 Vanos Leak - YouTube
As you can see in this picture below, oil is leaking through this cover. I grabbed the pictures off of ///M5 touring to illustrate my points. There seems to be some gaskets shown in the red arrows. Can these be responsible for the leak and can they be replaced? The Vanos seems healthy other than this severe leak as I am not getting any codes and the Vanos rattle is minimal. The solenoid O rings have already been changed. Has anyone else experienced this problem or can provide some insight? Thanks.
James
clee911 is offline
post #2 of 54 Old 10th March 2013, 10:07 AM
tradin1
tradin1's Avatar
tradin1 is offline
post #3 of 54 Old 10th March 2013, 02:22 PM
Sailor24
Sailor24's Avatar
First I fixed your link, Second you were told the last time you asked that is was the oring. There is no gasket at your arrows but at my arrows there is an oring.
Name:  solenoid and piston.jpg
Sailor24 is offline
post #4 of 54 Old 10th March 2013, 06:23 PM Thread Starter
clee911
Already tried replacing those o rings, but am still getting the persistent leak. Any other ideas?
clee911 is offline
post #5 of 54 Old 10th March 2013, 06:36 PM
Sailor24
Sailor24's Avatar
If the oring has been replaced then it could be to small a cross section or there are scratches on either of the surfaces that the o ring bares against. The oring is the thing that keeps the oil in nothing else.
Sailor24 is offline
post #6 of 54 Old 10th March 2013, 07:16 PM
D-RodM5
D-RodM5's Avatar
Use some of the red silicone sealant stuff?
/// M5
Umnitza VXX
BeastPower Brackets
Schmiedmann Blck Chrm Grills
AFE Power Air Filters
XPEL Protection Film
StopTech ST-40
TimmayTips
Bilstein PSS
Evolve Alpha-N
D-RodM5 is offline
post #7 of 54 Old 10th March 2013, 07:35 PM Thread Starter
clee911
Thanks sailor, will look for scratches on the surfaces.
D-rod, that's the plan B for now as we wanted to understand the problem before going that route.
Thank you all for the responses.
James
clee911 is offline
post #8 of 54 Old 10th March 2013, 10:43 PM
Sailor24
Sailor24's Avatar
How hard was it to get the cap back on? If it was easy try one cross section size up on the oring. Not sure if silicone can take the pressure but is worth a try.
Sailor24 is offline
post #9 of 54 Old 11th March 2013, 01:59 AM
tradin1
tradin1's Avatar
tradin1 is offline
post #10 of 54 Old 11th March 2013, 07:46 AM Thread Starter
clee911
Thanks, will have to try those options. My mechanic has created a custom gasket for now so I am crossing my fingers. Time to tackle the valve cover gasket and oil separator next.
clee911 is offline
Vanos Oil Leak Help ! M5 E60 ukheman E60 M5 and E61 M5 Touring Discussion 21 20th December 2018 03:50 AM
Advice: Oil Leak from Vanos Units? sfm5 E39 M5 and E52 Z8 Discussion 6 25th July 2012 01:39 PM
Pictures of the Vanos line oil leak? rayt E60 M5 and E61 M5 Touring Discussion 8 25th December 2005 04:53 AM
oil leak, but not vanos line dyc1077 E60 M5 and E61 M5 Touring Discussion 1 15th December 2005 12:50 AM
$4k Vanos Oil Leak dagone E39 M5 and E52 Z8 Discussion 12 11th March 2005 06:01 AM
