exhaust temp sensor - BMW M5 Forum and M6 Forums
LinkBack Thread Tools Rate Thread
Old 1st August 2012, 08:54 PM Thread Starter
shaunmal
exhaust temp sensor
hi been checking for error codes and the scanner threw up exhaust temp sensor fault,looked on realoem and looks likes it is an obselete part,any ideas where i could obtain this part? all connection seem good so must be the sensor thanks
shaunmal is offline
Old 1st August 2012, 09:28 PM
M5 London
M5 London's Avatar
If the car has been in the dealer network at any time since 2001 there is a good chance that EGT sensor is being ignored, via updated DME Software, I think.
So it is very interesting that you are seeing a code. What is the code number please ?
F06 M6 Gran Coupe 2015 - Imperial Blue Xirallic / Silverstone Merino
E39 M5 1999 - Carbon Black Metallic / Caramel Nappa Heritage Leather - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
E34 M5 1995 - Arctic Silver / Black Leather
E30 M3 1987 - Diamond Black Metallic / Black Leather
M5 London is offline
Old 1st August 2012, 10:01 PM Thread Starter
shaunmal
egt
hi m5 london the code is 4f(079). the car has been serviced by bmw so i'm sure dme has been updated any thoughts
shaunmal is offline
Old 1st August 2012, 10:28 PM
Sailor24
Sailor24's Avatar
Just because it was serviced does not mean they did the update. My car was leased from a BMW dealer, they owned it. They sold it when it was five years old, but never did one update nor did one recall, but I am sure they billed for them all. Go to a dealer with you vin and ask them to check if the software/egt delete was done.
Sailor24 is online now
Old 16th October 2012, 04:43 PM
Rog
Rog's Avatar
Did you ever get any closure on this, I have recently run into the same issue where the sensor wiring has broken, throwing up a fault on the scanner. Obviously the same as you when I looked up a replacement part, I fell into the same predicament you are in, can't replace the sensor and suspect the update has not been done.
I have two questions:-
1) Should i just go to the dealer and ask them to clarify?
2) What does the sensor actually do on the old software and will it throw a light (mine is already on because of something else so i can't tell if the sensor fault would throw the light or not).
FYI car is an early facelift Nov 2000 model.
Facelift E39 M5 Velvet Blue Individual
'Cosworth fanatic & M5 lover'
Rog is offline
Old 16th October 2012, 04:49 PM
nerio02
nerio02's Avatar
look in to the e46 m3 egt sensor, i suspect that one willfit our cars but not sure though.
maybe its a alternative for our discontinued ones
with kind regardes
nerio02/dominique
nerio02 is offline
Rate This Thread
IATS sensor / Outside temp sensor? Biofreak E39 M5 and E52 Z8 Discussion 15 6th September 2010 06:54 AM
Outside temp sensor michael9218 E39 M5 and E52 Z8 Discussion 10 7th June 2008 05:19 AM
Replacement/removal of exhaust temp sensor (EGT) Johannesp E39 M5 and E52 Z8 Discussion 1 21st June 2006 07:56 PM
TEMP SWITCH AND TEMP SENSOR imolaman E39 M5 and E52 Z8 Discussion 3 10th June 2006 11:38 PM
Temp. Sensor Nene E34 M5 Discussion 3 21st June 2002 08:30 PM
