Bimmernav MP3 Player - Solution for Aux Input - BMW M5 Forum and M6 Forums
 7Likes
post #1 of 20 Old 29th April 2012, 06:18 PM Thread Starter
Diny
Diny's Avatar
After much experimentation and a few weekends, I finally have an auxiliary jack in the dash. I've had a phone mount for a while but I couldn't get music or any other kind of audio (navigation instructions, trapster, etc) out of the car's speakers. I have a car that was made in the year 2000, so I don't have the aux jack from the 2003 models.
My first attempt involved the tape deck hack, which basically re-routes the tape signal into an aux jack. This is done by tapping 4 cables (positive and ground for left and right channels) on the back of the head unit (it doesn't matter if it's 4:3 or 16:9 because the harnesses are the same). I tried this but the volume was too low. I got a pre-line driver without much success and feared that sound quality wasn't gonna be that great. I believe that cars are some of the worst places in which to be an audiophile, but I don't want any hissing.
Any of the other solutions (dice, intravee, etc) didn't fit the bill because I'd have to run something to the front anyways. All I want is an aux jack because I play music through my phone. I didn't mind losing the CD player because I'd rarely use it if I had an aux jack.
As such, I stumbled upon the Bimmernav MP3 player. This looks like it might do the trick. It also has ipod connectivity but I'm not a fan of apple and ipods, so I'll be having none of that in my car. However, it might be handy for some of you. These are the materials that I used for the installation:
Amazon.com: Mediabridge - 3.5mm Male To (2) RCA Stereo Audio Cable - (25 Feet) [New design accomodates smartphone / mp3 cases]: MP3 Players & Accessories
Amazon.com: "2 x RCA Male / 1 x 3.5mm Stereo Female, Y-Cable, 6 inch": Electronics
Amazon.com: Hosa GRA101 RCA Female to RCA Female Coupler: Electronics
Amazon.com: StarTech.com MU1MMS2RA Slim 3.5mm Right Angle Stereo Audio Cable - M/M (1 Feet): Electronics
The ideas was to install the 3.5mm female in the dash and then run the cable to the back and into the aux jack of the mp3 player. I saw a few installs with a 3.5mm male cable dangling from the dashboard and I wasn't a big fan of that. I didn't take any pictures during the install, but it was pretty straight forward.
I installed the jack on the little trim piece by the fog light switch. I have my phone mounted on the top air vent, so it made sense to have it there. I also fabricated a little stainless steel surround to have it go with the rest of my accent pieces.
I tried to run the cable through the center console but I wasn't able to lift the carpet that's immediately behind the air vent right in front of the back seats, so I ran the cable through the bottom of the driver's side (right by the door). The cable went behind the gauges, down through the footrest (where the hood latch is) and all the way down to the back nicely tucked with the rest of the wire harnesses (which are also run through here). I had to remove a few trim pieces to tuck everything nicely but it was worth it).
Installation of the MP3 player itself is pretty straight forward. Unplug the CD player and plug the 2 cables into the cd player adapter. The only thing I had to do was tap positive power from the phone harness (you can find the info on the instructional video that Bimmernav provides). Here are some pictures of the finished install:
As you can see, I have an aftermarket amp (and speakers) but this should work with the DSP amp as well. The mp3 player is tiny and I just used double-sided tape to secure it to the face of the amp. Some of the cables that you see there may not look familiar. They are from my custom audio setup, so don't be confused.
Here's the aux jack without anything hooked up to it.
Here's the phone hooked up. I used a 1ft 3.5mm cable. The phone attachment that I'm using is for the Motorola Droid from ProClip. I like having it mounted there because I can keep the phone cool by blowing coo air directly to it and it's easy to view. They have tons of attachments. It's a 2-piece unit. One bit attaches to the car and another is for your specific phone. If you change phones, then you only need to get one piece of the puzzle.
Here's the rest of the setup.
Here's a picture of the phone in landscape mode running a GPS program (GPS Test). This one won't talk but you can see how it looks in horizontal mode.
PROS:
1) I finally have an aux input! It looks great and it works great.
2) Sound is excellent and I can tweak it from my phone. I use the app called Poweramp and it's the best mobile music player I've used. It's only $5 but it gives you a ridiculous amount of options and features. You can try it for free for 2 weeks. I find it very useful while driving because I can just swipe the screen to change the song (side to side for track and up and down for artist/folder).
3) If I want, I can also use an SD card or USB memory stick (which will take priority over the aux input) and I can treat those just like the cd changer. 6 folders instead of CDs and songs inside of each. I haven't played with this setting because I'll never use it. Again, I only use the aux input.
CONS:
1) The only con is that this has introduced an incredibly faint alternator whine. I know that it's coming from the unit because it's gone as soon as I unplug it completely. It's more evident after 3.5k RPMs. However, it's only noticeable if you don't have any music playing. Having some music playing (even at the lowest volume) will completely mask it. This is a non-issue because the work-around is so simple. I tried a few filters without much success, so I just tweaked my amp a bit and I'll just have some music playing (if only at low volumes). I can't tell if people with DSP amps will have this issue, but I suspect that they will. I'm sure that I can tackle the issue more but I don't think it's worth it at this point. It's far from an annoyance.
2) While installation of the player was a breeze, running the cable from the front to the back proved to be very time consuming. But hey! At least I got to know the car a bit more by taking it apart some.
Overall, very pleased and I'd definitely recommend this solution.
Thanks for looking!
Fighting Oil Threads since 2007
Diny is offline
The Following 4 Users Say Thank You to Diny For This Useful Post:
chowdah (29th April 2012), josiahg52 (30th April 2012), smaglik (27th September 2012), sor118 (30th April 2012)
post #2 of 20 Old 30th April 2012, 01:20 AM
bdsmitty88
bdsmitty88's Avatar
Very well done Diny. You have classy taste in modifications to your car.
When I want to play music from my phone I just use the old tape deck to 3.5mm jack. Works well, little messy, but works. Unfortunately there is no such thing as a good headphone jack from a smart phone. Every phone I have owned cannot isolate noise from the phone jack, to its internals.
So, for now I just use the ipod setup. Although, the convenience of the android OS is much better for downloading and playing music so I would like a better interface at some point.
2000 BMW m5 Carbon Black Metallic / Full Black Leather / Aluminum Trim
Matte Black Kidneys - Monochrome Trunk/Hood Roundels - Monochrome Trunk Badge - Slimms Finned Rear Diffuser: Matte Black
545 SSK - IATS Relocation
Full Interior / license plate LEDs
BBS RS-GT Diamond Black / Polished Lip
Muffler Delete
Evolve Alpha-N tune
60K Miles 8/15/12
bdsmitty88 is offline
The Following User Says Thank You to bdsmitty88 For This Useful Post:
Diny (30th April 2012)
post #3 of 20 Old 30th April 2012, 01:41 AM
AlBundy
AlBundy's Avatar
You interior looks GREAT! Really like red stitching with that trim. I am jealous. Car looks brand new in those pics.
Do you ever sit in those seats and touch the steering wheel?
AlBundy is offline
The Following User Says Thank You to AlBundy For This Useful Post:
post #4 of 20 Old 30th April 2012, 02:53 AM Thread Starter
Diny
Diny's Avatar
Interesting point about the noise isolation. I can't say that I've noticed any, though. Maybe I'm thinking of different things. There's no hiss in sound at all.
Thanks! I like the overall black with the very dark blue of the cubic trim. I just offset it with some red accents here and there plus the orange lights from the dash and center-console. Actually, the steering wheel is beat to hell. After 12 years and 124k miles, it's not in the best shape. I'm gonna get a new one later this year along with the new suspension (in order to make it seem like a more radical change). The driver's seat is just fine but the passenger one is even better. I'm having a problem of some lower back pain after driving for about an hour that I'm not able to solve. I know for a fact that it's position because I don't have that problem in the Mini. I'll see what I can do or I'll just sell the seats and get some Cobra Misanos
Diny is offline
post #5 of 20 Old 30th April 2012, 03:08 AM
AlBundy
AlBundy's Avatar
I think I know that pain.
If I lose memory and someone moves the seats, mirrors, and wheel, I am sore for a week or two.
It takes me forever to get that position right again and it drives me nuts. I kinda start with the seat and side mirrors then follow up with steering wheel. I can see the tach completely with my left eye and the steering wheel blocks it a little for my right eye. But, with both eyes opened the tach looks complete. Eventually, I get the rear view mirror set so I don't have to move my head too much to see what I want.
Then, after that, I ride it out for about a week making small tweaks to the seat. This may sound crazy, but otherwise I OCD over this and can't find a comfortable position and my back gets sore.
Anyways, love the look! Great color combo (even though this is not "show your interior thread")!
AlBundy is offline
post #6 of 20 Old 30th April 2012, 04:52 PM
bmwMcrzy
bmwMcrzy's Avatar
bmwMcrzy is offline
post #7 of 20 Old 30th April 2012, 04:56 PM Thread Starter
Diny
Diny's Avatar
Originally Posted by bmwMcrzy View Post
Your interior looks great! Feels like you hired an interior decorator
The pictures only show the front. I have carbon fiber drapes in the back window and alcantara throw pillows in the backseat. Some potpourri in the rear ashtrays, too.
Diny is offline
post #8 of 20 Old 30th April 2012, 05:10 PM
spiicytuna
You cannot say all of that and not provide pictures :-P
spiicytuna is offline
post #9 of 20 Old 30th April 2012, 06:05 PM
bdsmitty88
bdsmitty88's Avatar
GTFO!!!
You had me going until the throw pillows. I am growing ever more fond of that cubic trim. Does it get dirty easily...smudges and such? I like my Aluminum trim a lot, and wouldn't consider anything else, other than maybe this cubic trim. Purchased OEM or wrapped?
Are you making it to Timmayfest or are you doing F1 stuff? I would like to have a look at your stereo setup
Muffler Delete
Evolve Alpha-N tune
60K Miles 8/15/12
post #10 of 20 Old 30th April 2012, 06:37 PM Thread Starter
Diny
Diny's Avatar
GTFO!!!
What? They're secured so that they don't move around during spirited driving.
The trim is glossy so it behaves like most glossy stuff if you touch it. I don't touch it and just wipe it off with a microfiber towel every time I clean the interior. I got it from Slimmbones and it was a used kit. I polished it a bit to make it better. The center console has 2 nicks in it that can't be fixed, but it's no big deal. You can't wrap it.
I'm going to Montreal this year. Next year, I may skip Montreal and go to TimmayFest since we'll be having F1 in New Jersey, so we'll see. I'm going with my father this year, who hasn't been to an F1 race in almost 4 decades (his last race was at Watkins Glen here in NY).
Diny is offline
NAV DVD Player as an MP3/Music Player? Copper E60 M5 and E61 M5 Touring Discussion 0 18th October 2009 08:19 PM
Connecting MP3 player to aux input? ChuckRoberts E39 M5 and E52 Z8 Discussion 1 2nd October 2006 10:25 PM
M5 MP3 Player 33steve E60 M5 and E61 M5 Touring Discussion 44 19th October 2005 08:25 AM
Apple IPOD/mp3 Aux input Installation arnolds E39 M5 and E52 Z8 Discussion 9 15th January 2002 04:58 PM
