ESS 96mm vs 92mm pulley - BMW M5 Forum and M6 Forums
 7Likes
post #1 of 28 Old 24th March 2012, 08:20 PM Thread Starter
jselig
Okay so we all know the 92mm pulley gets us about ~8lbs of boost. But without proper cooling the engine will pull timing and knock. So with the advice from a very smart man I have gone back to my 96mm pulley until my meth kit arrives.
But here is what I am wondering. Yes the 92mm pulley makes more boost and more power but does the 96mm pulley bring the power on slightly sooner due to the larger size?
jselig is offline
post #2 of 28 Old 24th March 2012, 08:57 PM
ECB
ECB's Avatar
No, just the opposite. The 92 will start building boost at a lower rpm because its spinning faster.
03 M5 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C 88mm pulley, Supersprint headers and Race cats, Eisenmann Sport Exhaust, Nick G / CES Motorsport tune,
Aquamist HFS-3 water methanol injection, Rogue SSK w/ RP Synchromax fluid, fog light delete,
H&R Springs, Dinan 17mm rear sway bar, TCD sway bar brackets, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, 70W High beams,BSW Speaker Upgrade & 10" Sub
04 M3 Jet Black/Black Nappa/6 spd
Max PSI Turbo, Aquamist HFS-3 water methanol injection
Rogue Exhaust dump valve, Eisenmann Race Muffler
Rogue SSK, H&R springs, Koni Yellows, Squared 18's
07 Porsche 911 Turbo/Slate Gray/6 spd
ECB is offline
The Following User Says Thank You to ECB For This Useful Post:
herrubermensch (24th March 2012)
post #3 of 28 Old 24th March 2012, 09:08 PM Thread Starter
jselig
jselig is offline
post #4 of 28 Old 25th March 2012, 12:01 AM
M5_MONSTER
And you will need larger injectors and a tune too, watermeth will help reduce and elevate knock and cool the extra heat generated by the smaller pulley, but overall you need to get more fuel in there and with 315cc it isnt going to happen at top end. When i installed my bigger pulley even with 50/50 water meth it wasnt running right, it was knocking and it actually felt slower, or less smooth and linear throughout, did lots of dyno runs and remapped the ecu moved to 450cc and job done I know alot of people run with 315cc and bigger pulley but the s62 engine is very resilient to knock and it was only from moving back and forth from 96mm to 92mm and doing lots of dyno runs with monitoring AFR's EGT's and AIT's and other parameters that i found out what was going on. But very wise moving back to the 96mm, it will run alot cooler
M5_MONSTER is offline
post #5 of 28 Old 25th March 2012, 03:25 PM
RUFM5
Shill account for CNS Racing
When you purchase the ESS 550 kit and request the 92mm upgrade what does ESS supply? 92mm pulley and tune only? What about the 450cc injectors? Do they have a tune for the 450cc injectors or only the 315cc?
Shark Injector RACE Version 93 (Tuned By Jim Conforti)
CNS Racing Power Clutch kit - Oversized 10.5 Inch Carbon Metallic disk w/ lightweight Dualmass flywheel(DINAN S3 Design w/ zero gearlash noise)
Supersprint Headers with JETHOT coating (Extreme Sterling)
CNS Racing Cat-Back Exhaust
OZ Racing Superleggera III Bright Silver Wheels 19x9-2.5"lip, 19x10-4"lip - three piece forged.
Evosport Under-Drive Audiophile Pulley Kit
Custom Magnaflow High Flow Metallic CATS (#59926)
Innovative LM1 Wideband Air/Fuel ratio kit
Powerflex Front Thrust Arm and Sway Bar bushings
Cool Ride Thermal Reflective Panel under Air Plenum
Stoptech/SportStop slotted rotors with Axxis Deluxe pads
Bavauto Teflon Stainless steel brake lines
MB Quart Reference RUA213 Component Speakers, 12inch Kicker Subwoofer, RF AMP and XM Radio
Peake R5/FCX(II), Compaq PDA PocketPC OBDII realtime OBDpro Serial Scantool
Euro Clear headlights, 8K Xenon, Predator Angel Eyes Rings, Clear bra, Lamin-x, Euro Smoked tail lights
UFM IATS Relocator
Pro BEL RX65 Radar Detector direct wired and BLINDER Laser Jammer.
AFE Pro Dry S Intake with custom RAM air ducts
UMNITZA sink drain brake cooling grill
Carbon Fiber rear diffuser, front kidney grill and front Hamann look lip spoiler
Hamann DTM rear spoiler
Solargard 5% Tints, Ultimate Cup Holder, Full LED interior lights and exterior blinkers, Clear Bra
CNS Racing 3.62 Differential, suspension and sway bar upgrade
Royal Purple Synchromax.
CNS Racing Oil Separators/10W60
UUC RK6A-L knob
Alutec Strut Bar
RUFM5 is offline
post #6 of 28 Old 25th March 2012, 05:00 PM
M5_MONSTER
ESS sell the kit with the 96mm, if you request the 92mm with smaller belt it invalidates your warranty. They have only two tunes one with headers and one without, they do not have a tune for the larger pulley and they only supply 315cc injectors
post #7 of 28 Old 25th March 2012, 08:06 PM
RUFM5
If you were going to do it all over again with ESS and want the most SAFE 500+whp what would you recommend?
UFM IATS Relocator
UUC RK6A-L knob
Alutec Strut Bar
RUFM5 is offline
post #8 of 28 Old 25th March 2012, 09:04 PM
Ransidd
Ransidd's Avatar
If you are getting a water/meth kit, there's no need for larger injectors if you go with the 92mm pulley as long as you run at least a 50/50 mix by weight, not volume. A true 50/50 mix will make your A/F ratio run rich by ~1 pt.
For example, if you're running a 92mm pulley without meth inj and have an A/F ration of 13, with a 50/50 mix meth inj, it will drop to 12. more if you do a higher concentration of meth. Alot of people forget that 50/50 isn't just adding water for cooling, but also meth, which in itself is a fuel. People get thier cars all the time without the meth, then wonder why they lose power when they spray. It's because now thier tune is running rich.
I would recommend a larger capacity fuel pump, or at least a boost-a-pump application for additional safety.
Modding is addictive....supercharging is a gateway drug. Now im hooked on Meth. Just say NO to mods!
ESS CAI/92mm @9psi
HFS-6 Aquamist 50/50 Methanol Injection .7 x2 primary/.3 precompressor
Howerton Engineering 2 gallon LED tank, Kenne Bell Boost-a-Pump,
Brecus/SBC Stage 4 Extreme clutch, SS clutch pivot, TIAL 50mm Blow Off
19X10/19X11 DPE-S20 with 275/285 Hankook Ventus V12,
Stoptech brake kit: F/R crossdrilled/slotted rotors, pads, SS brake lines, Motul 600 fluid
BLACKED OUT: VIS GTR hood, vinyl roof, Hamann replica spoiler, and DJC rear diffuser
Armor tinted smoked headlights & tailights, E60 SSK w/ZHP shift knob .
Umnitza Predator ICS V3 6k HIDs, DICE IPOD
Ransidd is offline
post #9 of 28 Old 25th March 2012, 10:49 PM
M5_MONSTER
If i was going to do it all again then i would do the below:
1. Bigger injectors
2. 92mm Pulley
3. Custom tune
4. CCV Bypass
5. Silcione Hose Intake
6. CNC Plenum Plates
7. Intercooler
8. Watermeth spraying on and after intercooler
9. AIT Relocation too the intercooler after pipe to reduce heat soak
10. Overall better hose clamps and silicone pipes
The ESS kit is not a bad kit, but with anything us humans buy, we think of ways too improve and make the kit better and more safe
post #10 of 28 Old 26th March 2012, 12:23 AM
RUFM5
Why not install larger injectors and get it retuned by say Evolve? Maybe the meth would not be needed if the fuel levels are fine on 8 psi?
Installing a 92mm pulley on a 96mm tune wouldn't be ideal as it seems this is what folks getting the 92mm pulley are doing?
Maybe even getting the ESS 525 kit, add the 92mm pulley, meth 50/50, 450cc injectors and a new Evolve tune?
UFM IATS Relocator
UUC RK6A-L knob
Alutec Strut Bar
RUFM5 is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
JmoneyM5
ESS pulley/belt issues I've been talking about MABM5 E39 M5 and E52 Z8 Discussion 6 16th June 2011 12:32 PM
Need ESS 92mm and belt part numbers/Vendor Ransidd E39 M5 and E52 Z8 Discussion 10 8th April 2011 10:00 PM
ESS 92mm pulley belt size? mikeoski E39 M5 and E52 Z8 Discussion 29 15th September 2010 02:33 AM
Quick ESS pulley question leem5 E39 M5 and E52 Z8 Discussion 5 7th August 2010 06:30 AM
ESS 92mm pulley upgrade ?s mikeoski E39 M5 and E52 Z8 Discussion 3 30th March 2010 10:32 PM
