Spark plugs for ESS supercharged cars? - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 48 Old 25th December 2011, 12:36 AM Thread Starter
Cerberus
Cerberus's Avatar
What plugs are you guys running in your ESS supercharged cars? Is there a better choice than the factory recommended one?
Cerberus is offline
post #2 of 48 Old 25th December 2011, 07:04 AM
rated ///M
rated ///M's Avatar
I just run the ngk bkr6eix.
Need work done on your ///M by a fellow enthusiast in the Atlanta area? Please send me an email.
alex(at)alexautoinc.com www.alexautoinc.com
2002 BMW M5 TiSi ESS Supercharged @ 10psi. 580WHP 460WTQ
2014 BMW 328d black/black. (Girlfriends beast )
rated ///M is offline
post #3 of 48 Old 25th December 2011, 09:29 AM
tacoma330ci
If you're tra king it or have the potential for running lower octane fuels you can run one range colder plugs...
tacoma330ci is offline
post #4 of 48 Old 26th December 2011, 10:51 AM Thread Starter
Cerberus
Cerberus's Avatar
Is this OE replacement?
I run 93 octane only.
I was planning on running a couple HPDE's a year, but I have concerns the supercharged cars will experience too much heat soak due to the extended high RPM running on the track. Most likely my car will relegated to street use only.
Anyone here run their ESS car at track events?
Cerberus is offline
post #5 of 48 Old 26th December 2011, 04:12 PM
rated ///M
rated ///M's Avatar
It's the same heat range as OEM except its iridium.
post #6 of 48 Old 26th December 2011, 06:11 PM
gsfent
gsfent's Avatar
I run one range colder. It is a stock plug for late model 911's. I believe the engine designation is "H6". Also used in some JCW Mini's.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #7 of 48 Old 27th December 2011, 02:26 AM Thread Starter
Cerberus
Cerberus's Avatar
Did you notice any difference in comparison to the factory heat range?
Cerberus is offline
post #8 of 48 Old 27th December 2011, 02:33 AM
gsfent
gsfent's Avatar
Hard to notice any difference unless you are doing some type of controlled tests. Let's say I didn't notice any negative results and I feel the one range colder gives me some protection for when I am getting on the supercharger for multiple runs or hard use which increases oil and water temps.
gsfent is offline
post #9 of 48 Old 27th December 2011, 03:22 PM
herrubermensch
herrubermensch is offline
post #10 of 48 Old 27th December 2011, 03:34 PM
mattmartindrift
mattmartindrift's Avatar
Originally Posted by herrubermensch View Post
I run Denso Iridium IK24s--two ranges colder than stock.
--Peter
different ignition coils, too. right?
mattmartindrift is offline
spark plugs.. honeyM5 E39 M5 and E52 Z8 Discussion 24 23rd November 2010 12:57 AM
Spark plugs replaced (pics of old plugs included) D-RodM5 E39 M5 and E52 Z8 Discussion 4 15th November 2010 05:45 AM
Spark Plugs kosmo E39 M5 and E52 Z8 Discussion 35 24th December 2007 06:11 PM
spark plugs civic eater E39 M5 and E52 Z8 Discussion 10 12th April 2007 10:38 PM
Spark Plugs? V-10 4 Me E39 M5 and E52 Z8 Discussion 3 26th February 2003 03:09 AM
