Ugh..Broken TPS Bolt...now what? - BMW M5 Forum and M6 Forums
post #1 of 13 Old 15th October 2011, 08:02 PM Thread Starter
cab
cab's Avatar
Sometimes you are the hammer, sometimes you are the nail...
Ss part of my jerky throttle triage I decided to pull the two TPS sensors off, which of course meant battling the phillips head TPS screws. First side gave me some issues and I ended up have to dremel/chisel off the head of the bolt. Once the TPS was out of the way (slid off after that) I just unscrewed the threads....no biggie. Second side (left) was similar, first bolt came out OK, but second was was just stripping so I tried the dremel. Tighter fit this time and I just get a notch in it, so I decide to just whack the head off with the chisel like I did with the other side...cr*p - it broke alright - INSIDE THE THROTTLE BODY! Now I have three options:
1. Reinstall with just one screw - note I can tell it won't hold tight and will probably move around, probably not an option.
2. Pull the number 8 throttle body only and just extract it and/or retap as necessary - this requires disturbing what I am calling a "stop screw" (see pic). I could "count" the number of turns it takes to remove it and dupplicate when I re-install.
3. Pull all 4 throttle bodies on that side, leaving them "connected" to each other (if that is even possible) in order to avoid disturbing the throttle adjustment screws.
Here is the stop screw I am referring to (red arrow). There is one between each of the throttle bodies.
Any adice is greatly appreciated. I feel like my job is to fix my car, and my car's job is to stop me!
cab is offline
post #2 of 13 Old 15th October 2011, 08:08 PM
leviathan
leviathan's Avatar
did it break off flush or inside of the hole? if inside, you'll have at least a few threads to screw into with a truncated bolt and loctite
leviathan is offline
post #3 of 13 Old 15th October 2011, 08:14 PM Thread Starter
cab
cab's Avatar
flush (of course). I tried screwing the other bolt in there to see if it would catch even one thread...nope. :<
cab is offline
post #4 of 13 Old 15th October 2011, 08:43 PM Thread Starter
cab
cab's Avatar
Hmmm...after looking at the throttle bodies more closely, I don't think they are "connected" per say by the linkage, just positioned with intertwined linkage. Each throttle body's linkage has a tab that is "clamped" to the next by a spring loaded "stop" and the actual stop screw. I think can actualy slide the tab out (it would snap shut of course, w/o disturbing the set screw, but it might be a bear to reinsert it (space is tight). Option 2 seems to be where I am headed...will wait to see if anyone else has a suggestion.
Thanks!
cab is offline
post #5 of 13 Old 15th October 2011, 08:44 PM
Burnout_187
Burnout_187's Avatar
Burnout_187 is offline
post #6 of 13 Old 15th October 2011, 10:30 PM Thread Starter
cab
cab's Avatar
Update to my own saga. All 4 throttle bodies are off - You can't really remove one as the giant avuuem tube that connects them all together prevents it. On the upside, it also keeps everything together. If I didn't already have all my fuel injectors out for cleaning, this would have been a huge pain. I had to drill the old bolt out, but I actually appear to have soem deeper threads left which I may be able to use...investigating a tiny heli-coil option now. Good times.
(p.s. needless to say, I will be giving the tb's a good cleaning while they are off).
cab is offline
post #7 of 13 Old 16th October 2011, 02:49 AM
68FB
This is a good example of why I hate Phillips head screws! They are the reason impact screwdrivers had to be invented.
Just in case you need to replace the TPS's again (God forbid), maybe use Allen head screws?
68FB is offline
post #8 of 13 Old 16th October 2011, 03:11 AM
jt2ma71
jt2ma71's Avatar
Next time break them loose with vise grips then use the bit to unscrew it. Trying to loosen it with the phillips becomes pointless because 90% of the time it just strips.
2003 E55 AMG - Obsidian Black/Black, Eurocharged ECU reflash, 84mm SC pulley, CM30 IC Pump, FTP Heat exchanger, Needswings Dual CAI, Custom exhaust, Forgestar F14's, Lowering links, E63 Spoiler, CF Front lip
2000 BMW M5 - Alpine White/Silverstone Extended Leather/BBS LMs 245.35.19, 285.30.19/Evolve Alpha-N/Tubi Exhaust/AA Intake/Ducts/Dinan Springs - RIP
2001 Yamaha R6 - Yamaha Blue, Yamaha GYT-R Exhaust, Factory Pro +4 Ignition Advance, Factory Pro Jet kit, 03R6 Airbox/Filter, Clear Alternates and fender eliminator, puig windscreen, Yamaha Solo seat, APE CCT
2000 Durango SLT+ - 5.9 V8, 3.92 LSD, 32x11.5 BFG All Terrains, Airaid intake, Hughes F1 Airgap, SCT Tuner, Flowmaster 50 Series, Fully rebuilt 46RE, 2" torsion lift
Glock17 9x19|Vz.58 7.62x39|Mossberg 500
jt2ma71 is offline
post #9 of 13 Old 16th October 2011, 03:43 PM
nightkrawler
nightkrawler's Avatar
as you've realized you cannot remove just one throttle, they have to come out as a set. might as well remove both sets and clean them, they get really cruddy. b12 chemtool spray and a toothbrush works really well for cleaning them. also a good time to clean the intake valves. with the throttles removed you have good access to them. take a look down there with a flashlight, im sure a lot of the valves are covered with carbon. manually rotate the engine so that the valves on the cylinder you're working on are closed. then spray some cleaner down there, i like castle hydroblast and the b12. also need something to scrape the carbon off with, use something made of plastic or hardwood, nothing metal.
nightkrawler is offline
post #10 of 13 Old 16th October 2011, 04:53 PM Thread Starter
cab
cab's Avatar
Yeah, once I saw how nasty this side was it is sort of hard not to justify doing both sides...in for a penny, in for a pound I guess.
cab is offline
Broken Oil Filter Bolt Replacement getbent E39 M5 and E52 Z8 Discussion 4 2nd September 2010 08:48 PM
TPS? I can't see anything Elekta E34 M5 Discussion 4 27th April 2008 11:14 AM
TPS bad- car in shop- can I do tps sensors myself? Please help!! SatanicPanda E39 M5 and E52 Z8 Discussion 3 10th January 2008 01:21 AM
UGH - SUV Broken Into (long) :( dmcgibbo E39 M5 and E52 Z8 Discussion 4 7th August 2001 05:55 PM
