Center support bearing replaced now I'm getting a ticking noise from the center console! - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 21 Old 22nd March 2012, 10:36 PM
meepmeep
At lower speeds (cruising in neighborhoods) a metallic clanking may be indicative of e-brake shoes that have come apart inside the drum. Try gently lifting the e-brake, just enough to cause a bit of tension, while you hear the noise and see if it goes away.
meepmeep is offline
post #12 of 21 Old 22nd March 2012, 10:50 PM
mediaboy
I had the same ticking noise and my fix from my local tech was having the drive shaft rebuilt. Not sure exactly what on the drive shaft was causing it.
mediaboy is offline
post #13 of 21 Old 22nd March 2012, 11:32 PM Thread Starter
madyspop
Already handled, changed out the aftermarket lugs and went back to OEM, wallah problem solved!
02 Dinan S2 M5 Sterling Grey/silverstone sport interior w/titanium trim
Dinan S2
Evolve Alpha N Tune
19" BBS RS-GT w/Continental DW
Dinan/Brembo 4 wheel big brake kit with Euro brake ducts
Lidatek laser diffuser
V1 w/hidden display
3M tinted windows and clear bra
Color matched bumper, side moldings and grill
Euro headlights with 6000K ultinon bulbs
UUC 11" clutch and lightweight flywheel, DSSR, EVO 3 short shifter, black tranny mounts
AC Shnitzer aluminum pedals
Kenwood HD9980 7" head unit
Hertz Mille 6 1/2" Comps
Hertz Mille 5 1/4" Comps
JL 10w6V2
JL HD900/5
madyspop is offline
post #14 of 21 Old 23rd March 2012, 12:42 AM
Lunker325
Lunker325's Avatar
Good follow up info, thanks guys. Tried pulling up on the ebrake, no difference.
On the way home today I found how to make the ticking louder. Was taking a right handed off ramp at speed and the noise got much louder the tighter I made the turn. I'm thinking the center support bearing as it is seems to be directly under the center console.
2002 M5 Sterling Grey / Silverstone - Sold
2011 E90 M3 Jerez Black / Fox Red - Current
Lunker325 is offline
post #15 of 21 Old 23rd March 2012, 01:01 AM
rao
I don't want to scare you, but if the noise gets louder when turning I would be taking a close look at the diff. does it make the noise when you turn the other way? Go to a parking lot and do some low speed figure 8s and see if the noise is there.
The center bearing will make noise from a stop as it allows the driveshaft to rise up.
If you find this post unsatisfactory, please add me to your Ignore List so you will not be disappointed again in the future.
---> https://www.m5board.com/vbulletin/pro...?do=ignorelist
Rob
Prior - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Older - 92 325i with Chevy 6.6 LS2/T-56 Power
Oldest BMW - 95 M3 with Chevy 6.6 LS2/T-56 Power
rao is offline
post #16 of 21 Old 23rd March 2012, 02:45 AM
mattmartindrift
mattmartindrift's Avatar
Wheel bearings can do what you described. So can loose heat shields and a ton of other underbody stuff.
Do you think the kinetic energy (KE), of an object, can be stated mathematically as being equal to half the mass (of the object) multiplied by the square of the object's velocity (KE=(1/2)m*v^2)?
Originally Posted by Sailor24 View Post
....no.
physics is hard.
Do you even science!?
mattmartindrift is offline
post #17 of 21 Old 23rd March 2012, 06:20 PM
Lunker325
Lunker325's Avatar
Strange that the noise is not present during the morning drive, only on the last half of the afternoon drive home. Doubt it is the diff or anything in the rear of the car, noise is no doubt coming from the center of the car. It is in the very early stages right now, I'm sure it will get worse and be easier to pinpoint. I'll be doing shocks and struts soon and will take a look at things when it is up in the air.
post #18 of 21 Old 13th April 2012, 04:36 AM
VinboTom
Have the same problem, but all I did was swap the snow tires/rims and summer tires/stock rims. Summer tires are new Continentals, Extreme Contact DW (stock size). One thing is that the Indy did use the lugs from the snow tires, not the OEM lugs..
Any help is appreciated
VinboTom is offline
post #19 of 21 Old 8th May 2019, 05:41 AM
Dkarabas
Dkarabas's Avatar
Bump....
Having same problem it sounds like.
I recently installed spacers....sounds like its coming from under/in front of the center console....removed front spacers, and aftermarket lugs, the clicking is still there.
Dkarabas is offline
post #20 of 21 Old 8th May 2019, 10:54 PM
josiahg52
josiahg52's Avatar
Wheel bolts can protrude excessively through the hub flange and make noise.
josiahg52 is online now
Who has the best prices on parts, and what all do I need to buy if I'm going to replace my center support bearing? madyspop E39 M5 and E52 Z8 Discussion 4 28th October 2010 06:47 PM
Driveshaft/center support bearing noise solved KevinM E39 M5 and E52 Z8 Discussion 10 3rd October 2010 11:59 PM
Center support bearing B10 BT apbails ALPINABoard.com | BMW Alpina Discussion 1 29th April 2008 06:26 PM
Center Support bearing issues...or?? BmwNut E39 M5 and E52 Z8 Discussion 4 14th April 2008 10:04 PM
Giubo and center bearing replaced, now what... Larry's M5 E39 M5 and E52 Z8 Discussion 8 17th June 2007 08:51 PM
