My Carbon Black bare metal respray - progress photos - Page 5 - BMW M5 Forum and M6 Forums
 34Likes
post #41 of 81 Old 30th August 2011, 10:33 AM Thread Starter
M5 Sydney
M5 Sydney's Avatar
A quick update...
I just saw the car and doors are painted and on, but it's not in a great place to get a photo at the moment. I'm now waiting on a parts order before they can reassemble. I'm replacing the obvious external trim pieces new Hella headlight covers and the gloss black door frame window trims as well as a broken rear quarter blind.
Just before the car went in for this work it began running roughly and I found some Vanos codes. So as soon as it's back I will do the following repairs myself:
- general service including spark plugs, spark plug cover gaskets, TWS oil and all filters
- replace leaking power steering hoses
- replace vanos o-rings & front dust gasket, plus test and repair solenoid pack
- replace 4 x CPS
- replace thermostat and all crankcase breather hoses, plus clean out oil separators
- while plenum is removed, replace all accessible vacuum hoses and fuel tank breather valve
- clean throttle bodies
- drain radiator & block & replace coolant with BMW coolant & demineralised water
- replace misc items ordered
I've already flushed brake / clutch fluid, gearbox & diff oil, and replaced MAFS. After this, I'm not spending any more on it except TWS & filters!!!
Parts list is attached:
QuantityPartsPart No.MANUFACTURER
1BOOT LID BADGE M51142694404Genuine BMW
1BOOT LID BADGE 551142693189Genuine BMW
1REAR SCREEN MOULD51318159785Genuine BMW
1FRONT SCREEN MOULD51318159784Genuine BMW
1SUNROOF SEAL54107245551Genuine BMW
1HOOD BADGE - BMW51148132375Genuine BMW
1TRUNK BADGE - BMW51148203864Genuine BMW
1N/S/F DOOR TOP FRAME MOULD / SHINEY51322427409Genuine BMW
1O/S/F DOOR TOP FRAME MOULD / SHINEY51322427410Genuine BMW
1O/S/R DOOR TOP FRAME MOULD / SHINEY51342427412Genuine BMW
1N/S/R DOOR TOP FRAME MOULD / SHINEY51342427411Genuine BMW
1N/S/F DOOR VERTICAL MOULD51327890087Genuine BMW
1O/S/F DOOR VERTICAL MOULD51327890088Genuine BMW
1O/S/R DOOR VERTICAL MOULD51347890090Genuine BMW
1O/S/R DOOR VERTICAL MOULD/QTR GLASS51347890092Genuine BMW
1N/S/R DOOR VERTICAL MOULD/QTR GLASS51347890091Genuine BMW
1N/S/R DOOR VERTICAL MOULD51347890089Genuine BMW
1LOWER LEFT ENGINE COMPARTMENT COVER51712694899Genuine BMW
1LOWER RIGHT ENGINE COMPARTMENT COVER51712694832Genuine BMW
1AIR BRAKE CHANNEL FRONT LEFT51117890013Genuine BMW
1AIR BRAKE CHANNEL FRONT RIGHT51117890014Genuine BMW
1MOULDING ROCKER PANEL FRONT LEFT51112494193Genuine BMW
1MOULDING ROCKER PANEL FRONT RIGHT51112494194Genuine BMW
1MOULDING ROCKER PANEL REAR LEFT51122498501Genuine BMW
1MOULDING ROCKER PANEL REAR RIGHT51122498502Genuine BMW
1FOG LIGHT, LEFT63172228613ZKW (OEM)
2ADJUSTING ELEMENT, HEADLIGHT63120027924MTC (AFT)
INTERIOR
1WAIST RAIL TRIM STRIP, INT. LEFT REAR - GLANZBLACK51222694047Genuine BMW
1 LEFT REAR DOOR SUN BLIND - DUNKELGRAY51168176167Genuine BMW
1 SUN BLIND SUPPORT51168191679Genuine BMW
1 LEFT SUN BLIND SUPPORT51168202819Genuine BMW
GENERAL SERVICE
2PROFILE-GASKET11121406744Genuine BMW
6RUBBER SEAL11121721879REINZ (OEM)
1DRAIN PLUG RADIATOR17111712339Genuine BMW
2GASKET RING - A14X20-AL07119963225Genuine BMW
8SPARK PLUG, HIGH POWER - NGK BKR6EQUP12129071003NGK
2AIR FILTER ELEMENT13721736675MAHLE
1MICROFILTER (2 per box)64319069927BOSCH
1 HOUSING LOWER PART LEFT MICROFILTER64318379625Genuine BMW
POWER STEERING
2GASKET RING - A14X20-CUSN32411093596OEM
1SUCTION HOSE32412228873BURGAFLEX
2O-RING - 10,82X1,78/FPM17211742636OEM
1RETURN PIPE32412228868BURGAFLEX
VANOS
2 PULSE GENERATOR, CAMSHAFT12147539173Genuine BMW
2PULSE GENERATOR, CAMSHAFT13627796054Genuine BMW
4 O-RING - 17X312141748398REINZ
2 GASKET ASBESTOS FREE11361406838Genuine BMW
8 O-RING11367830828Genuine BMW
8 O-RING11367830829Genuine BMW
CRANKCASE VENTILATION
1VENT HOSE - ZYL. 1-411151406952CONTITECH
1 VENT HOSE - ZYL. 5-811151406953CONTITECH
1 RETURN HOSE - ZYL. 1-411151407344Genuine BMW
1RETURN HOSE - ZYL. 5-811151406902Genuine BMW
1 RETURN HOSE11151406900Genuine BMW
THERMOSTAT
1THERMOSTAT - 79CEL11537835558BEHR
1GASKET RING11531312287Genuine BMW
4 O-RING - 31X2,5MM11531406249Genuine BMW
2O-RING - 18,3X3,6MM11531407002Genuine BMW
VACUUM CONTROL
1ELECTR.VALVE11741742712PIERBURG
1 NON-RETURN VALVE11611312737Genuine BMW
1VACUUM HOSE BLACK - 3,5X1,8 (meter)11727545323Genuine BMW
2 HOSE11727837591Genuine BMW
1 HOSE11727837592Genuine BMW
1FUEL TANK BREATHER VALVE13907830766Genuine BMW
MISC
1FINAL STAGE UNIT64116923204OEM
1REAR CAN HOLDER51168249707Genuine BMW
M5 Sydney is offline
post #42 of 81 Old 30th August 2011, 01:12 PM
M B34ST
I've got to say, a most impressive result so far. I'm really looking forward to catching up with you, Stu, Ben and all the other Sydney/NSW based board members sooner rather than later. Can't wait to see the finished result in person.
Is the shop doing your work in Alexandria? My wife thinks she recognises it from the photos. She thinks it is the massive prestige repair shop on McEvoy St.
M B34ST is offline
post #43 of 81 Old 30th August 2011, 03:40 PM Thread Starter
M5 Sydney
M5 Sydney's Avatar
Very close - it's at Panel One on O'Riordan St Mascot. Likewise looking forward to catching up with the other Sydney board members as soon as possible! Incidentally I'd like to pass on a massive thanks to Stu M5 for all his help with my parts order and for getting me a great deal via his contact at BMA. I'd be lost without the support of board members
Nick
post #44 of 81 Old 31st August 2011, 01:31 PM
StuM5
No worries Nick. I'm sure Yves at BMA Parts will get it all sorted for you.
Looking forward to seeing your reborn beast!
cheers mate
Stu
Silverstone Blue
Evolve AlphaN and Power Map
IATS Relocation kit
Iforged Imola wheels F19x9 & R19x10
SS Headers
Tubi X-pipe and mufflers
E60 545 Short Shifter
Black Kidney grills
Exotic Tuning Rear Diffuser
Exotic Tuning Fog Covers
196,000kms @March 2013.
StuM5 is offline
post #45 of 81 Old 16th September 2011, 09:01 AM Thread Starter
M5 Sydney
M5 Sydney's Avatar
So my parts have all arrived from the US, and will they will start fitting it up mid next week. Hopefully will be finished the following Friday. I'm going to spend Saturday morning fixing my headlight adjusters and fitting the new lenses so I can drop them off next week. Getting excited now! I'll get some updated photos once they get the car down from their mezzanine storage floor and post next week.
It's a shame it's not really driveable until I sort the Vanos out, but I have all the parts so will get straight onto it.
post #46 of 81 Old 16th September 2011, 11:18 AM
ur20v
ur20v's Avatar
ur20v is offline
post #47 of 81 Old 16th September 2011, 12:20 PM
RICKROSS
RICKROSS's Avatar
wow, fantastic to see the whole process and the extra shiny end result coming together, you need to enter a club concourse soon after...
make sure you use it often and don't turn it into a garage sculpture!
RICKROSS is offline
post #48 of 81 Old 6th October 2011, 09:57 AM
M B34ST
M B34ST is offline
post #49 of 81 Old 12th October 2011, 07:46 AM Thread Starter
M5 Sydney
M5 Sydney's Avatar
Guys,
Sorry that updates have been a bit slow. It's still in the shop believe it or not, but I think will be out this week!! They have been taking their time (and I haven't rushed them), and there was a delay on some of the parts that they ordered via the insurance (I think they got the wrong side mirror). I've seen the car and it was 90% back together last Thursday and they had all the parts, but couldn't get a great update photo to post.
It still needed buffing and apparently was going back into the paint booth so they could blow in around the boot / bonnet apertures and over front guard bolts that had been disturbed etc. Should be an amazing job, and I'll post an update with photos as soon as I have it back.
Nick
post #50 of 81 Old 12th October 2011, 10:42 AM
ur20v
ur20v's Avatar
ur20v is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
tammer in philly
Looking for photos of exterior mods on Carbon Black Glenn in Encinitas E39 M5 and E52 Z8 Discussion 9 3rd October 2010 05:58 AM
Carbon Fiber Upgrades in progress... [removing iDrive trim?] DoctaM3 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 17 15th June 2008 08:59 AM
E34 Bare Metal Respray UK Johnnym5 E34 M5 Discussion 9 7th August 2007 12:03 PM
Carbon Black Photos (750+) PurePassion Gumball 3000 Forum 11 10th October 2006 09:44 PM
