DIY: Vanos Solenoid Repair - Page 18 - BMW M5 Forum and M6 Forums
 37Likes
post #171 of 179 Old 18th February 2019, 10:32 PM
Sailor24
Sailor24's Avatar
The one I originally found is near identical to the one you found except has a much higher voltage rating. Again I don't know which is right,I am not an electrical engineer. What I a have read however is that the voltages produced from magnetic pintle devices like our solenoids produce very high voltages but with no amps/watts in them.
Again the problem is no one who really really knows has said. I have also found a type of mov that looks identical but I am inclined to agree it is likely a diode. My answer has always been to put and old original on a board, but I have a few spares that I guard.
Sailor24 is offline
post #172 of 179 Old 19th February 2019, 11:57 AM
[email protected]
Originally Posted by gzig5 View Post
I'm cheap. I added the grub screws into my old covers rather than buying new covers. I got my screws from McMaster-Carr or I think you can get the OEM ones. Just find the approximate center of each counterbore and drill and tap. A little of the low strength thread locker can be added for peace of mind. Haven't had any solenoid issues since.
Do you have the exact dimensions/ Length of these grab screw? is it a 6mm or 7mm screw ? and what about the torque value, it is near 16Nm right? i will also update my covers using the same procedure
post #173 of 179 Old 19th February 2019, 01:44 PM
Clemster
I have updated cover sets available and can ship Internationally.
https://www.m5board.com/vbulletin/pa...ub-screws.html
2003 Carbon Black on Caramel
ESS SC
Aquamist w/ Custom Howerton Tank
Supersprint Headers - X-pipe - Eisenmann Race
Dinan Wheels
Stoptech
3.45 Dinan Differential
CNS 10.5" clutch
Many more cool mods courtesy of Steve!
Clemster is online now
post #174 of 179 Old 19th February 2019, 05:11 PM Thread Starter
gzig5
Part #6
RealOEM.com - Online BMW Parts Catalog
I don't remember the specs but it was an M10 or M12 diameter fine thread.
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is offline
post #175 of 179 Old 19th February 2019, 06:02 PM
Ibmotoren
Ibmotoren's Avatar
Here it is, from your post a few years back-
The covers are easy to modify if you have a drill press or a milling machine. I probably wouldn't try it with a hand drill. I modded my covers a couple years ago. The screw spec is M12 x 1.25 thread with 12mm screw length. I got the screws from McMaster Carr. The OEM screws have a dab of loctite/sealant on the thread is the only difference. I simply put some blue loctite on the threads as I installed them and they are still tight.
I'll modify your existing covers for $40 each plus return shipping if you are interested. That covers the modification and the screws.
This is what they look like.
From this thread-
https://www.m5board.com/vbulletin/e3...ml#post3960386
2001 ///M5 ...Anthracite / Black Complete-Heritage
Ibmotoren is offline
post #176 of 179 Old 20th February 2019, 09:09 AM
[email protected]
i found this DIY it is very helpful thanks to TommeH
https://www.m5board.com/vbulletin/e3.../topics/201120
post #177 of 179 Old 20th February 2019, 09:12 AM
[email protected]
sounds great but i live in Lebanon, the shipment of these items will cost a lot i think
at what price you are selling both covers?
post #178 of 179 Old 20th February 2019, 11:53 AM
[email protected]
i also noticed that you may have a set of complete working solenoid boards, do you have any of the version 1.4 and above now?
email me at: [email protected]
post #179 of 179 Old 20th February 2019, 03:55 PM
Clemster
I have at least 3 complete working boards and all are V1.4. $475 + payment fee (if any) shipped to Lebanon. Can include update set of covers for another $75.
ESS SC
Dinan Wheels
Stoptech
CNS 10.5" clutch
Vanos solenoid seals Dr. Vanos vs OEM replacement? blackwagon E39 M5 and E52 Z8 Discussion 18 24th January 2011 07:31 PM
throwing vanos solenoid codes on new solenoid pack Msentinel E39 M5 and E52 Z8 Discussion 0 16th June 2010 04:14 AM
Vanos Solenoid - anyone use Dr. Vanos to repair? reds2 E39 M5 and E52 Z8 Discussion 3 2nd March 2010 04:01 AM
VANOS Solenoid everycredit E39 M5 and E52 Z8 Discussion 7 15th August 2008 08:20 PM
Vanos Solenoid vs Complete Vanos Replacement SoCaLE39 E39 M5 and E52 Z8 Discussion 5 4th June 2008 09:42 PM
