DIY: Vanos Solenoid Repair - Page 17 - BMW M5 Forum and M6 Forums
 37Likes
post #161 of 179 Old 27th April 2018, 05:12 PM Thread Starter
gzig5
I'm cheap. I added the grub screws into my old covers rather than buying new covers. I got my screws from McMaster-Carr or I think you can get the OEM ones. Just find the approximate center of each counterbore and drill and tap. A little of the low strength thread locker can be added for peace of mind. Haven't had any solenoid issues since.
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is offline
The Following 2 Users Say Thank You to gzig5 For This Useful Post:
[email protected] (15th February 2019), Essixtytwo (29th April 2018)
post #162 of 179 Old 15th February 2019, 02:29 PM
[email protected]
post #163 of 179 Old 15th February 2019, 03:35 PM
[email protected]
Hi all, i own an M2000 E39 M5 since 2007, as usual and since day one i have a problem with the solenoid valve board, but lately i have done a huge mistake when i was trying to clean the oil path inside the solenoids and i have manage to kill 3 of these MOV or diodes (using a 12V battery)
anyone have any idea about the part number or anything related?
still the mystery of these diodes or MOV haven't been solved yet
post #164 of 179 Old 15th February 2019, 05:17 PM
xrviz
xrviz's Avatar
Post #144
Those are the MELF style. I also found the same specs in a standard end-wire style diode somewhere.
xrviz is offline
The Following 2 Users Say Thank You to xrviz For This Useful Post:
post #165 of 179 Old 15th February 2019, 07:56 PM
[email protected]
post #166 of 179 Old 15th February 2019, 08:23 PM
Sailor24
Sailor24's Avatar
Have you not seen this? There is a part number in the writing on the mid right. I am not saying that getting a Melf stye would not be ideal, it is just there is no real track record for them being in a bunch of cars. This standard diode that is recommended by Gzig has been tested in many cars and has been proven to work. It is your safe bet. 1N4148
Name:  Vanos Board Schematic_V3.jpg
Sailor24 is offline
post #167 of 179 Old 15th February 2019, 08:52 PM
[email protected]
During a lot and i am saying a lot of discussion between you sailor24, gigz and others (believe me i went threw all of these discussions and it was alot of reading), it seams that the debates did not ends and the type of the original type of diodes/MOVs still not quiet clear
so excuse me for asking again and i know that you did made a lot of effort to find the type of these MOVs, using the suggested diodes have been tested and the still working after some miles on it?
thank you sailor for effort
post #168 of 179 Old 15th February 2019, 09:13 PM
xrviz
xrviz's Avatar
Yes the debate continues.
It is NOT an MOV. The circuit is a simple flyback diode circuit. There's no need for an MOV plus if you google image MOV you will see they all look kind of like capacitors, nothing like these. The stock unit is a MELF (i.e. surface mount) diode.
If you look at the physical size, band colors, and surface mount package, it fits best with the BYM10-1000.
https://www.vishay.com/docs/88546/bym10-xxx.pdf
A lot of people have used the 1N4148 supposedly without issue.
https://www.vishay.com/docs/81857/1n4148.pdf
However, look at the difference in repetitve peak reverse voltage suppression: 100 vs. 1000.
Personally I would not use the little ones. Why risk spiking your ECM?
xrviz is offline
post #169 of 179 Old 16th February 2019, 07:03 PM
Sailor24
Sailor24's Avatar
There is no debate I am pretty sure I know what it is, 68 was pretty sure he knew what it was, but no one has bought that part put in a car and tested it over the long haul.
This part you keep telling people is right has not been in a car. 68 was skeptical, I think you are pretty close, but I also found the correctly colored with identical look of the ones you found but they had different properties. I can't tell someone to use them, even though I know they will work perfect, I have not tested them. I know the ones you found will work but have not been tested, so I am not telling anyone to put them in their car.
The original substitute works and are safe, I know this from all the people that have put them in. If they are installed backwards they blowup but there is no damage to the rest of the system. What happens with your part if someone installs it backwards?
Sailor24 is offline
post #170 of 179 Old 18th February 2019, 08:13 PM
xrviz
xrviz's Avatar
Dunno. Maybe it would blow up, maybe it would fry the DME. So you like the small diode because it's idiot proof and has a track record. That's fine. However, BMW spec'ed in the larger one to be on the safe side long term perhaps. The little one may burn out over time, which puts the DME transistors at risk. Or maybe their engineers know something we don't know. How many volts/amps can the noids produce when they aren't switched off? I watched a 1N4148 go up in smoke with just a 9V smoke alarm battery connected to it.
Whoever first tried the 1N4148 used what he had laying around I suspect. It's one of the widely used generic diodes anywhere.
I would be interested in seeing the component you found if you still have it. I know for sure it's not an MOV though.
xrviz is offline
Vanos solenoid seals Dr. Vanos vs OEM replacement? blackwagon E39 M5 and E52 Z8 Discussion 18 24th January 2011 07:31 PM
throwing vanos solenoid codes on new solenoid pack Msentinel E39 M5 and E52 Z8 Discussion 0 16th June 2010 04:14 AM
Vanos Solenoid - anyone use Dr. Vanos to repair? reds2 E39 M5 and E52 Z8 Discussion 3 2nd March 2010 04:01 AM
VANOS Solenoid everycredit E39 M5 and E52 Z8 Discussion 7 15th August 2008 08:20 PM
Vanos Solenoid vs Complete Vanos Replacement SoCaLE39 E39 M5 and E52 Z8 Discussion 5 4th June 2008 09:42 PM
