DIY: Vanos Solenoid Repair - Page 13 - BMW M5 Forum and M6 Forums
 37Likes
post #121 of 179 Old 27th February 2016, 06:54 PM
Sailor24
Sailor24's Avatar
Originally Posted by liquidsmoke View Post
Was there a consensus for good replacement diodes/movs? My electrical knowledge ends with wiring a plug.
Not yet but the best guess seems to be diode1N97, there are still some unanswered questions? Some questions I still don't understand, so not sure if they have been answered.
Originally Posted by Bigmitch117 View Post
OK, so what is the correct power supply to be used in testing the solenoids?
Still working on that question but it appears a 9V battery is safe, except that when you are cleaning the noid and holding it open for a long time you might want to desolder one side. Protecting the diode is the reason for this.
That said I have always used an old charger for a flip phone. It puts out around 5v and much lower amps, think it is 2 amps. The issue is burning out the diode and the more watts you put through the more likely that is. The diode is rated at 150 watts non continuous and a 9V battery has 4 amps so that is 36 watts. W=AxV . A 5v charger at 2 amps is only 10w, much safer.You can use a voltage as low as 3.2v but the lower you go the less force applied. Force helps dislodge the crud.
Sailor24 is offline
post #122 of 179 Old 27th February 2016, 08:23 PM
liquidsmoke
what would happen if you used a spare car battery to test the noids? In theory?... Lol.
liquidsmoke is offline
post #123 of 179 Old 27th February 2016, 10:37 PM
Sailor24
Sailor24's Avatar
You would likely burn the diode and maybe even the noid if you held the power on for more than a millisec. 12v x ~1000a = 12000 watts well over the spec of the diode but I am sure over the noids rating too. Would not burn up the noid instantly but as the wire got hot who knows what would happen.
Sailor24 is offline
post #124 of 179 Old 27th February 2016, 10:49 PM
Bigmitch117
Bigmitch117's Avatar
I actually just finished servicing the the solenoids today. I used a 9 volt battery to test the noids. Seemed to work pretty well and I could tell a huge difference in the way they sounded before and after cleaning. Tomorrow I will reinstall the unit with new seals and hope the vanos rattle noise goes away.
Bigmitch117 is offline
post #125 of 179 Old 27th February 2016, 11:08 PM
Sailor24
Sailor24's Avatar
Word of advice that is not in the DIYs. Once you have the board in, rotate the noids so the wires are tightish. This will prevent the wires from getting pinched when the cover goes back on. Also oil up the o rings to make the install easier. Recently there have been a few torn on the install.
Sailor24 is offline
post #126 of 179 Old 27th February 2016, 11:18 PM Thread Starter
gzig5
I've used a 12v current limited lab supply as well as a 9V battery with no issues. I've not tried the car battery but even a weak one can supply a couple hundred amps for a short period of time. I remember at least one member saying that he burned the mov/diode using a car battery, so no theory there.
The thing to remember is that the solenoid is fed a PWM signal at some frequency. That means the RMS voltage is somewhat less than the supply voltage which affects the power being dissipated. All in all a 5-9 VDC supply seems to be the safe way to go.
When I catch up on my honey-do list, I'll throw the 0-scope on the solenoids and capture some signals at different rpm ranges. Look for the report in about five years...
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is offline
post #127 of 179 Old 28th February 2016, 01:24 AM
68FB
I would clarify that to say a current-limited 5-9 VDC supply. That's the great thing about the 9V (smoke detector-type) battery - it self-limits to a maximum of ~4A when dead-shorted.
Malcolm
68FB is offline
post #128 of 179 Old 28th February 2016, 01:32 AM
Sailor24
Sailor24's Avatar
Sailor24 is offline
post #129 of 179 Old 28th February 2016, 02:05 AM
68FB
Originally Posted by Sailor24 View Post
You have said that before, but how? All that is in there is 6 quad A batteries?
You mean how is it so high or how is it so low?
If you have 10A scale on your DMM, try it.
68FB is offline
post #130 of 179 Old 28th February 2016, 02:16 AM
Sailor24
Sailor24's Avatar
No, I mean what is limiting it? Is it just what those batteries can output? I have taken tons apart because quad A are the same length as triple A. I never noticed anything but was not looking, or maybe I did notice and ignored what I saw.
Sailor24 is offline
Vanos solenoid seals Dr. Vanos vs OEM replacement? blackwagon E39 M5 and E52 Z8 Discussion 18 24th January 2011 07:31 PM
throwing vanos solenoid codes on new solenoid pack Msentinel E39 M5 and E52 Z8 Discussion 0 16th June 2010 04:14 AM
Vanos Solenoid - anyone use Dr. Vanos to repair? reds2 E39 M5 and E52 Z8 Discussion 3 2nd March 2010 04:01 AM
VANOS Solenoid everycredit E39 M5 and E52 Z8 Discussion 7 15th August 2008 08:20 PM
Vanos Solenoid vs Complete Vanos Replacement SoCaLE39 E39 M5 and E52 Z8 Discussion 5 4th June 2008 09:42 PM
