Back at the drag strip with the ESS Beast! - BMW M5 Forum and M6 Forums
 19Likes
post #1 of 79 Old 26th March 2011, 04:10 PM Thread Starter
Clemster
As some of you may remember, my last trip to the track was a quest for 11's. I was fortunate enough to squeak out an 11.95 with drag radials on the stock clutch. Yesterday I was back for the record, which is held by Kelster's S3 at 11.79. I won't lie, I wanted it. Even if it's just for a short time until someone with some serious power makes it to the strip.
I have since upgraded to the Brecus stage 4 Feramic disc and really put it through the paces yesterday. It performed flawlessly and took everthing I threw at it in a dozen or so passes. Thanks, AAron! Only other changes since the last trip to the track was a fog light delete to get more air to filter that is located in front of the right side wheel. Oh, and also the addition of the DSSR to the UUC shift that I thought was stock.
Air temps yesterday ranged from low 40's to low 50's with a favorable DA. Unfortunately yours truly was not as favorable and I botched many passes which I will blame on the nasty head cold, total lack of sleep the night before and just overall feeling like butt. I missed many a shift including one on my best 60' foot of the day. You can clearly hear Matt's disappoinment while shoot the vid of this pass. Classic! And although the new clutch bites hard, take up is more abrupt and takes a little getting used to. At the end of the day I was finally getting the hang of it but my car had enough and we called it a day. A bit of a cross/head wind probably kept my trap speeds down a bit.
In regards to lauching, there is a fine line between getting away clean and being overly aggresive and triggering massive wheel hop. Spinning was not an issue with the DR's lowered to 18 psi and the awesome track prep at MIR. A huge thanks to Ray for the loan of the DR's on those sexy Dinan wheels.
Enough with the excuses and onto the good stuff. Keep in mind, my Beast is stock performance-wise with the exception of the ESS kit.
Some vBox numbers-
0-60 3.6
0-100 8.6
IMO, Not bad for a nearly two ton grocery getter!
Vids and pic courtesy of Matt/SnizM3. Thanks for the footage and encouragement!
My quickest pass.....
Second best....
Best launch with blown 1-2 shift (one of many this day....way off my game) Note Matt's response.
2003 Carbon Black on Caramel
ESS SC
Aquamist w/ Custom Howerton Tank
Supersprint Headers - X-pipe - Eisenmann Race
Dinan Wheels
Stoptech
3.45 Dinan Differential
CNS 10.5" clutch
Many more cool mods courtesy of Steve!
Clemster is offline
The Following 11 Users Say Thank You to Clemster For This Useful Post:
Alpine2002 (29th March 2011), chowdah (26th March 2011), feeblebob (26th March 2011), havasusteve03Beast (27th March 2011), herrubermensch (26th March 2011), jimmythefish (26th March 2011), Kelster (28th March 2011), M5 London (26th March 2011), sor118 (26th March 2011), Vector57 (27th March 2011), wilsodh (27th March 2011)
post #2 of 79 Old 26th March 2011, 04:19 PM
timmay77
timmay77's Avatar
Looks like fun Adam! New PR for you still!
The New Whip:
2003 Sterling Gray/Executive Caramel ///M5 (Name TBD)
~Coming soon! 5.3 LS Twin Turbo Swap. Just another LS swap, but with 2 snails.
The Storm Trooper:
2014 328i xDrive Msport Alpine White/Black Dakota (fully loaded)
~Bootmod3 stage 2~ER Downpipe~ER Charge pipe~BMS Intercooler~351M wheels
Tim ~ email: HallmanTL (at) gmail (dot) com
timmay77 is offline
The Following User Says Thank You to timmay77 For This Useful Post:
Clemster (26th March 2011)
post #3 of 79 Old 26th March 2011, 05:28 PM
chowdah
Super Moderator
chowdah is offline
The Following User Says Thank You to chowdah For This Useful Post:
post #4 of 79 Old 26th March 2011, 05:41 PM
Pagimo
Pagimo's Avatar
Pagimo is offline
post #5 of 79 Old 26th March 2011, 05:43 PM
M5 London
M5 London's Avatar
You just keep getting better Adam !!
Well done man !
F06 M6 Gran Coupe 2015 - Imperial Blue Xirallic / Silverstone Merino
E39 M5 1999 - Carbon Black Metallic / Caramel Nappa Heritage Leather - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
E34 M5 1995 - Arctic Silver / Black Leather
E30 M3 1987 - Diamond Black Metallic / Black Leather
M5 London is offline
post #6 of 79 Old 26th March 2011, 06:05 PM Thread Starter
Clemster
Originally Posted by Pagimo View Post
Sweet !! How much boost are you seeing ?
Thanks! It's hard to say really. Some runs showed over 9 psi, but I think that spike occurred during my burnout. I think I'm seeing around 8 on the track.
Well done man !
I appreciate that, Kumuran. You know first hand that it's not as easy as it looks. Stickies do make it more fun, but create a whole new set of challenges. Frankly, my sketchy driving was the main issue yesterday. Head cold + no sleep = diminished motor skills.
I have to throw this vid in of this insanely fast Viper. I've seen him run many times and still can't comprehend. He let off way early AND got on the brakes and still ran 7.77! The vid doesn't do it justice.
ESS SC
Dinan Wheels
Stoptech
CNS 10.5" clutch
Clemster is offline
The Following 2 Users Say Thank You to Clemster For This Useful Post:
M5 London (26th March 2011), Pagimo (26th March 2011)
post #7 of 79 Old 26th March 2011, 06:51 PM
///Marylander
Thumbs down
Way to go Adam , temps were favorable yesterday but , yes that wind was an obstacle , Matt did a good job with camera . 2 thumbs up !
///Marylander is offline
post #8 of 79 Old 26th March 2011, 06:57 PM
mfizzlenyc
mfizzlenyc's Avatar
congrats!!! your gettin closer and closer to that record!!! The car looks and sounds great going down the track!!!!
again nice job!!!
RIP MFIZZLENYCMOBILE - 12/5/2012 2000 Silverstone M5 extended Leather
213,500 miles !!!!!
Evolve Stage 3 Tune
BBS LMs 19s
Michelin Pilot Super Sports ,StopTech BBK,Dinan Headers, CF Plenum cover with clear windows, Dinan CF -CAI,Dinan Air Mass Meters ,Dinan light weight flywheel,Dinan stage 3 suspension ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
2009 135 "Worlds First Frozen 1ER" ESS stage 2 - 450 HP - SOLD
mfizzlenyc is offline
post #9 of 79 Old 26th March 2011, 07:33 PM
chowdah
Super Moderator
chowdah is offline
post #10 of 79 Old 26th March 2011, 07:36 PM
doe
doe's Avatar
doe is offline
