BC Racing Coilover install and review - BMW M5 Forum and M6 Forums
 6Likes
post #1 of 133 Old 12th February 2011, 05:44 AM Thread Starter
timmay77
timmay77's Avatar
I purchased my BC Racing Coilvers (Type BR, 8k/6k spring rates) from Tristan at Circuit Motorsports. Great guy to deal with. I also purchased the rear extenders for the damping controls. I installed the rears first, the harder of the 2 to do. If you remove the fender liner, it really isn't THAT bad. You just have to remove the caliper, take the upper rear trailing arm loose from the knuckle and disconnect 1 plug to slide the shock/spring assembly out. The fronts are SO EASY it isn't even funny. Once I get the ride heights at all 4 corners squared away, I will do a full review. I am starting my dmapening setting with 10 clicks from full soft in the rear and 15 clicks from full soft in the front.
PS: I am sorry my fender wells aren't as clean as your's Steve. I am sure I could eat a $50 steak off of them if I went into your garage right now......LOL
Rear install:
Rear extender install, you can see where I intended to put the extender knob out through the speaker grill but it bent the cable too much that you couldn't feel the "click" of the settings, so I had to move it up a little. I will just source some new speaker grills to take care of that hole.
The New Whip:
2003 Sterling Gray/Executive Caramel ///M5 (Name TBD)
~Coming soon! 5.3 LS Twin Turbo Swap. Just another LS swap, but with 2 snails.
The Storm Trooper:
2014 328i xDrive Msport Alpine White/Black Dakota (fully loaded)
~Bootmod3 stage 2~ER Downpipe~ER Charge pipe~BMS Intercooler~351M wheels
Tim ~ email: HallmanTL (at) gmail (dot) com
timmay77 is offline
The Following 9 Users Say Thank You to timmay77 For This Useful Post:
Beasty5 (13th February 2011), Clemster (12th February 2011), havasusteve03Beast (13th February 2011), Hdhntr23 (23rd March 2011), herrubermensch (22nd February 2011), Lancefitzgiben (12th February 2011), mkaehly (12th February 2011), Quicksilv3r (30th May 2011), sor118 (12th February 2011)
post #2 of 133 Old 12th February 2011, 06:04 AM
mkaehly
mkaehly is offline
post #3 of 133 Old 12th February 2011, 06:27 AM Thread Starter
timmay77
timmay77's Avatar
Fronts. The only thing I have to gripe about is this:
The manual is HORRIBLY translated. Good Lord is it bad.
Also, in the first picture, this nut is difficult to get on and tighten as you have to use an open end wrench due to the flare of the shock body. No big deal, just be aware of it. You have to thread it on as the ball joint threads are pushed through.
Here you can see the clearance of 9.5" OEM rear wheels on the front. These pictures are taken with the car fully on the ground.
3mm spacer
10mm spacer
The New Whip:
The Storm Trooper:
timmay77 is offline
The Following 4 Users Say Thank You to timmay77 For This Useful Post:
herrubermensch (22nd February 2011), Lancefitzgiben (12th February 2011), Mr.Devere (12th February 2011), NearShadow (16th February 2011)
post #4 of 133 Old 12th February 2011, 07:54 AM
tradin1
tradin1's Avatar
tradin1 is offline
The Following User Says Thank You to tradin1 For This Useful Post:
timmay77 (5th September 2011)
post #5 of 133 Old 12th February 2011, 08:25 AM
M55555
M55555's Avatar
Very nice. Have you had a chance to drive it around?
2001 Carbon Black ///M5
ESS VT1-560 Supercharger System 92mm Pulley
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete V1
Bilstein PSS9 Coilovers + Ground Control Camber Plates
BBS CH 19x8.5F, 19x10.0R
Michelin Pilot Super Sport 245/35F, 275/35R
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
OEM Mud Flaps
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser
SLIMM Front Lip Spoiler
SLIMM OEM Euro Armrest
Audiovox Mediabridge BT Integration
M55555 is offline
post #6 of 133 Old 12th February 2011, 10:43 AM
wkd928
wkd928's Avatar
nice pictorial write up! I should add that in your pics the spring perch collar screws are seperated, the ones at the lower ends of the springs. from my recollection they need to be tightened together to stop the spring working loose. the lower most (gold coloured) shock body collar is the one that gets undone in order to adjust ride height
wkd928 is offline
post #7 of 133 Old 12th February 2011, 11:23 AM
jamiepeers
jamiepeers's Avatar
Timmay.
I too have the extenders and was wondering if you could put them anywhere through the speaker grilles.
Obviously the corner is a no no but do you think you could do it more central in the grille, perhaps where you have positioned the holes in the shelf but a little further back so as they are on the very front edge of the grille??
I was going to do that, or leave them in such a way as they are tucked under the grille itself and i could simply unclip the grille for access to the extender.
Having done the job now do you think any of that is possible as i want to leave the shelf unless its a last resort???
Oh, as a final point, did you undo your hub nut/bolt that clamps the front shock to the hub okay, or was it a PITA??
Jay
jamiepeers is offline
post #8 of 133 Old 12th February 2011, 11:24 AM Thread Starter
timmay77
timmay77's Avatar
Not yet, still adjusting ride height.
Correct. I was in the middle of making adjustments when I remembered to snap a few pictures........
I did notice that when I was making my adjustments, as descibed by, well, everyone, the spring collars came loose that preload the spring, which they shouldn't have. My method of adjustments will be to loosen all 3 collars, adjust threaded collar to desired ride height, preload the spring with the upper collars to 5mm (thickness of the wrench), tighten top collars, then tighten the lower collar. That way I know FOR SURE that I have 5mm of preload on my spring.
The New Whip:
The Storm Trooper:
timmay77 is offline
post #9 of 133 Old 12th February 2011, 11:28 AM Thread Starter
timmay77
timmay77's Avatar
Originally Posted by jamiepeers View Post
Timmay.
I am sure it could be done, but I am not sure you would be able to feel each "click" of the adjuster. Where I had mine it worked, just not the way it was intened too. Look at the picture with the speaker enclosure mounted. You will have to go around that to get where you want to go. That will be your issue.....
I had no problems at all. I had each shock/spring assembly replaced in literally 10 min. SUPER easy.
Jay
Noted.....
The New Whip:
The Storm Trooper:
timmay77 is offline
post #10 of 133 Old 12th February 2011, 01:52 PM
Mr.Devere
Mr.Devere's Avatar
Seems to be a lot of BC action going on lately..............can you confirm that the shock clamp of the wheel carrier is threaded as well as having the lock nut on it, I got the nut off ok, but the bolt is uber tight, I was fearing some internal organ displacement as I was proper hanging off it to get it to budge, soaked in penetrating fluid over night and am going to get a heat source if it still wont budge, I found the rears flew on, albeit with the extra work of the shelf and that but no hassles from the rear, front have been another story..........like your plan to set them up, whats the mileage on your car, what did you think of all the control arms, wishbones etc etc, mine all look OK but its got 110k on it so am considering swapping them out for new but its not cheap............
M5 (black)........
Audi S6 V10 (Stolen)...:
Career Path:
330ci Sport Conv (silver)
Escort Cosworth (silver)
Sapphire Cosworth (2wd) (magenta)
MKI XR4x4 (white)
MKI XR2 (white)
Mr.Devere is offline
BC Racing coilover users - need input Torquey5 E39 M5 and E52 Z8 Discussion 31 19th December 2014 06:45 PM
Torquey5's BC Racing coilover install (with alignment) Torquey5 E39 M5 and E52 Z8 Discussion 65 28th September 2010 06:59 PM
Just finished my GC coilover install. mtrhed E39 M5 and E52 Z8 Discussion 24 30th October 2009 07:54 PM
05 Playersrun with H&R coilover review jl330cic E39 M5 and E52 Z8 Discussion 9 14th June 2005 06:58 AM
Coilover Install in Boston leederek E39 M5 and E52 Z8 Discussion 1 1st June 2002 07:02 AM
