BC Racing Coilover install and review - Page 4 - BMW M5 Forum and M6 Forums
 6Likes
post #31 of 133 Old 26th February 2011, 12:08 AM
gzig5
Originally Posted by timmay77 View Post
Too low? IDK, it seems so......
Drove it around a bit, pretty stiff, but I like it. need to crawl under it and find out if I am rubbing with the 3mm spacers, see if my tape is still there. I didn't drive it hard at all, not until I get my alignment, but just to see if I am rubbing yet.
In my opinion it looks pretty good, but is about 3/8" too low for my taste. I don't think the tire should be hidden behind the fender at the top. Maybe its the angle. I couldn't wait to find out if these fit with the rears up front and got new Koni's and BG springs on sale last year. Still haven't installed them, so maybe I could have waited.
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is offline
post #32 of 133 Old 26th February 2011, 12:16 AM
havasusteve03Beast
havasusteve03Beast's Avatar
Home run Timmay. Doesnt look to low from my perspective, but its your car. Raising it slightly of course will get ride of some of the stiffness.
Cosmetically...Dont change a thing Player.
03 TiAg Biest; 565 RWHP via Dynojet - SOLD
03 CB Biest; 549 RWHP via Dynojet - SOLD
havasusteve03Beast is offline
The Following User Says Thank You to havasusteve03Beast For This Useful Post:
timmay77 (26th February 2011)
post #33 of 133 Old 26th February 2011, 12:43 AM
Lunker325
Lunker325's Avatar
Looks good Tim! Swing by sometime so I can see it in person! Where do you have the shocks set at?
2002 M5 Sterling Grey / Silverstone - Sold
2011 E90 M3 Jerez Black / Fox Red - Current
Lunker325 is offline
post #34 of 133 Old 26th February 2011, 01:39 AM
IRISH M5
IRISH M5's Avatar
IRISH M5 is offline
The Following User Says Thank You to IRISH M5 For This Useful Post:
post #35 of 133 Old 26th February 2011, 02:08 AM Thread Starter
timmay77
timmay77's Avatar
I am starting my dampening settings with 10 clicks from full soft in the rear and 15 clicks from full soft in the front.
The New Whip:
2003 Sterling Gray/Executive Caramel ///M5 (Name TBD)
~Coming soon! 5.3 LS Twin Turbo Swap. Just another LS swap, but with 2 snails.
The Storm Trooper:
2014 328i xDrive Msport Alpine White/Black Dakota (fully loaded)
~Bootmod3 stage 2~ER Downpipe~ER Charge pipe~BMS Intercooler~351M wheels
Tim ~ email: HallmanTL (at) gmail (dot) com
timmay77 is offline
post #36 of 133 Old 26th February 2011, 02:19 AM
Vason
Vason's Avatar
Ride height looks good to me....not too low at all. Maybe it's just the blurry pic but the rear looks a little lower than the front.
'16 M3 Alpine White/Black
'03 M5 Carbon Black/Caramel - Sold
'03 M3 Alpine White/Black - Flooded/R.I.P.
Vason is offline
The Following User Says Thank You to Vason For This Useful Post:
post #37 of 133 Old 26th February 2011, 02:22 AM
SidekickChuck
SidekickChuck's Avatar
Since BC's are a body thru design I don't think the height alters the ride quality.. Its all in the dampener adjustment.
Looks great btw..its not low at all. Pictures might have introduced some shadows etc to make it seem tire tucked, but it clearly is not. In fact, that height is higher than bg springs.
SidekickChuck is offline
The Following User Says Thank You to SidekickChuck For This Useful Post:
post #38 of 133 Old 26th February 2011, 06:07 AM
xr4tic
xr4tic's Avatar
Ride quality can suffer if the car is too low and bouncing off the bumpstops, although I'm not sure at what point that is.
In addition, handling can also be effected by the suspension operating outside of it's normal range of travel. I'm by no means a suspension expert, but depending on the design, your camber curve will change in rate the lower you go. Or, once again, if you're bouncing off the bumpstops.
John Baas
2001 Anthracite Metallic M5
1976 BMW 2002
Interior
Euro Dash, Slimmbones Euro Armrest, Slimmbones Shifter/Ebrake Boots, F10 M5 Illuminated Shift Knob, UUC EVO3 Shifter, UUC DSSR, UUC Clutch Stop, Autolumination Interior LEDS, JBL MS-8, Alpine MRX-V70, Kicker Subwoofers, Polk/Boston Acoustic Speakers
Exterior
Vorsteiner Power Dome CF Hood, Euro Clear Corner Headlights w/Lamin-X, Umnitza Predator Ice V3, Umnitza 6K Headlight + Fog Light Upgrade, Umnitza V4 Side/Turn/License LEDs, CF Roundels, Black Kidney Grills, Slimmbones BigMouth Lower Grill
Drivetrain
Evolve Alpha-N Tuning, Supersprint Headers/Cats/X-pipe + Eisenmann Race Mufflers, VSL Aluminum Radiator, UUC Twin Disk Clutch, Rogue Engineering Trans Mounts
Suspension
Ground Control Coilovers, Dinan Monoballs, Dinan Rear Sway Bar w/Beastpower Brackets, Dinan Front and Rear Strut Bars, BMW Performance Front Brake Kit, StopTech SS Brake Lines, Black Stock Rims Square Setup
Coming Soon
Custom Oil Catch Cans, Zionsville Radiator Shroud, Supercharger!
xr4tic is offline
post #39 of 133 Old 26th February 2011, 06:13 AM
M55555
M55555's Avatar
Looks great, Tim! Don't change a thing.
Just for easy comparison, what is your height front and rear measured from the ground to the fender?
2001 Carbon Black ///M5
ESS VT1-560 Supercharger System 92mm Pulley
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete V1
Bilstein PSS9 Coilovers + Ground Control Camber Plates
BBS CH 19x8.5F, 19x10.0R
Michelin Pilot Super Sport 245/35F, 275/35R
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
OEM Mud Flaps
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser
SLIMM Front Lip Spoiler
SLIMM OEM Euro Armrest
Audiovox Mediabridge BT Integration
M55555 is offline
post #40 of 133 Old 26th February 2011, 06:58 AM
wkd928
wkd928's Avatar
Looks good! My ride height did settle a bit more - maybe another 10mm or so, but it took a few hundred miles.
wkd928 is offline
BC Racing coilover users - need input Torquey5 E39 M5 and E52 Z8 Discussion 31 19th December 2014 06:45 PM
Torquey5's BC Racing coilover install (with alignment) Torquey5 E39 M5 and E52 Z8 Discussion 65 28th September 2010 06:59 PM
Just finished my GC coilover install. mtrhed E39 M5 and E52 Z8 Discussion 24 30th October 2009 07:54 PM
05 Playersrun with H&R coilover review jl330cic E39 M5 and E52 Z8 Discussion 9 14th June 2005 06:58 AM
Coilover Install in Boston leederek E39 M5 and E52 Z8 Discussion 1 1st June 2002 07:02 AM
