BC Racing Coilover install and review - Page 2 - BMW M5 Forum and M6 Forums
 6Likes
post #11 of 133 Old 12th February 2011, 11:43 PM
IRISH M5
IRISH M5's Avatar
IRISH M5 is offline
The Following User Says Thank You to IRISH M5 For This Useful Post:
timmay77 (13th February 2011)
post #12 of 133 Old 13th February 2011, 12:46 AM
Diny
Diny's Avatar
Tim, I expect you to drive these suckers hard and put their durability to the test. Not for track duty, but for the eventual twisties. I should be getting mine in the summer (tied up with the Mini at the moment) so the M5 is taking a rest with mods.
Fighting Oil Threads since 2007
Diny is offline
post #13 of 133 Old 13th February 2011, 01:47 AM Thread Starter
timmay77
timmay77's Avatar
Originally Posted by Mr.Devere View Post
Seems to be a lot of BC action going on lately..............can you confirm that the shock clamp of the wheel carrier is threaded as well as having the lock nut on it, I got the nut off ok, but the bolt is uber tight, I was fearing some internal organ displacement as I was proper hanging off it to get it to budge, soaked in penetrating fluid over night and am going to get a heat source if it still wont budge, I found the rears flew on, albeit with the extra work of the shelf and that but no hassles from the rear, front have been another story..........like your plan to set them up, whats the mileage on your car, what did you think of all the control arms, wishbones etc etc, mine all look OK but its got 110k on it so am considering swapping them out for new but its not cheap............
If you are referring to #3, it IS NOT threaded on my car. I removed the nut and it just slides out. My car only has 63k on it, so everything looks pretty good. I have one ball joint that is leaking a little on the passenger rear so I shot some grease in it and put some silicone on the edges to see if I can make it last a little longer.
Originally Posted by IRISH M5 View Post
Looking good Tim. Now you've no reason not to come to Mid Ohio...
You are correct sir.....
After I get my clutch broke in I plan on driving the hell out of my car this summer. No worries.
The New Whip:
2003 Sterling Gray/Executive Caramel ///M5 (Name TBD)
~Coming soon! 5.3 LS Twin Turbo Swap. Just another LS swap, but with 2 snails.
The Storm Trooper:
2014 328i xDrive Msport Alpine White/Black Dakota (fully loaded)
~Bootmod3 stage 2~ER Downpipe~ER Charge pipe~BMS Intercooler~351M wheels
Tim ~ email: HallmanTL (at) gmail (dot) com
timmay77 is offline
post #14 of 133 Old 13th February 2011, 04:37 AM
havasusteve03Beast
havasusteve03Beast's Avatar
Tim,
As usual, you have done an outstanding job at the install an documentation. Congrats..(Come on Spring!!)
Now, let me say that I am APPAULED at the fact you didnt do a complete detail of the undercarriage area while you were there, at least the fender wells.
I thought I knew you better than that
03 TiAg Biest; 565 RWHP via Dynojet - SOLD
03 CB Biest; 549 RWHP via Dynojet - SOLD
havasusteve03Beast is offline
post #15 of 133 Old 13th February 2011, 06:19 AM Thread Starter
timmay77
timmay77's Avatar
Steve, first off, thank you. If I showed you the rest of the car, you would fly out here and hand my butt to me, trust me. Due to the amount of dust I have created from all of the speaker baffle making and other stereo work, my car is a MESS. While I was waiting for my flywheel, I decided to do other work on the car. Since I could not move it due to it being on jack stands, it collected all of the dust. Plus, I am trying to rush and get everything done! Once I finish EVERYTHING, if there is such a thing, I plan on doing a "HavasuSteve" style cleansing of MCINCO. I will earn back your respect sir.......
The New Whip:
The Storm Trooper:
timmay77 is offline
post #16 of 133 Old 18th February 2011, 01:18 PM Thread Starter
timmay77
timmay77's Avatar
I had a chance to drive it around the block. Once. Then realized the new clutch is not releasing all of the way, so the car is back in the garage with the guts spilled again. I did get a chance to level it out and do some testing with the suspension.
First off, make sure these nuts are tight. Mine were not so I was banging around HARD.
I put some tape on the shock body to test if I would rub with the 3mm spacers. I did not rub, but then again, I just went around the block. I ordered some 5mm spacers just in case. I don't really want to run 10mm spacers in the front unless I have to.
The New Whip:
The Storm Trooper:
timmay77 is offline
post #17 of 133 Old 21st February 2011, 10:14 PM
Bmw2bad0904
Bmw2bad0904's Avatar
Tmmay,
Waiting for the final review on these with how you think the ride is with these and possibly some pics of them set on your car. You think it will be completed anytime soon ? I am going to pull the trigger on theses next week and would like to hear your final review on them
Bmw2bad0904 is offline
post #18 of 133 Old 22nd February 2011, 12:02 AM Thread Starter
timmay77
timmay77's Avatar
Originally Posted by Bmw2bad0904 View Post
Tmmay,
Probably not anytime soon. For one, my transmission is still on my garage floor due to my clutch problems. Also, it is hailing outside right now. I have a feeling I won't be driving the car any time soon. Sorry.
The New Whip:
The Storm Trooper:
timmay77 is offline
post #19 of 133 Old 22nd February 2011, 06:38 AM
ClayMan
ClayMan is offline
post #20 of 133 Old 22nd February 2011, 01:52 PM
leem5
Good call on checking the top nuts, one of mine was 'loose' and the knocking was nasty. All sorted now though.
On another note, with your drive around the block, how did you initially find your settings?
ESS VT550, Hayward & Scott Exhaust with 100 Cell CATs
leem5 is offline
BC Racing coilover users - need input Torquey5 E39 M5 and E52 Z8 Discussion 31 19th December 2014 06:45 PM
Torquey5's BC Racing coilover install (with alignment) Torquey5 E39 M5 and E52 Z8 Discussion 65 28th September 2010 06:59 PM
Just finished my GC coilover install. mtrhed E39 M5 and E52 Z8 Discussion 24 30th October 2009 07:54 PM
05 Playersrun with H&R coilover review jl330cic E39 M5 and E52 Z8 Discussion 9 14th June 2005 06:58 AM
Coilover Install in Boston leederek E39 M5 and E52 Z8 Discussion 1 1st June 2002 07:02 AM
