I INSTALLED THESE STOCK OEM M5 BUSHINGS JUST THE OTHER DAY AND DESIDED I WOULD TAKE PICS AS I WENT ALONG TO POST. NOW I HAD THE ASSISTACE OF A LIFT TO GET MY BEAST IN THE AIR AND THOUGH IT MADE THE JOB MUCH EASIER, YOU COULD JUST DO THIS IN YOUR DRIVE WAY. ( JUST MAKE SURE YOU HAVE A RIDE TO GET YOU TO SOMEONE WITH A PRESS TO REMOVE THE BUSHINGS ) IT WOULD A BIT SILLY STANDING IN YOUR DRIVE HOLDING ON TO YOUR THRUST ARMS IN EACH HAND WITH TEARS IN YOUR EYES :crying:.
ONCE YOU HAVE THE CAR IN THE AIR, MAKE SURE IT'S SECURE, NOW START TO REMOVE THE PLASTIC NOISE DAMPNER.
THEN REMOVE THE SWAYBAR BUSHING BRAKETS 13MM BOLTS...YOU WILL NEED TO DO THIS TO DROP DOWN THE BAR TO GET TO THE 21MM BOLT HOLDING THE THRUST BUSHING.
THEN TAKE TWO 21MM WRENCHES TO REMOVE THE BOLT HOLDING THE THRUST BUSHING IN, ONCE THE NUT IS REMOVED YOU WILL NEED TO MOVE THE WHEEL SIDE TO SIDE TO GET THE BOLT OUT OF THE WAY SO THE ARM COMES STRAIGHT DOWN. THE BOLT WILL NOT NEED TO BE COMPLETELY REMOVED. ONCE THIS IS DOWN THEN MOVE TO THE BALL JOINT.
TAKE A 21MM WRENCH AND START REMOVING THE BALL JOINT NUT, IN MY CASE THE BALL JOINT NEVER SPUN. BUT LIKE ON EVERYONES MIND, THERE IS NO ROOM FOR THE NUT TO COME OFF BECAUSE THE STRUT IS IN THE WAY..RIGHT??? WELL A LITTLE TRICK HERE, I KEPT REMOVING THE NUT UNTIL IT STARTED PRESSURE ON THE STRUT, THEN I TOOK A HAMMER AND TAPPED FIRMLY ON THE HOUSING (IN BETWEEN THE NUT AND THE BALL JOINT) TO BREAK IT LOOSE FROM THE HOUSING. THEN TURNING THE NUT A COUPLE MORE TIMES THE BALL JOINT JUST POPPED RIGHT OUT.
ONCE THE TWO ENDS ARE OUT THE RESULT IS, YOU CAN NOW EXAMINE THE DAMMAGED BUSHING. AND NOW START THE PROCESS OF REMOVING THE BUSHING.
REMOVING THE BUSHINIG IS A BREEZE, JUST MAKE SURE YOU ARE USING THE PROPER SIZE GUIDES SO YOU DONT DRAG IT ALONG THE SIDES WALLS OF THE BUSHING HOUSING. NOTE: HOW THE BUSHING IS IN PLACE BEFORE YOU REMOVE IT, YOU WILL PUT THE NEW ONE THE SAME WAY. ONCE THIS IS DONE THE BUSHING COMES OUT LIKE BUTTER.
NOW ADDING THE NEW BUSHING, MAKE SURE THE ALIGNMENT MARK (ON THE TOP OF THE BUSHING) MATCHES THE ARROW THAT IS MARKED ON THE ARM, BASICLY PUT THE BUSHING BACK THE WAY IT CAME OUT. TAP THE BUSHING TO MAKE SURE IT IS SECURE BEFORE PRESSING, ONCE ITS STARTED IT WILL GUIDES IT'S WAY PERFECTLY...BUTTER. REPEAT OTHER ARM.
HERE IS THE FINISHED PRODUCT ... B E A UTIFUL!!!
NOW INSTALL IN REVERSE.
NO LIE THE INSTALL ONLY TOOK ME 1.5 HOURS.
cherrsagai
cherrsagai
