Vanos solenoid seals Dr. Vanos vs OEM replacement? - BMW M5 Forum and M6 Forums
post #1 of 19 Old 22nd January 2011, 05:52 PM Thread Starter
blackwagon
I've been looking around for the advantages of the Dr. Vanos over the OEM replacements and there is no comparisons except for a member pointing out that the OEM rings have a bevel to them and are not O rings like the ones included in the Dr. Vanos kit. I haven't been able to find the part numbers for the "o rings"/gaskets, so that means no price reference either. Any info would be appreciated.
blackwagon is offline
post #2 of 19 Old 22nd January 2011, 09:45 PM
russap5
russap5's Avatar
I'm interested to know as well because recently in Peter's engine build thread there is discussion that the Dr.Vanos kits cause a lot of issues. It sounds like OEM is the way to go.
2001 ///M5 Jet Black on Caramel / Alcantara
Dinan
CAI, Dinan Rear Sway Bar, Dinan Front Strut Bar, Dinan Exhaust, Dinan
Brembo GT BBK 355mm Front - 345mm Rear, Evolve Alpha-N Tuning, Walbro 255HP fuel pump,
Ground Control Coilovers, Evolve "Medusa" headers, Magnaflow Cats, SuperSprint X-pipe, Magnaflow 10416 resonators, Beastpower Rear Sway Brackets, Gulf Oil Filter Housing w/ Fluidyne Cooler,
Custom Fluidyne Power Steering Cooler,
Linea Corse Z2S 19" wheels w/ Continental DW tires, EVO U/D Pulleys, Reinforced Rear Subframe, Diff Viton O-rings,
RaceSkids Metal Underbody Panels, Custom Leather/Alcantara steering wheel door panels and front seats, 35% window tint, Valentine One Hardwired, ACS style splitters,
E60 SSK and ZHP Knob, "Shorty" clutch stop w/ start sensor mod, Carbon Fiber Wrapped Interior, BSW subwoofer kit, Competition 6.5" front speakers in custom baffles,
DICE/Intravee II iPod adapter, TEC Cupholder, E90 radio knobs, AC and USB powered plugs installed in center console, Full LED overhaul in cabin/footwells/trunk
DIY Accelerator Pedal Removal
My Custom covered steering wheel
My plug-n-play LED light upgrade
DIY adding AC and USB power outlets
DIY fix squeaking steering wheel adjustments
Shadow Chrome: A closer look
$6 DIY headrest in-car camera mount
M5 DIY for Dummies
russap5 is offline
post #3 of 19 Old 22nd January 2011, 11:18 PM
wsfm5
wsfm5's Avatar
Would recommend OEM. Have been spending a lot of time on similar threads since my M5 has recently developed "oil reflux" in the plenum and intake plumbing. Saw a number of recos for OEM only and at least one instance where the viton o-rings from Dr. Vanos failed within a year.
wsfm5 is offline
post #4 of 19 Old 22nd January 2011, 11:24 PM
vantaam5
OEM is way cheaper,has the correct design of the O-rings and also lasts quite long..
vantaam5 is offline
The Following User Says Thank You to vantaam5 For This Useful Post:
herrubermensch (23rd January 2011)
post #5 of 19 Old 23rd January 2011, 02:25 AM Thread Starter
blackwagon
post #6 of 19 Old 23rd January 2011, 05:28 AM
wsfm5
wsfm5's Avatar
wsfm5 is offline
The Following 2 Users Say Thank You to wsfm5 For This Useful Post:
blackwagon (23rd January 2011), klunk (23rd January 2011)
post #7 of 19 Old 23rd January 2011, 07:22 AM
gixxeridaz
gixxeridaz's Avatar
gixxeridaz is offline
post #8 of 19 Old 23rd January 2011, 09:32 AM
klunk
klunk's Avatar
Thanks for the diagram.
assuming the mechanical parts were in serviceable condition, what parts from that diagram are recommended for a vanos rebuild ?
klunk is offline
post #9 of 19 Old 23rd January 2011, 09:35 AM
feeblebob
feeblebob's Avatar
vantaam5, didn't you mention in another thread the other day that the OEM replacements now are made of better material and less likely to fail the way the originals did, especially for pre-facelift cars?
2001 E39 M5 : Silverstone Blue, 19" Breyton Spirits (horribly rashed...Genuine BBS LM's to go on), Philips Silverline Indicator Bulbs, Intravee II and Alpine KCA-420i (in a box in the house) and 160GB iPod Classic , Evolve headers and race cats to go on, otherwise standard at the mo...
"I look at it like this. Owning an M5 is kind of like dating a slamming hot big-t...ed blonde, who is a pain in the *****, drains your cash, but screws like there's no tomorrow. Owning a Honda Civic or the like, is akin to dating a girl who is fat, ugly, smells a bit where she shouldn't, is a cheap date and doesn't screw at all (you don't mind). So yeah, I'll take the blonde." (Courtsey of Jetpilot718)
The thread of my car and it's progression to mechanical perfection... : https://www.m5board.com/vbulletin/e39...ry-thread.html if I ever get around to anything...
Cabin Filters 6/3/11, Bosch wipers 21/5/11, OEM air filters 24/5/11 (110,920), Oil Change, Oil Seperators and Thermostat 07/08/11 (112,699), Final Stage Resistor, Coolant Temp Sensor, Silvered Indicator Bulbs 21/08/11 (114,110), Private Plate 23/10/11, Came home from storage 13/02/13
feeblebob is offline
post #10 of 19 Old 23rd January 2011, 09:41 AM
feeblebob
feeblebob's Avatar
klunk, if it helps, this site has some VANOS info, in terms of what might be needed for a recon.
Mr Vanos - Bmw Vanos Repair Specialists - E39 M5 S62 5.0 Vanos
There's also plenty of info in the DIY section and just google 'vanos E39 M5' to bring up up lots of info.
From what I've found, it's either leaking seals which is fairly simple, or an actual failing/broken component (solenoids etc.) which affects the VANOS system.
The Following User Says Thank You to feeblebob For This Useful Post:
Vanos Solenoid Seal Replacement Write Up JeffYoung E39 M5 and E52 Z8 Discussion 10 3rd July 2010 12:32 AM
Vanos Solenoid - anyone use Dr. Vanos to repair? reds2 E39 M5 and E52 Z8 Discussion 3 2nd March 2010 04:01 AM
More codes after Vanos solenoid replacement...:mad: rroberrto E39 M5 and E52 Z8 Discussion 6 19th August 2009 10:03 PM
Vanos Solenoid vs Complete Vanos Replacement SoCaLE39 E39 M5 and E52 Z8 Discussion 5 4th June 2008 09:42 PM
VANOS replacement (solenoid)...Now what? FAST4DR E39 M5 and E52 Z8 Discussion 13 4th April 2003 01:47 AM
